电子发烧友论坛|
首先下载 stlink 的 Linux 版本,下载地址。
然后解压到你指定的路径下,参照其中的 README 文件进行配置编译。 HOWTO ===== First, you have to know there are several boards supported by the software. Those boards use a chip to translate from USB to JTAG commands. The chip is called stlink and there are 2 versions: 。 STLINKv1, present on STM32VL discovery kits, 。 STLINKv2, present on STM32L discovery and later kits. 2 different transport layers are used: 。 STLINKv1 uses SCSI passthru commands over USB, 。 STLINKv2 uses raw USB commands. Common requirements(依赖环境) ~~~~~~~~~~~~~~~~~~~ 。 libu***-1.0 (You probably already have this, but you‘ll need the development version to compile) (这个工具只需要执行sudo apt-get install libu***-dev && sudo apt-get install libu***-1.0-0-dev这两个命令即可。) 。 pkg-config (这个工具一般Ubuntu都会默认安装,注意变量PKG-CONFIG-PATH的设置) IF YOU HAVE AN STLINKv1 ~~~~~~~~~~~~~~~~~~~~~~~ The STLINKv1’s SCSI emulation is very broken, so the best thing to do is tell your operating system to completely ignore it. Options (do one of these before you plug it in) *) modprobe -r u***-storage && modprobe u***-storage quirks=483:3744:i or *)1. add “options u***-storage quirks=483:3744:i” to /etc/modprobe.conf *)2. modprobe -r u***-storage && modprobe u***-storage or *)1. cp stlink_v1.modprobe.conf /etc/modprobe.d *)2. modprobe -r u***-storage && modprobe u***-storage IF YOU HAVE AN STLINKv2(我们的开发板支持STLINKv2,所以这里不做配置) ~~~~~~~~~~~~~~~~~~~~~~~ You‘re ready to go :) COMPILING(编译:下边3个指令即可) ~~~~~~~~~ This project was converted to Autotools by a well meaning individual. The following steps will build the project for you. $ 。/autogen.sh $ 。/configure $ make USING THE GDBSERVER(使用GDB调试服务) ~~~~~~~~~~~~~~~~~~~ To run the gdb server: (you do not need sudo if you have set up permissions correctly) (此时连上你的开发板,一般都要sudo) $ make && [sudo] 。/st-util There are a few options: 。/st-util - usage: -h, --help Print this help -vXX, --verbose=XX Specify a specific verbosity level (0..99) -v, --verbose Specify generally verbose logging -s X, --stlink_version=X Choose what version of stlink to use, (defaults to 2) -1, --stlinkv1 Force stlink version 1 -p 4242, --listen_port=1234 Set the gdb server listen port. (default port: 4242) -m, --multi Set gdb server to extended mode. st-util will continue listening for connections after disconnect. -n, --no-reset Do not reset board on connection. The STLINKv2 device to use can be specified in the environment variable STLINK_DEVICE on the format 《USB_BUS》:《USB_ADDR》。 Then, in your project directory, someting like this.。. (remember, you need to run an _ARM_ gdb, not an x86 gdb) (重新打开一个终端,找到你编译好的应用程序的目录,就是存在elf文件的地方) $ arm-none-eabi-gdb fancyblink.elf (开启调试) 。.. (gdb) tar extended-remote :4242 (连上GDB服务) 。.. (gdb) load Loading section .text, size 0x458 lma 0x8000000 Loading section .data, size 0x8 lma 0x8000458 Start address 0x80001c1, load size 1120 Transfer rate: 1 KB/sec, 560 bytes/write. (gdb) 。.. (gdb) continue Have fun! Resetting the chip from GDB =========================== You may reset the chip using GDB if you want. You’ll need to use `target extended-remote‘ command like in this session: (gdb) target extended-remote localhost:4242 Remote debugging using localhost:4242 0x080007a8 in _startup () (gdb) kill Kill the program being debugged? (y or n) y (gdb) run Starting program: /home/whitequark/ST/apps/bally/firmware.elf Remember that you can shorten the commands. `tar ext :4242’ is good enough for GDB. Setting up udev rules ===================== For convenience, you may install udev rules file, 49-stlinkv*.rules, located in the root of repository. You will need to copy it to /etc/udev/rules.d, and then either reboot or execute $ udevadm control --reload-rules $ udevadm trigger Udev will now create a /dev/stlinkv2_XX or /dev/stlinkv1_XX file, with the appropriate permissions. This is currently all the device is for, (only one stlink of each version is supported at any time presently) Running programs from SRAM(在RAM上运行) ========================== You can run your firmware directly from SRAM if you want to. Just link it at 0x20000000 and do (gdb) load firmware.elf It will be loaded, and pc will be adjusted to point to start of the code, if it is linked correctly (i.e. ELF has correct entry point)。 Writing to flash(烧写Flash) ================ The GDB stub ships with a correct memory map, including the flash area. If you would link your executable to 0x08000000 and then do (gdb) load firmware.elf then it would be written to the memory. FAQ === Q: My breakpoints do not work at all or only work once. A: Optimizations can cause severe instruction reordering. For example, if you are doing something like `REG = 0x100;‘ in a loop, the code may be split into two parts: loading 0x100 into some intermediate register and moving that value to REG. When you set up a breakpoint, GDB will hook to the first instruction, which may be called only once if there are enough unused registers. In my experience, -O3 causes that frequently. Q: At some point I use GDB command `next’, and it hangs. A: Sometimes when you will try to use GDB `next‘ command to skip a loop, it will use a rather inefficient single-stepping way of doing that. Set up a breakpoint manually in that case and do `continue’。 Currently known working combinations of programmer and target ============================================================= STLink v1 (as found on the 32VL Discovery board) Known Working Targets: * STM32F100xx (Medium Density VL) * STM32F103 (according to jpa- on ##stm32) No information: * everything else! STLink v2 (as found on the 32L and F4 Discovery boards) Known Working Targets: * STM32F0Discovery (STM32F0 Discovery board) * STM32F100xx (Medium Density VL, as on the 32VL Discovery board) * STM32L1xx (STM32L Discovery board) * STM32F103VC, STM32F107RC, STM32L151RB, STM32F205RE and STM32F405RE on custom boards (https://github.com/UweBonnes/wiki_fuer_alex/layout/usps.。.) * STM32F303xx (STM32F3 Discovery board) * STM32F407xx (STM32F4 Discovery board) * STM32F429I-DISCO (STM32F4 Discovery board with LCD) * STM32F439VIT6 (discovery board reseated CPU) * STM32L151CB (custom board) * STM32L152RB (STM32L-Discovery board, custom board) STLink v2-1 (as found on the Nucleo boards) Known Working Targets: * STM32F401xx (STM32 Nucleo-F401RE board) Please report any and all known working combinations so I can update this! 按照上边步骤的配置,就可以调试和下载应用程序。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1894浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1976浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2165浏览 3评论
/9
GMT+8, 2025-12-2 01:41 , Processed in 0.831911 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2363
