Micro USB接上数据线,就可以进行串口查看及调试了,电脑识别为COM4,我用了XshellV6软件
连接上后,按一下 开发板上的复位键,就能看到开发板启动过程中的一系列信息,这也有助于多了解和熟悉开发板。
下面是启动过程中的一系列信息:
- IPL g5da0ceb
- D-1d
- HW Reset
- miupll_166MHz
- miu_bw_set
- utmi_1_init done
- utmi_2_init done
- utmi_3_init done
- u***pll init done......
- cpupll init done
- SPI 54M
- clk_init done
- P1 USB_rterm trim=0x0000
- P1 USB_HS_TX_CURRENT trim=0x0001
- P2 USB_rterm trim=0x0001
- P2 USB_HS_TX_CURRENT trim=0x0001
- P3 USB_rterm trim=0x0001
- P3 USB_HS_TX_CURRENT trim=0x0001
- PM_vol_bgap trim=0x0004
- GCR_SAR_DATA trim=0x0190
- ETH 10T output swing trim=0x0000
- ETH 100T output swing trim=0x0000
- ETH RX input impedance trim=0x0000
- ETH TX output impedance trim=0x0000
- MIPI_HS_RTERM trim=0x0001
- MIPI_LP_RTERM trim=0x0000
- 64MB
- BIST0_0001-OK
- Enable MMU and CACHE
- Load IPL_CUST from SPINAND
- QUAD MODE ENABLE
- Checksum OK
- IPL_CUST g5da0ceb
- runUBOOT()
- runUBOOT()
- [SPINAND]
- SPI 54M
- Load UBOOT from SPINAND
- -Verify UBOOT CRC32 passed!
- -Decompress UBOOT XZ
- decomp_size=0x000a7820
- Disable MMU and D-cache before jump to UBOOT
- U-Boot 2015.01 (Apr 12 2021 - 13:39:20)
- Version: I2g#######
- [WDT] Enalbe WATCHDOG 60s
- Watchdog enabled
- I2C: ready
- DRAM:
- WARNING: Caches not enabled
- SPINAND: _MDrv_SPINAND_GET_INFO: Found SPINAND INFO
- (0xCD) (0xEB) (0x11)
- SPINAND: board_nand_init: CIS contains part info
- 256 MiB
- MMC: MStar SD/MMC: 0
- In: serial
- Out: serial
- Err: serial
- Net: MAC Address 00:30:1B:BA:02:DB
- Auto-Negotiation...
- Link Status Speed:10 Full-duplex:0
- Status Error!
- sstar_emac
- Saving Environment to NAND...
- Erasing NAND...
- Erasing at 0x440000 -- 100% complete.
- Writing to NAND... OK
- Erasing NAND...
- gpio debug MHal_GPIO_Pad_Set: pin=19
- _[sdmmc_0] Card Detect Fail!
- ** Bad device mmc 0 **
- Error: the max size of one line is 8000!!!
- sdstar - script via sd package
- Usage:
- sdstar
- Erasing NAND...
- do_display 1705, argc =6
- do_display 1803:: In(0 fd200), Out(0 fd200), Disp(0 0 0) Interface:0
- _DrvDispIfTransDeviceOutpuTimingInfoToHal 210, Can't find Timing(UNKNOWN) in Table
- MHAL_DISP_DeviceSetOutputTiming 166, SetOutputTiming Fail
- gpio debug MHal_GPIO_Pad_Set: pin=8
- gpio[8] is 0
- NAND read: device 0 offset 0x520000, size 0x500000
- Time:1148528 us, speed:4564 KB/s
- 5242880 bytes read: OK
- gpio[8] is 1
- ## Booting kernel from Legacy Image at 22000000 ...
- Image Name: MVX4##I2M#g#######KL_LX409##[BR:
- Image Type: ARM Linux Kernel Image (lzma compressed)
- Data Size: 2220476 Bytes = 2.1 MiB
- Load Address: 20008000
- Entry Point: 20008000
- Verifying Checksum ... OK
- -u***_stop(USB_PORT0)
- -u***_stop(USB_PORT1)
- -u***_stop(USB_PORT2)
- Uncompressing Kernel Image ...
- [XZ] !!!reserved 0x21000000 length=0x 1000000 for xz!!
- XZ: uncompressed size=0x470000, ret=7
- OK
- atags:0x20000000
- Starting kernel ...
- Booting Linux on physical CPU 0x0
- Linux version 4.9.84 (ronnie@wt_rd_server) (gcc version 8.2.1 20180802 (GNU Toolchain for the A-profile Architecture 8.2-2018-08 (arm-rel-8.23)) ) #280 SMP PREEMPT Mon Apr 12 13:40:23 CST 2021
- CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
- CPU: div instructions available: patching division code
- CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
- early_atags_to_fdt() success
- OF: fdt:Machine model: INFINITY2M SSC011A-S01A-S
- LXmem is 0x3f00000 PHYS_OFFSET is 0x20000000
- Add mem start 0x20000000 size 0x3f00000!!!!
