实验目的:中断方式按键(PA0)实现流水灯,每个灯之间的切换时延是2秒
1在文件stm32f4xx.h中找到STM32F40_41xxx系列HSE_VALUE(L144)改为8000000 在文件system_stm32f4xx.c中修改STMF40_41xxx系列 PLL_M=8 L371 PLL_N=336 L401 PLL_P=2 L403 systick.c #include “stm32f4xx.h” #include 《stdint.h》 #define rSysTickCtrl *((volatile unsigned long*)0xE000E010) static uint32_t systicknum = 0; //定时器中断函数 void SysTick_Handler(void) { if(systicknum != 0) { systicknum--; } } void delay_ms(uint32_t m) { systicknum = m; SysTick_Config(SystemCoreClock/1000); NVIC_SetPriority(SysTick_IRQn, 0); while(systicknum != 0); rSysTickCtrl &= ~(1 《《 0) ; // bit0 -》 0 disable SysTick } void delay_us(uint32_t u) { systicknum = u; SysTick_Config(SystemCoreClock/1000000); //NVIC_SetPriority(SysTick_IRQn, 1); while(systicknum != 0); rSysTickCtrl &= ~(1 《《 0) ; // bit0 -》 0 disable SysTick } rj_led.c #include “rj_led.h” #include “systick.h” void led_init() { GPIO_InitTypeDef P; /*使能GPIOD的时钟*/ RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE); /*配置PD0,PD1,PD2,PD3,为输出模式,输出类型为输出推挽, 速率为50MHz,无上拉下拉电阻*/ P.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3; P.GPIO_Mode = GPIO_Mode_OUT; P.GPIO_OType = GPIO_OType_PP; P.GPIO_Speed = GPIO_Speed_50MHz; P.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOD, &P); } void led_ctrl(int led_n) { switch(led_n) { case 1: { /*控制LED1亮,其他灯熄灭,给PD0端口置1,PD1,PD2,PD3端口置0*/ GPIO_SetBits(GPIOD, GPIO_Pin_0); GPIO_ResetBits(GPIOD, GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3); break; } case 2: { /*控制LED2亮,其他灯熄灭,给PD1端口置1,PD0,PD2,PD3端口置0*/ GPIO_SetBits(GPIOD, GPIO_Pin_1); GPIO_ResetBits(GPIOD, GPIO_Pin_0|GPIO_Pin_2|GPIO_Pin_3); break; } case 3: { /*控制LED3亮,其他灯熄灭,给PD2端口置1,PD1,PD0,PD3端口置0*/ GPIO_SetBits(GPIOD, GPIO_Pin_2); GPIO_ResetBits(GPIOD, GPIO_Pin_1|GPIO_Pin_0|GPIO_Pin_3); break; } case 4: { /*控制LED4亮,其他灯熄灭,给PD3端口置1,PD1,PD2,PD0端口置0*/ GPIO_SetBits(GPIOD, GPIO_Pin_3); GPIO_ResetBits(GPIOD, GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_0); break; } default: break; } } void delay(int num) { while(num--); } void led_loop() //LED等循环点亮; { int led_count=1; for(led_count=1;led_count《5;led_count++) { led_ctrl(led_count); delay_ms(200); } } rj_int_key.c #include “stm32f4xx.h” /* KEY -》 PA -》 EXTI -》 NVIC -》 CPU EXTI_IRQHandler */ void key_int_init(void) { //时钟使能; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA|RCC_AHB1Periph_GPIOE,ENABLE); /*配置端口,为输入模式,速率为50MHz,不上拉*/ GPIO_InitTypeDef p; p.GPIO_Pin=GPIO_Pin_0; p.GPIO_Mode=GPIO_Mode_IN; p.GPIO_Speed=GPIO_Speed_50MHz; //p.GPIO_OType=GPIO_OType_PP; //输出推挽; p.GPIO_PuPd=GPIO_PuPd_NOPULL; GPIO_Init(GPIOA,&p); p.GPIO_Pin=GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4; GPIO_Init(GPIOE,&p); /*SYSCFG选择器的配置*/ RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE); //时钟使能; SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOA,EXTI_PinSource0); //选择PA0作为外部中断的输入引脚; SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOE,EXTI_PinSource2); //PE2 SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOE,EXTI_PinSource3); //PE3 SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOE,EXTI_PinSource4); //PE4 /*外部中断控制器的配置*/ RCC_APB2PeriphClockCmd(RCC_APB2Periph_EXTIT, ENABLE);//时钟使能; EXTI_InitTypeDef e; e.EXTI_Line=EXTI_Line0|EXTI_Line2|EXTI_Line3|EXTI_Line4; e.EXTI_Mode=EXTI_Mode_Interrupt; //中断模式; e.EXTI_LineCmd=ENABLE; e.EXTI_Trigger=EXTI_Trigger_Rising; //上升沿; EXTI_Init(&e); /*NVIC的控制*/ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//pre:2,sub:2 NVIC_InitTypeDef n; n.NVIC_IRQChannel=EXTI0_IRQn; n.NVIC_IRQChannelCmd=ENABLE; //n.NVIC_IRQChannelPreemptionPriority = 0x02; //n.NVIC_IRQChannelSubPriority = 0x02; NVIC_Init(&n); n.NVIC_IRQChannel=EXTI2_IRQn; NVIC_Init(&n); n.NVIC_IRQChannel=EXTI3_IRQn; NVIC_Init(&n); n.NVIC_IRQChannel=EXTI4_IRQn; NVIC_Init(&n); NVIC_SetPriority(EXTI0_IRQn,0x07); } uint8_t status = 0; void key_irqHandler(void) { // 1.EXTI_GetITStatus if (EXTI_GetITStatus(EXTI_Line0) == SET) { status = 1; //EXTI_ClearFlag 清除中断标识,否则会一直产生中断; EXTI_ClearFlag(EXTI_Line0); } } //中断函数,按一下亮,再按一下灭 //int f1 = 0, f2 = 0, f3 = 0, f4 = 0; //void key_irqHandler(void) //{ // if (EXTI_GetITStatus(EXTI_Line0) == SET) // { // if (f1 == 0) // { // GPIO_SetBits(GPIOD, GPIO_Pin_0); // f1 = 1; // } // else // { // GPIO_ResetBits(GPIOD, GPIO_Pin_0); // f1 = 0; // } // EXTI_ClearITPendingBit(EXTI_Line0); // } // if (EXTI_GetITStatus(EXTI_Line2) == SET) // { // if (f2 == 0) // { // GPIO_SetBits(GPIOD, GPIO_Pin_1); // f2 = 1; // } // else // { // GPIO_ResetBits(GPIOD, GPIO_Pin_1); // f2 = 0; // } // EXTI_ClearITPendingBit(EXTI_Line2); // } // if (EXTI_GetITStatus(EXTI_Line3) == SET) // { // if (f3 == 0) // { // GPIO_SetBits(GPIOD, GPIO_Pin_2); // f3 = 1; // } // else // { // GPIO_ResetBits(GPIOD, GPIO_Pin_2); // f3 = 0; // } // EXTI_ClearITPendingBit(EXTI_Line3); // } // if (EXTI_GetITStatus(EXTI_Line4) == SET) // { // if (f4 == 0) // { // GPIO_SetBits(GPIOD, GPIO_Pin_3); // f4 = 1; // } // else // { // GPIO_ResetBits(GPIOD, GPIO_Pin_3); // f4 = 0; // } // EXTI_ClearITPendingBit(EXTI_Line4); // } //} 实验三角形: |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1614 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1541 浏览 1 评论
970 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
682 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1592 浏览 2 评论
1863浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
644浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
515浏览 3评论
531浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
504浏览 3评论
GMT+8, 2024-11-22 01:24 , Processed in 0.572343 second(s), Total 76, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
