1个回答
VCC 供 5V电源,
GND 为地线, TRIG 触发控制信号输入, ECHO 回响信号输出。 //ECHO PA4 //TRIG PA5 1.了解超声波的原理 (1)采用 IO 口 TRIG 触发测距,给最少 10us 的高电平信号。 (2)模块自动发送 8 个 40khz 的方波,自动检测是否有信号返回; (3)有信号返回,通过 IO 口 ECHO 输出一个高电平,高电平持续的时间就是超声波从发射到返回的时间。测试距离=(高电平时间*声速(340M/S))/2; int main(void) { unsigned int count=0; float distance=0; float distancebuf[]={0}; /* USART1 config 115200 8-N-1 */ USART1_Config(); Distance_Config(); //测距模块对应的引脚初始化 CLI() ;//关闭总中断 SEI(); //开总中断 Tim3_Config(); //定时器的初始化 GPIO_ResetBits(GPIOA,GPIO_Pin_5); //先拉低电平 while(1) { // printf("测距开始n"); GPIO_SetBits(GPIOA,GPIO_Pin_5); //拉高电平 Delay(2000000000); //延时20个微秒 // Delay(20); // Delay(20); GPIO_ResetBits(GPIOA,GPIO_Pin_5); TIM3->CNT=0; //TIM3的计数器清0 while(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_4) == 0); //等待ECHO的高电平 TIM_Cmd(TIM3,ENABLE); //运行TIM3进行计时 while((GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_4) == 1) && (TIM3->CNT < TIM3->ARR-10)); TIM_Cmd(TIM3,DISABLE); count=TIM3->CNT; printf("count=%d",count); distance=ChangeDistance(count) -1; printf(" 当前距离为:%fn",distance); Delay(2000000000); //Delay(50); //while(1); } } void Delay(unsigned short int time) //粗略的延时函数(自带的延迟) { unsigned char i=0; while(time--) { i=100; // i改的越大,延迟越高 while(i--); } } float ChangeDistance(unsigned int cout1) { float distance=0; printf("cou1=%dn",cout1); distance=cout1/58.0; return distance; } usart文件内容 void USART1_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; /* config USART1 clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE); /* USART1 GPIO config */ /* Configure USART1 Tx (PA.09) as alternate function push-pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); /* Configure USART1 Rx (PA.10) as input floating */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); /* USART1 mode config */ USART_InitStructure.USART_BaudRate = 115200; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No ; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(USART1, &USART_InitStructure); USART_Cmd(USART1, ENABLE); } ///重定向c库函数printf到USART1 int fputc(int ch, FILE *f) { /* 发送一个字节数据到USART1 */ USART_SendData(USART1, (uint8_t) ch); /* 等待发送完毕 */ while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET); return (ch); } ///重定向c库函数scanf到USART1 int fgetc(FILE *f) { /* 等待串口1输入数据 */ while (USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET); return (int)USART_ReceiveData(USART1); } |
只有小组成员才能发言,加入小组>>
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
427 浏览 1 评论
279 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
247 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
611 浏览 2 评论
635 浏览 2 评论
1364浏览 9评论
37浏览 3评论
STM32CUBEMX4.22.1在main函数里面添加一行语句就死机的原因?
49浏览 3评论
42浏览 3评论
KEIL MDK为什么无法debug library中的代码?
80浏览 3评论
GMT+8, 2024-4-27 21:55 , Processed in 0.533135 second(s), Total 45, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