- LX_MEM = 0x20000000, 0x3f00000
- LX_MEM2 = 0x0, 0x0
- LX_MEM3 = 0x0, 0x0
- EMAC_LEN= 0x0
- DRAM_LEN= 0x0
- deal_with_reserved_mmap memblock_reserve success mmap_reserved_config[0].reserved_start=
- 0x23300000
- deal_with_reserve_mma_heap memblock_reserve success mma_config[0].reserved_start=
- 0x21900000
- cma: Reserved 2 MiB at 0x23c00000
- Memory policy: Data cache writealloc
- percpu: Embedded 14 pages/cpu @c3e3c000 s25112 r8192 d24040 u57344
- Built 1 zonelists in Zone order, mobility grouping on. Total pages: 9346
- Kernel command line: console=ttyS0,115200 ubi.mtd=UBI,2048 root=ubi:rootfs rw rootfstype=ubifs init=/linuxrc rootwait=1 LX_MEM=0x3f00000 mma_heap=mma_heap_name0,miu=0,sz=0x1a00000 mma_memblock_remove=1 highres=off mmap_reserved=fb,miu=0,sz=0x300000,max_start_off=0x3300000,max_end_off=0x3600000 mtdparts=nand0:384k@1280k(IPL0),384k(IPL1),384k(IPL_CUST0),384k(IPL_CUST1),768k(UBOOT0),768k(UBOOT1),384k(ENV0),0x20000(KEY_CUST),0x60000(LOGO),0x500000(KERNEL),0x500000(RECOVERY),-(UBI)
- PID hash table entries: 256 (order: -2, 1024 bytes)
- Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
- Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
- Memory: 27408K/37888K available (2627K kernel code, 226K rwdata, 1372K rodata, 168K init, 167K bss, 8432K reserved, 2048K cma-reserved)
- Virtual kernel memory layout:
- vector : 0xffff0000 - 0xffff1000 ( 4 kB)
- fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
- vmalloc : 0xc4000000 - 0xff800000 ( 952 MB)
- lowmem : 0xc0000000 - 0xc3f00000 ( 63 MB)
- modules : 0xbf800000 - 0xc0000000 ( 8 MB)
- .text : 0xc0008000 - 0xc0298f68 (2628 kB)
- .init : 0xc0414000 - 0xc043e000 ( 168 kB)
- .data : 0xc043e000 - 0xc0476a88 ( 227 kB)
- .bss : 0xc0478000 - 0xc04a1e10 ( 168 kB)
- SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
- Preemptible hierarchical RCU implementation.
- Build-time adjustment of leaf fanout to 32.
- RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
- RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
- NR_IRQS:16 nr_irqs:16 16
- ms_init_main_intc: np->name=ms_main_intc, parent=gic
- ms_init_pm_intc: np->name=ms_pm_intc, parent=ms_main_intc
- ss_init_gpi_intc: np->name=ms_gpi_intc, parent=ms_main_intc
- Find CLK_cpupll_clk, hook ms_cpuclk_ops
- arm_arch_timer: Architected cp15 timer(s) running at 6.00MHz (virt).
- clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1623fa770, max_idle_ns: 440795202238 ns
- sched_clock: 56 bits at 6MHz, resolution 166ns, wraps every 4398046511055ns
- Switching to timer-based delay loop, resolution 166ns
- Console: colour dummy device 80x30
- console [ttyS0] enabled
- Calibrating delay loop (skipped), value calculated using timer frequency.. 12.00 BogoMIPS (lpj=60000)
- pid_max: default: 4096 minimum: 301
- Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
- Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
- CPU: Testing write buffer coherency: ok
- CPU0: update cpu_capacity 1024
- CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
- Setting up static identity map for 0x20008240 - 0x20008270
- CPU1: update cpu_capacity 1024
- CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
- Brought up 2 CPUs
- SMP: Total of 2 processors activated (24.00 BogoMIPS).
- CPU: All CPU(s) started in SVC mode.
- devtmpfs: initialized
- VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
- clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
- futex hash table entries: 16 (order: -2, 1024 bytes)
- NET: Registered protocol family 16
- DMA: preallocated 256 KiB pool for atomic coherent allocations
- Version : MVX4##I2M#g#######KL_LX409##[BR:g]#XVM
- GPIO: probe end[ss_gpi_intc_domain_alloc] hw:42 -> v:43
- [MS_PM_INTC] hw:20 -> v:51
- [Padmux]reset Pad_58(reg 0xe28; mask0x4000) to GPIO(org: PM_SD_CDZ_MODE)
- [Padmux]reset Pad_87(reg 0x101e09; mask0x7) to DMIC_MODE_2(org: I2C0_MODE_1)
- hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
- hw-breakpoint: maximum watchpoint size is 8 bytes.
- SCSI subsystem initialized
- u***core: registered new interface driver u***fs
- u***core: registered new interface driver hub
- u***core: registered new device driver u***
- Linux video capture interface: v2.00
- clocksource: Switched to clocksource arch_sys_counter
- NET: Registered protocol family 2
- TCP established hash table entries: 1024 (order: 0, 4096 bytes)
- TCP bind hash table entries: 1024 (order: 2, 20480 bytes)
- TCP: Hash tables configured (established 1024 bind 1024)
- UDP hash table entries: 128 (order: 0, 6144 bytes)
- UDP-Lite hash table entries: 128 (order: 0, 6144 bytes)
- hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
- workingset: timestamp_bits=30 max_order=13 bucket_order=0
- squashfs: version 4.0 (2009/01/31) Phillip Lougher
- jffs2: version 2.2. © 2001-2006 Red Hat, Inc.
