1个回答
在自然同步同步电机的控制中,需要对电机的三相定子施加一定的电压,才能控制捕捉。要想产生SVPWM波形,需要控制的三相电压呈如下形式,即A,B,C三相的电压是中间对齐的,这就需要用到STM32定时器的中间对齐模式了。
1,STM32的时钟树 STM32的时钟树如下图所示,简单介绍一下STM32时钟的配置过程。以外部时钟作为时钟源为例。HSE代表外部时钟(假设为8M),SYSCLK为系统时钟,经过倍频器之后变成168M、SYSCLK经过AHB预分频器(真分频系数为1)后变成HCLK时钟相当于系统时钟SYSCLK,HCLK即AHB外部时钟,APB预分频器分出APB1(频分频因子为2) ,低速设备SYSCLK/4)与APB2时钟(分频系数为1,高速设备SYSCLK/2) HSE-》SYSCLK-》HCLK-》APB1APB2。 针对stm32f427的配置资源如下 static void SetSysClock(void) { #if defined (STM32F40_41xxx) || defined (STM32F427_437xx) || defined (STM32F429_439xx) || defined (STM32F401xx) /******************************************************************************/ /* PLL (clocked by HSE) used as System clock source */ /******************************************************************************/ __IO uint32_t StartUpCounter = 0, HSEStatus = 0; /* Enable HSE */ RCC-》CR |= ((uint32_t)RCC_CR_HSEON); /* Wait till HSE is ready and if Time out is reached exit */ do { HSEStatus = RCC-》CR & RCC_CR_HSERDY; StartUpCounter++; } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT)); if ((RCC-》CR & RCC_CR_HSERDY) != RESET) { HSEStatus = (uint32_t)0x01; } else { HSEStatus = (uint32_t)0x00; } if (HSEStatus == (uint32_t)0x01) { /* Select regulator voltage output Scale 1 mode */ RCC-》APB1ENR |= RCC_APB1ENR_PWREN; PWR-》CR |= PWR_CR_VOS; /* HCLK = SYSCLK / 1*/ RCC-》CFGR |= RCC_CFGR_HPRE_DIV1;//AHB时钟 #if defined (STM32F40_41xxx) || defined (STM32F427_437xx) || defined (STM32F429_439xx) /* PCLK2 = HCLK / 2*/ RCC-》CFGR |= RCC_CFGR_PPRE2_DIV2;//APB2时钟 /* PCLK1 = HCLK / 4*/ RCC-》CFGR |= RCC_CFGR_PPRE1_DIV4;//APB1时钟 #endif /* STM32F40_41xxx || STM32F427_437x || STM32F429_439xx */ /* Configure the main PLL */ RCC-》PLLCFGR = PLL_M | (PLL_N 《《 6) | (((PLL_P 》》 1) -1) 《《 16) | (RCC_PLLCFGR_PLLSRC_HSE) | (PLL_Q 《《 24); /* Enable the main PLL */ RCC-》CR |= RCC_CR_PLLON; /* Wait till the main PLL is ready */ while((RCC-》CR & RCC_CR_PLLRDY) == 0) { } #if defined (STM32F427_437xx) || defined (STM32F429_439xx) /* Enable the Over-drive to extend the clock frequency to 180 Mhz */ PWR-》CR |= PWR_CR_ODEN; while((PWR-》CSR & PWR_CSR_ODRDY) == 0) { } PWR-》CR |= PWR_CR_ODSWEN; while((PWR-》CSR & PWR_CSR_ODSWRDY) == 0) { } /* Configure Flash prefetch, Instruction cache, Data cache and wait state */ FLASH-》ACR = FLASH_ACR_PRFTEN | FLASH_ACR_ICEN |FLASH_ACR_DCEN |FLASH_ACR_LATENCY_5WS; #endif /* STM32F427_437x || STM32F429_439xx */ /* Select the main PLL as system clock source */ RCC-》CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW)); RCC-》CFGR |= RCC_CFGR_SW_PLL; /* Wait till the main PLL is used as system clock source */ while ((RCC-》CFGR & (uint32_t)RCC_CFGR_SWS ) != RCC_CFGR_SWS_PLL); { } } else { /* If HSE fails to start-up, the application will have wrong clock configuration. User can add here some code to deal with this error */ } } 2 、stm32定时器的时钟 stm32定时器分为高级定时器(TIM1与TIM8)、通用定时器(TIM2-TIM5、TIM9-TIM14)、基本定时器(TIM6、TIM7)。 其中TIM1,TIM8,TIM10,TIM11使用的是APB2时钟,而其余定时器使用的是APB1时钟。 在STM32中手册有这么一段话教育 根据前面RCC配置可以知道TIM1,TIM8,TIM10,TIM11使用的时钟频率为SYSCLK,其他定时器使用的时钟频率为SYSCLK/2 3、stm32定时器1的卫星模式 时钟模式的图标如下图所示,可以看到在中心模式下产生的PWM时钟的生命周期比实际计数生命周期要等大倍,如果要使用PWM1模式,并且需要产生的PWM波频率为20K,那么的定时器时基应该设为40K。 