- io scheduler noop registered
- io scheduler deadline registered (default)
- libphy: Fixed MDIO Bus: probed
- mousedev: PS/2 mouse device common for all mice
- i2c /dev entries driver
- u***core: registered new interface driver uvcvideo
- USB Video Class driver (1.1.1)
- u***core: registered new interface driver u***hid
- u***hid: USB HID core driver
- 1f221000.uart0: ttyS0 at MMIO 0x0 (irq = 30, base_baud = 10800000) is a unknown
- 1f221200.uart1: ttyS1 at MMIO 0x0 (irq = 31, base_baud = 10800000) is a unknown
- 1f220400.uart2: ttyS2 at MMIO 0x0 (irq = 32, base_baud = 10800000) is a unknown
- [Padmux]reset Pad_49(reg 0x101e03; mask0x700) to GPIO(org: UART1_MODE_1)
- [ss_gpi_intc_domain_alloc] hw:0 -> v:58
- [Core Voltage] check_voltage_valid: Not support 0mV, use 850mV
- [ mstar_mci_init() ]
- eMMC: no SD 1006
- >> [emmc] get dts [bus-width]: 4
- >> [emmc] get dts [max-clks]: 2
- >> [emmc] get dts [clk-driving]: 0
- >> [emmc] get dts [cmd-driving]: 0
- >> [emmc] get dts [data-driving]: 0
- [ mstar_mci_completed_command() ] eMMC Warn: ST:F08h, CMD:1, arg:0h, retry:0
- ##################################### in ms_sdmmc_probe
- >> [sdmmc] ms_sdmmc_probe
- [Padmux]reset Pad_51(reg 0x101e08; mask0x300) to GPIO(org: SDIO_MODE_1)
- >> [sdmmc_0] Probe Platform Devices
- MSYS: DMEM request: [emac0_buff]:0x00000812
- MSYS: DMEM request: [emac0_buff]:0x00000812 success, CPU phy:@0x23C42000, virt:@0xC3C42000
- libphy: mdio: probed
- mdio_bus mdio-bus@emac0: /soc/emac0/mdio-bus@emac0/ethernet-phy@0 has invalid PHY address
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 0
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 1
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 2
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 3
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 4
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 5
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 6
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 7
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 8
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 9
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 10
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 11
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 12
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 13
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 14
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 15
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 16
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 17
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 18
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 19
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 20
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 21
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 22
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 23
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 24
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 25
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 26
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 27
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 28
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 29
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 30
- mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 31
- [emac_phy_connect][3204] connected mac emac0 to PHY at mdio-bus@emac0:00 [uid=11112222, driver=SStar 10/100 Ethernet Phy]
- MSYS: DMEM request: [emac1_buff]:0x00060812
- MSYS: DMEM request: [emac1_buff]:0x00060812 success, CPU phy:@0x23C50000, virt:@0xC3C50000
- mdio_bus mdio-bus@emac1: /soc/emac1/mdio-bus@emac1/ethernet-phy@1 has invalid PHY address
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 0
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 1
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 2
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 3
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 4
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 5
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 6
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 7
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 8
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 9
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 10
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 11
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 12
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 13
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 14
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 15
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 16
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 17
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 18
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 19
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 20
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 21
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 22
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 23
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 24
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 25
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 26
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 27
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 28
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 29
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 30
- mdio_bus mdio-bus@emac1: scan phy ethernet-phy at address 31
- [emac_phy_connect][3204] connected mac emac1 to PHY at mdio-bus@emac1:01 [uid=02430c54, driver=Generic PHY]
- ms_rtcpwc 1f006800.rtcpwc: rtc core: registered 1f006800.rtcpwc as rtc0
- [ms_cpufreq_init] Current clk=1005326304
- mstar_spinand_probe: mstar_spinand enableClock
- MSYS: DMEM request: [BDMA]:0x00000840
- MSYS: DMEM request: [BDMA]:0x00000840 success, CPU phy:@0x23C43000, virt:@0xC3C43000
- MDrv_SPINAND_Init: Detected ID: MID =cd, DID =eb
- _dumpNandInformation:warning, Bytes / Page : 2048
- _dumpNandInformation:warning, Pages / Block: 64
- _dumpNandInformation:warning, Sector/ Page : 512
- _dumpNandInformation:warning, Spare / Page : 64
- _dumpNandInformation:warning, Current config r:4 w:4 drv:1
- mstar_spinand_probe: Magic memcmp pass
- mstar_spinand_probe: Get partition (Block 0 : page 1)
- mstar_spinand_probe: CIS contains part info
- mstar_spinand_probe: Before nand_scan()...
- 12 cmdlinepart partitions found on MTD device nand0
- mstar_spinand_probe: Mtd parts parse
- Creating 12 MTD partitions on "nand0":
- 0x000000140000-0x0000001a0000 : "IPL0"
- 0x0000001a0000-0x000000200000 : "IPL1"
- 0x000000200000-0x000000260000 : "IPL_CUST0"
- 0x000000260000-0x0000002c0000 : "IPL_CUST1"
- 0x0000002c0000-0x000000380000 : "UBOOT0"
- 0x000000380000-0x000000440000 : "UBOOT1"
- 0x000000440000-0x0000004a0000 : "ENV0"
- 0x0000004a0000-0x0000004c0000 : "KEY_CUST"
- 0x0000004c0000-0x000000520000 : "LOGO"
- 0x000000520000-0x000000a20000 : "KERNEL"
- 0x000000a20000-0x000000f20000 : "RECOVERY"
- 0x000000f20000-0x000010000000 : "UBI"
- NET: Registered protocol family 17
- ThumbEE CPU extension supported.