在SVPWM波的产生过程中使用的是定时器1的3对互补的PWM通道,它的配置如下 static void TIM1_Configuration(void) { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; TIM_BDTRInitTypeDef TIM_BDTRInitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);//使能定时器1时钟 Time1_Period = (SystemCoreClock / 40000 );//定时器频率为APB2频率的2倍=HCLK 自动重装载为40K,最大值为4200 Limit_Pluse_Max_Value = Time1_Period * 0.95; /* TIM1 Peripheral Configuration */ TIM_DeInit(TIM1); /* Time Base configuration */ //配置定时器的计数方式为中间对齐方式,所以产生的PWM波的频率为20K TIM_TimeBaseStructure.TIM_Prescaler = 0x0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_CenterAligned1;//TIM_CounterMode_Up;TIM_CounterMode_CenterAligned1 TIM_TimeBaseStructure.TIM_Period = Time1_Period - 1;//PERIOD;//定时器时基40K TIM_TimeBaseStructure.TIM_ClockDivision = 0x0; TIM_TimeBaseStructure.TIM_RepetitionCounter = 0x0; TIM_TimeBaseInit(TIM1,&TIM_TimeBaseStructure); /* Channel 1, 2,3 and 4 Configuration in PWM mode */ TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable; TIM_OCInitStructure.TIM_Pulse = Time1_Period / 2;//CCR1_Val; //占空比50% TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;//TIM_OCPolarity_Low;TIM_OCPolarity_High; TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;//TIM_OCNPolarity_Low;TIM_OCNPolarity_High; TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset;//TIM_OCIdleState_Set; TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset; TIM_OC1Init(TIM1,&TIM_OCInitStructure); TIM_OCInitStructure.TIM_Pulse = Time1_Period / 2;//CCR2_Val;//占空比50% TIM_OC2Init(TIM1,&TIM_OCInitStructure); TIM_OCInitStructure.TIM_Pulse = Time1_Period / 2;//CCR3_Val;//占空比50% TIM_OC3Init(TIM1,&TIM_OCInitStructure); // /* Channel 4 Configuration in OC */ // TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; // TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; // TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable; // TIM_OCInitStructure.TIM_Pulse = 4000;//Time1_Period / 2; //1500;//PERIOD - 1; // // TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; // TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low; // TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset; // TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset; // TIM_OC4Init(TIM1,&TIM_OCInitStructure); /* TIMx-》CCMR1的bit3设为1:输出比较寄存器预装载使能 */ // PWM占空比改变只在更新事件时生效 TIM_OC1PreloadConfig(TIM1,TIM_OCPreload_Enable);//A相 /* TIMx-》CCMR1的bit11设为1:输出比较寄存器预装载使能 */ // PWM占空比改变只在更新事件时生效 TIM_OC2PreloadConfig(TIM1,TIM_OCPreload_Enable);//B相 /* TIMx-》CCMR2的bit3设为1:输出比较寄存器预装载使能 */ // PWM占空比改变只在更新事件时生效 TIM_OC3PreloadConfig(TIM1,TIM_OCPreload_Enable);//C相 // TIM_OC4PreloadConfig(TIM1,TIM_OCPreload_Enable);//电磁铁 /* Automatic Output enable, Break, dead time and lock configuration*/ TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable; TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable; TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_1; TIM_BDTRInitStructure.TIM_DeadTime = 50; TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable;//TIM_Break_Enable; TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High; TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Disable;//TIM_AutomaticOutput_Enable; TIM_BDTRConfig(TIM1,&TIM_BDTRInitStructure); TIM_SelectOutputTrigger(TIM1,TIM_TRGOSource_Update); /* TIM1 counter enable */ // TIM_Cmd(TIM1,ENABLE); /* Main Output Enable */ TIM_CtrlPWMOutputs(TIM1,ENABLE);//由于使用中间对齐模式,PWM频率为20K //TIM_ITConfig(TIM1, TIM_IT_Update, ENABLE);//定时器1的溢出中断 } |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1362 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1359 浏览 1 评论
779 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
561 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1391 浏览 2 评论
1756浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
483浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
417浏览 3评论
410浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
388浏览 3评论
GMT+8, 2024-9-27 22:29 , Processed in 0.793577 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