- Registering SWP/SWPB emulation handler
- ubi0: attaching mtd11
- ubi0: scanning is finished
- ubi0: attached mtd11 (name "UBI", size 240 MiB)
- ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
- ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
- ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
- ubi0: good PEBs: 1927, bad PEBs: 0, corrupted PEBs: 0
- ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128
- ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
- ubi0: available PEBs: 23, total reserved PEBs: 1904, PEBs reserved for bad PEB handling: 40
- ubi0: background thread "ubi_bgt0d" started, PID 568
- ms_rtcpwc 1f006800.rtcpwc: setting system clock to 1970-01-01 00:00:47 UTC (47)
- OF: fdt:not creating '/sys/firmware/fdt': CRC check failed
- UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 570
- UBIFS (ubi0:0): recovery needed
- UBIFS (ubi0:0): recovery completed
- UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs"
- UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
- UBIFS (ubi0:0): FS size: 205320192 bytes (195 MiB, 1617 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
- UBIFS (ubi0:0): reserved for root: 0 bytes (0 KiB)
- UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID A6CBA434-1EDF-40FA-B16A-B5D1166FFE13, small LPT model
- VFS: Mounted root (ubifs filesystem) on device 0:13.
- devtmpfs: mounted
- This architecture does not have kernel memory protection.
- mount: can't find devpts in /etc/fstab
- /etc/init.d/rcS: line 12: telnetd: not found
- Starting syslogd: OK
- Starting klogd: Jan 1 00:00:47 (none) syslog.info syslogd started: BusyBox v1.31.1
- Jan 1 00:00:48 (none) user.notice kernel: klogd started: BusyBox v1.31.1 (2020-06-08 17:40:30 CST)
- Jan 1 00:00:48 (none) user.info kernel: Booting Linux on physical CPU 0x0
- OK
- Jan 1 00:00:48 (none) user.notice kernel: Linux version 4.9.84 (ronnie@wt_rd_server) (gcc version 8.2.1 20180802 (GNU Toolchain for the A-profile Architecture 8.2-2018-08 (arm-rel-8.23)) ) #280 SMP PREEMPT Mon Apr 12 13:40:23 CST 2021
- Jan 1 00:00:48 (none) user.info kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
- Jan 1 00:00:48 (none) user.info kernel: CPU: div instructions available: patching division code
- Jan 1 00:00:48 (none) user.info kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
- Jan 1 00:00:48 (none) user.err kernel: early_atags_to_fdt() success
- Jan 1 00:00:48 (none) user.info kernel: OF: fdt:Machine model: INFINITY2M SSC011A-S01A-S
- Jan 1 00:00:48 (none) user.err kernel: LXmem is 0x3f00000 PHYS_OFFSET is 0x20000000
- Jan 1 00:00:48 (none) user.err kernel: Add mem start 0x20000000 size 0x3f00000!!!!
- Jan 1 00:00:48 (none) user.err kernel: LX_MEM = 0x20000000, 0x3f00000
- Jan 1 00:00:48 (none) user.err kernel: LX_MEM2 = 0x0, 0x0
- Jan 1 00:00:48 (none) user.err kernel: LX_MEM3 = 0x0, 0x0
- Jan 1 00:00:48 (none) user.err kernel: EMAC_LEN= 0x0
- Jan 1 00:00:48 (none) user.err kernel: DRAM_LEN= 0x0
- Jan 1 00:00:48 (none) user.err kernel: deal_with_reserved_mmap memblock_reserve success mmap_reserved_config[0].reserved_start=
- Jan 1 00:00:48 (none) user.err kernel: 0x23300000
- Jan 1 00:00:48 (none) user.err kernel: deal_with_reserve_mma_heap memblock_reserve success mma_config[0].reserved_start=
- Jan 1 00:00:48 (none) user.err kernel: 0x21900000
- Jan 1 00:00:48 (none) user.debug kernel: cma: dma_contiguous_reserve(limit ffffffff)
- Jan 1 00:00:48 (none) user.debug kernel: cma: dma_contiguous_reserve: reserving 2 MiB for global area
- Jan 1 00:00:48 (none) user.debug kernel: cma: cma_declare_contiguous(size 0x00200000, base 0x00000000, limit 0xffffffff alignment 0x00000000)
- Jan 1 00:00:48 (none) user.info kernel: cma: Reserved 2 MiB at 0x23c00000
- Jan 1 00:00:48 (none) user.info kernel: Memory policy: Data cache writealloc
- Jan 1 00:00:48 (none) user.debug kernel: On node 0 totalpages: 9472
- Jan 1 00:00:48 (none) user.debug kernel: free_area_init_node: node 0, pgdat c0475e40, node_mem_map c3e78000
- Jan 1 00:00:48 (none) user.debug kernel: Normal zone: 126 pages used for memmap
- Jan 1 00:00:48 (none) user.debug kernel: Normal zone: 0 pages reserved
- Jan 1 00:00:48 (none) user.debug kernel: Normal zone: 9472 pages, LIFO batch:1
- Jan 1 00:00:48 (none) user.info kernel: percpu: Embedded 14 pages/cpu @c3e3c000 s25112 r8192 d24040 u57344
- Jan 1 00:00:48 (none) user.debug kernel: pcpu-alloc: s25112 r8192 d24040 u57344 alloc=14*4096
- Jan 1 00:00:48 (none) user.debug kernel: pcpu-alloc: [0] 0 [0] 1
- Jan 1 00:00:48 (none) user.info kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 9346
- Jan 1 00:00:48 (none) user.notice kernel: Kernel command line: console=ttyS0,115200 ubi.mtd=UBI,2048 root=ubi:rootfs rw rootfstype=ubifs init=/linuxrc rootwait=1 LX_MEM=0x3f00000 mma_heap=mma_heap_name0,miu=0,sz=0x1a00000 mma_memblock_remove=1 highres=off mmap_reserved
- Jan 1 00:00:48 (none) user.info kernel: PID hash table entries: 256 (order: -2, 1024 bytes)
- Jan 1 00:00:48 (none) user.info kernel: Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
- Jan 1 00:00:48 (none) user.info kernel: Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
- Jan 1 00:00:48 (none) user.info kernel: Memory: 27408K/37888K available (2627K kernel code, 226K rwdata, 1372K rodata, 168K init, 167K bss, 8432K reserved, 2048K cma-reserved)
- Jan 1 00:00:48 (none) user.notice kernel: Virtual kernel memory layout:
- Jan 1 00:00random: fast init done
- :48 (none) user.notice kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB)
- Jan 1 00:00:48 (none) user.notice kernel: fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
- Jan 1 00:00:48 (none) user.notice kernel: vmalloc : 0xc4000000 - 0xff800000 ( 952 MB)
- Jan 1 00:00:48 (none) user.notice kernel: loRunning sysctl: OK
- Starting mdev...
- modprobe: can't change directory to '4.9.84': No such file or directory
- Starting watchdog...
- Saving random seed: SKIP (read-only file system detected)
- Starting network: ifup: can't open '/var/run/ifstate.new': No such file or directory
- OK
- Starting collectd: Jan 1 00:00:48 (none) daemon.info collectd[617]: plugin_load: plugin "syslog" successfully loaded.
- Jan 1 00:00:48 (none) daemon.err collectd[617]: change_basedir: mkdir (/var/lib/collectd): No such file or directory
- Error: Unable to change to directory `/var/lib/collectd'.
- FAIL
- Jan 1 00:00:48 (none) daemon.info nit: starting pid 620, tty '': '-/bin/sh'
- mount: mounting none on /sys failed: Device or resource busy
- mount: mounting none on /sys/kernel/debug/ failed: Device or resource busy
- UBIFS (ubi0:1): background thread "ubifs_bgt0_1" started, PID 630
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:1): background thread "ubifs_bgt0_1" started, PID 630
- UBIFS (ubi0:1): recovery needed
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:1): recovery needed
- UBIFS (ubi0:1): recovery completed
- UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name "miservice"
- UBIFS (ubi0:1): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
- UBIFS (ubi0:1): FS size: 9269248 bytes (8 MiB, 73 LEBs), journal size 1650688 bytes (1 MiB, 13 LEBs)
- UBIFS (ubi0:1): reserved for root: 0 bytes (0 KiB)
- UBIFS (ubi0:1): media format: w4/r0 (latest is w4/r0), UUID 49094765-31CF-4DC5-9AE6-2CFBB4AB4980, small LPT model
- UBIFS (ubi0:2): background thread "ubifs_bgt0_2" started, PID 632
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:1): recovery completed
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS UBIFS (ubi0:2): recovery needed
- (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name "miservice"
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:1): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
- Jan 1 00:00:49 (none) user.notice kernel: UBIFUBIFS (ubi0:2): recovery completed
- S (ubi0:1): FS sUBIFS (ubi0:2): UBIFS: mounted UBI device 0, volume 2, name "customer"
- UBIFS (ubi0:2): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
- UBIFS (ubi0:2): FS size: 4063232 bytes (3 MiB, 32 LEBs), journal size 1142785 bytes (1 MiB, 8 LEBs)
- UBIFS (ubi0:2): reserved for root: 0 bytes (0 KiB)
- UBIFS (ubi0:2): media format: w4/r0 (latest is w4/r0), UUID 4F45A52C-BEA3-4B54-8FB5-FB88C6C5A0D2, small LPT model
- ize: 9269248 bytUBIFS (ubi0:3): background thread "ubifs_bgt0_3" started, PID 635
- es (8 MiB, 73 LEBs), journal size 1650688 bytes (1 MiB, 13 LEBs)
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:1): reserved for root: 0 bytes (0 KiB)
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:1): media format: w4/r0 UBIFS (ubi0:3): recovery needed
- (latest is w4/r0), UUID 49094765-31CF-4DC5-9AE6-2CFBB4AB4980, small LPT model
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:2): background thread "ubifs_bgt0_2" started, PID 632
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:2): recovery needed
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:2): recovery completed
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:2): UBIFS: mounted UBI device 0, volume 2, name "customer"
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:2): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:2): FS size: 4063232 bytes (3 MiB, 32 LEBs), journal size 114278UBIFS (ubi0:3): recovery completed
- 5 bytes (1 MiB, UBIFS (ubi0:3): UBIFS: mounted UBI device 0, volume 3, name "appconfigs"
- 8 LEBs)
- Jan 1 UBIFS (ubi0:3): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
- UBIFS (ubi0:3): FS size: 4063232 bytes (3 MiB, 32 LEBs), journal size 1142785 bytes (1 MiB, 8 LEBs)
- 00:00:49 (none) UBIFS (ubi0:3): reserved for root: 0 bytes (0 KiB)
- UBIFS (ubi0:3): media format: w4/r0 (latest is w4/r0), UUID BD0D8465-3049-4C58-B3D8-C28C2CA31166, small LPT model
- user.notice kernel: UBIFS (ubi0:2): reserved for root: 0 bytes (0 KiB)
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:2): media format: w4/r0 (latest is w4/r0), UUID 4F45A52C-BEA3-4B54-8FB5-FB88C6C5A0D2, small LPT model
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:3): background thread "ubifs_bgt0_3" started, PID 635
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:3): recovery needed
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:3): recovery completed
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:3): UBIFS: mounted UBI device 0, volume 3, name "appconfigs"
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:3): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:3): FS size: 4063232 bytes (3 MiB, 32 LEBs), journal size 1142785 bytes (1 MiB, 8 LEBs)
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:3): reserved for root: 0 bytes (0 KiB)
- Jan 1 00:00:49 (none) user.notice kernel: UBIFS (ubi0:3): media format: w4/r0 (latest is w4/r0), UUID BD0D8465-3049-4C58-B3D8-C28C2CA31166, small LPT model
- -/bin/sh: /etc/init.d/set_eth1_mac.sh: not found
- telnetd: applet not found
- RPC: Registered named UNIX socket transport module.
- RPC: Registered udp transport module.
- RPC: Registered tcp transport module.
- RPC: Registered tcp NFSv4.1 backchannel transport module.
- Jan 1 00:00:49 (none) user.info kernel: RPC: Registered named UNIX socket transport module.
- Jan 1 00:00:49 (none) user.info kernel: RPC: Registered udp transport module.
- Jan 1 00:00:49 (none) user.info kernel: RPC: Registered tcp transport module.
- Jan 1 00:00:49 (none) user.info kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
- ntfs: driver 2.1.32 [Flags: R/O MODULE].
- insmod: can't insert '/config/modules/4.9.84/u***-common.ko': No such file or directory
- Jan 1 00:00:49 (none) user.info kernel: ntfs: driver 2.1.32 [Flags: R/Oehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
- ehci monitor start running
- Mstar_ehc_init version:20180309
- MODULE].
- insmoSstar-ehci-2 H.W init
- Titania3_series_start_ehc start
- [USB] config miu select [70] [e8] [ef] [ef]
- d: can't insert [USB] enable miu lower bound address subtraction
- [USB] init squelch level 0x2
- '/config/modules[USB] no platform_data, device tree coming
- [USB][EHC] dma coherent_mask 0xffffffffffffffff mask 0xffffffffffffffff
- BC disable
- [USB] soc:Sstar-ehci-2 irq --> 38
- Sstar-ehci-2 soc:Sstar-ehci-2: EHCI Host Controller
- Sstar-ehci-2 soc:Sstar-ehci-2: new USB bus registered, assigned bus number 1
- Sstar-ehci-2 soc:Sstar-ehci-2: irq 38, io mem 0xfd285000
- /4.9.84/u***core.u*** u***1: New USB device found, idVendor=1d6b, idProduct=0002
- ko': No such filu*** u***1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
- u*** u***1: Product: EHCI Host Controller
- u*** u***1: Manufacturer: Linux 4.9.84 ehci_hcd
- u*** u***1: SerialNumber: mstar
- hub 1-0:1.0: USB hub found
- hub 1-0:1.0: 1 port detected
- Sstar-ehci-1 H.W init
- e or directory
- [USB] enable miu lower bound address subtraction
- [USB] no platform_data, device tree coming
- insmod: can't in[USB][EHC] dma coherent_mask 0xffffffffffffffff mask 0xffffffffffffffff
- sert '/config/moBC disable
- [USB] soc:Sstar-ehci-1 irq --> 37
- Sstar-ehci-1 soc:Sstar-ehci-1: EHCI Host Controller
- dules/4.9.84/u***Sstar-ehci-1 soc:Sstar-ehci-1: new USB bus registered, assigned bus number 2
- Sstar-ehci-1 soc:Sstar-ehci-1: irq 37, io mem 0xfd284800
- hid.ko': No such file or directory
- u*** u***2: New USB device found, idVendor=1d6b, idProduct=0002
- u*** u***2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
- u*** u***2: Product: EHCI Host Controller
- u*** u***2: Manufacturer: Linux 4.9.84 ehci_hcd
- u*** u***2: SerialNumber: mstar
- hub 2-0:1.0: USB hub found
- hub 2-0:1.0: 1 port detected
- u***core: registered new interface driver u***-storage
- MSYS: DMEM request: [AESDMA_ENG]:0x00001000
- MSYS: DMEM request: [AESDMA_ENG]:0x00001000 success, CPU phy:@0x23C4A000, virt:@0xC3C4A000
- MSYS: DMEM request: [AESDMA_ENG1]:0x00001000
- MSYS: DMEM request: [AESDMA_ENG1]:0x00001000 success, CPU phy:@0x23C4B000, virt:@0xC3C4B000
- mhal: loading out-of-tree module taints kernel.
- mhal: module license 'PROPRIETARY' taints kernel.
- Disabling lock debugging due to kernel taint
- mhal driver init
- jpe driver probed
- DivpProcInit 515
- Jan 1 00:00:49 (none) user.info kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
- Jan 1 00:00:49 (none) user.info kernel: ehci monitor start running
- Jan 1 00:00:49 (none) user.err kernel: Mstar_ehc_init version:20180309
- Jan 1 00:00:49 (none) user.err kernel: Sstar-ehci-2 H.W init
- Jan 1 00:00:49 (none) user.err kernel: Titania3_series_start_ehc start
- Jan 1 00:00:49 (none) user.err kernel: [USB] config miu select [70] [e8] [ef] [ef]
- Jan 1 00:00:49 (none) user.err kernel: [USB] enable miu lower bound address subtraction
- Jan 1 00:00:49 (none) user.err kernel: [USB] init squelch level 0x2
- Jan 1 00:00:49 (none) user.warn kernel: [USB] no platform_data, device tree coming
- Jan 1 00:00:49 (none) user.notice kernel: [USB][EHC] dma coherent_mask 0xfmodule [sys] init
- fffffffffffffff MI_SYSCFG_SetupMmapLoader default_config_path:/config/config_tool, argv1:/config/load_mmap,argv2:/config/mmap.ini
- mask 0xffffffffffffffff
- Jan 1 00:00:49 (none) user.err kernel: BC disable
- Ja==20180309==> hub_port_init 1 #0
- Plug in USB Port1
- n 1 00:00:49 (none) user.info kernel: [USB] soc:Sstar-ehci-2 irq --> 38
- Jan 1 00:00:49 (none)Function = init_glob_miu_kranges, Line = 604, Insert KProtect for LX @ MIU: 0
- Function = init_glob_miu_kranges, Line = 613, [INIT] for LX0 kprotect: from 0x20000000 to 0x23F00000, using block 0
- user.info kerneconfig...... strPath:/config/config_tool, argv0:/config/load_config
- l: Sstar-ehci-2 soc:Sstar-ehci-2: EHCI Host Controller
- Jan 1 00:00:49 (none) ufunction:parese_Cmdline,pCmd_Section:0x3f00000
- mm
- a
- _
- h
- e
- a
- p
- _
- n
- a
- m
- e
- 0
- miu=0,sz=1a00000 reserved_start=21900000
- r_front->miuBlockIndex:0,r_front->start_cpu_bus_pa:0x20000000,r_front->start_cpu_bus_pa+r_front->length:0x21900000
- ser.info kernel:r_back->miuBlockIndex:1,r_back->start_cpu_bus_pa:0x23300000,r_back->start_cpu_bus_pa+r_back->length:0x23f00000
- Sstar-ehci-2 somi_sys_mma_allocator_create success, heap_base_addr=21900000 length=1a00000
- Kernel CONFIG_HZ = 100
- Sigmastar Module version: project_commit.866b490 sdk_commit.341badc build_time.20200714212826
- module [gfx] init
- c:Sstar-ehci-2: module [divp] init
- new USB bus registered, assigned bus number 1
- Jan 1 00:00:49 (none) user.debug kernel: cma: cma_alloc(cma c0488ef0, count 1, align 0)
- Jan 1 00:00:49 (none) user.debug kernel: cma: cma_alloc(): returned c3ef0880
- Jan 1 0module [vdec] init
- 0:00:49 (none) user.debug kernel: cma: cma_alloc(cma c0488ef0, count 1, align 0)
- Jan 1 00:00:49 (none) user.debug kernel: cma: cma_alloc(): returned c3ef08a0
- Jan 1 00:00:49 (none) user.debmodule [ao] init
- ug kernel: cma: cma_alloc(cma c0488ef0, count 1, align 0)
- Jan 1 00:00:49 (none) user.debug kernel: cma: cma_alloc(): returned c3ef08c0
- Jan 1 00:00:49 (none) user.info kernel: Sstar-ehci-2 soc:Sstar-ehci-2: irq 38, io memmodule [disp] init
- 0xfd285000
- Jan 1 00:00:49 (none) user.info kernel: u*** u***1: New USB device found, idVendor=1d6b, idProduct=0002
- Jan 1 00:0drv_ccif_cpu_init :c4580000
- 0:49 (none) userrequest_irq failed
- .info kernel: u*** u***1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
- Jan 1 00:00:49 (none) user.info kernel: u*** u***1: Product: EHCI Host Controller
- Jan 1 00:00:49 (none) user.info kernel: u***u*** 2-1: new high-speed USB device number 2 using Sstar-ehci-1
- module [ai] init
- u***1: Manufacturer: Linux 4.9.84 ehci_hcd
- Jan 1 00:00:49 (none) user.info kernel: u*** u***1: SerialNumber: mstar
- Jan 1 00:00:49 (none) user.info kernel: hub 1-0:1.0: USB hub found
- Jan 1 00:00:49 (none) user.info kernel: hub 1-0:1.0: 1module [venc] init Jul 14 2020 21:29:05
- port detected
- Jan 1 00:00:49 (none) user.err kernel: Sstar-ehci-1 H.W init
- Jan 1 00:00:49 (none) user.err kernel: Titania3_module [panel] init
- series_start_ehc start
- Jan[GOP]HalGopUpdateGwinParam 720: GOP_id=011 not support
- 1 00:00:49 (no[GOP]HalGopSetArgb1555Alpha 1208: GOPId=0x11 not support
- ne) user.warn ke[GOP]HalGopSetArgb1555Alpha 1208: GOPId=0x11 not support
- rnel: [USB] no platform_data, device tree coming
- Jan 1 00:00:49 (none) user.notice kernel: [USB][EHC] dma coherent_mask 0xffffffffffffffff mask 0xffffffffffffffff
- Jan 1 00:00:49 (none) user.info kernel: [USB] soc:Sstar-ehci-1 irq --> 37
- Jan 1 00:00:49 (none) user.info kernel: Sstar-ehci-1 soc:Sstar-ehci-1: EHCI Host Controller
- Jan 1 00:00:49 (none) user.info kernel: Sstar-ehci-1 soc:Sstar-ehci-1: new USB bus registered, assigned bus number 2
- Jan 1 00:00:49 (none) user.debug kernel: cma: cma_alloc(): returned c3ef08e0
- Jan 1 00:00:49 (none) user.debug kernel: cma: cma_alloc(): returned c3ef0900
- Jan 1 00:00:49 (none) user.debug kernel: cma: cma_alloc(): returned c3ef0920
- Jan 1 00:00:49 (none) user.info kernel: Sstar-ehci-1 soc:Sstar-ehci-1: irq 37, io mem 0xfd284800
- Jan 1 00:00:49 (none) user.info kernel: u*** u***2: New USB device found, idVendor=1d6b, idProduct=0002
- Jan 1 00:00:49 (none) user.info kernel: u*** u***2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
- Jan 1 00:00:49 (none) user.info kernel: u*** u***2: Product: EHCI Host Controller
- Jan 1 00:00:49 (none) user.info kernel: u*** u***2: Manufacturer: Linux 4.9.84 Jan 1 00:00:49 Jan 1 00:00:50 (none) user.err kernel: module [sys] init
- Jan 1 00:00:50 (none) user.err kernel: MI_SYSCFG_SetupMmapLoader default_config_path:/config/config_tool, argv1:/config/load_mmap,argv2:/config/mmap.ini
- Jan 1 00:00:50 (none) user.err kernel: ==20180309==> hub_port_init 1 #0
- Jan 1 00:00:50 (none) user.err kernel: Plug in USB Port1
- Jan 1 00:00:50 (none) user.err kernel: ^[[35mFunction = init_glob_miu_kranges, Line = 604, Insert KProtect for LX @ MIU: 0^[[m
- Jan 1 00:00:50 (none) user.err kernel: ^[[35mFunction = init_glob_miu_kranges, Line = 613, [INIT] for LX0 kprotect: from 0x20000000 to 0x23F00000, using block 0^[[m
- Jan 1 00:00:50 (none) user.err kernel: config...... strPath:/config/config_tool, argv0:/config/load_config
- Jan 1 00:00:50 (none) user.err kernel: function:parese_Cmdline,pCmd_Section:0x3fu*** 2-1: New USB device found, idVendor=1b20, idProduct=8888
- u*** 2-1: New USB device strings: Mfr=16, Product=32, SerialNumber=0
- 00000
- Jan 1 00u*** 2-1: Product: SigmaStarWIFI
- u*** 2-1: Manufacturer: SigmaStar inc
- :00:50 (none) user.err kernel: m
- Jan 1 00:00:50 (none) user.err kernel: m
- Jan 1 00:00:50 (nJan 1 00:00:50 Jan 1 00:00:50 (none) user.err kernel: module [vdec] init
- Jan 1 00:00:50 (none) user.err kernel: module [ao] init
- Jan 1 00:00:50 (none) user.err kernel: module [disp] init
- Jan 1 00:00:50 (none) user.err kernel: drv_ccif_cpu_init :c4580000
- Jan 1 00:00:50 (none) user.err kernel: request_irq failed
- Jan 1 00:00:50 (none) user.info kernel: u*** 2-1: new high-speed USB device number 2 using Sstar-ehci-1
- Jan 1 00:00:50 (none) user.err kernel: module [ai] init
- Jan 1 00:00:50 (none) user.err kernel: module [venc] init Jul 14 2020 21:29:05
- Jan 1 00:00:50 (none) user.err kernel: module [panel] init
- Jan 1 00:00:50 (none) user.debug kernel: [FB_DEVICE]
- Jan 1 00:00:50 (none) user.debug kernel: FB_HWLAYER_ID=1
- Jan 1 00:00:50 (none) user.debug kernel: FB_HWWIN_ID=0
- Jan 1 00:00:50 (none) user.debug kernel: FB_HWLAYER_DST=3
- Jan 1 00:00:50 (none) user.debug kernel: FB_HWWIN_FORMAT=5
- Jan 1 00:00:50 (none) user.debug kernel: FB_HWLAYER_OUTPUTCOLOR=1
- Jan 1 00:00:50 (none) user.debug kernel: FB_WIDTH=480
- Jan 1 00:00:50 (none) user.debug kernel: FB_HEIGHT=480
- Jan 1 00:00:50 (none) user.debug kernel: FB_TIMMING_WIDTH=1920
- Jan 1 00:00:50 (none) user.debug kernel: FB_TIMMING_HEIGHT=1080
- Jan 1 00:00:50 (none) user.debug kernel: FB_MMAP_NAME=E_MMAP_ID_FB
- Jan 1 00:00:50 (none) user.debug kernel: FB_BUFFER_LEN=4096
- Jan 1 00:00:50 (none) user.debug kernel: ^[[1;36m
- Jan 1 00:00:50 (none) user.debug kernel: Mstar frame buffer device,numFbHwlayer:1
- Jan 1 00:00:50 (none) user.debug kernel: ^[[0m
- Jan 1 00:00:50 (none) user.debug kernel: fb0 parse_hwLayerInfo can nJan 1 00:00:50 [1]+ Done(127) busybox telnetd
- / # Jan 1 00:00:50 (none) user.debug kernel: ^[[0m
- Jan 1 00:00:50 (none) user.info kernel: u*** 2-1: New USB device found, idVendor=1b20, idProduct=8888
- Jan 1 00:00:50 (none) user.info kernel: u*** 2-1: New USB device strings: Mfr=16, Product=32, SerialNumber=0
- Jan 1 00:00:50 (none) user.info kernel: u*** 2-1: Product: SigmaStarWIFI
- Jan 1 00:00:50 (none) user.info kernel: u*** 2-1: Manufacturer: SigmaStar inc
复制代码
下面截一些认为较为有用的信息,可以一起分享下
U-Boot信息:
网卡的MAC地址(后要确认一下具体是哪个)
Linux版本及CPU信息
USB信息
后面就可以多做一些测试和使用了!!!
