电子发烧友论坛|
最近调试STM32的串口接收时发现例程中只能接收一个字节
例程如下: 1 //初始化串口1 2 void uart_init(u32 bound){ 3 //GPIO端口设置 4 GPIO_InitTypeDef GPIO_InitStructure; 5 USART_InitTypeDef USART_InitStructure; 6 NVIC_InitTypeDef NVIC_InitStructure; 7 8 RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA, ENABLE); //使能USART1,GPIOA时钟 9 USART_DeInit(USART1); //复位串口1 10 //USART1_TX PA.9 11 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9 12 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; 13 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 14 GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化PA9 15 16 //USART1_RX PA.10 17 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; 18 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入 19 GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化PA10 20 21 //Usart1 NVIC 配置 22 23 NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; 24 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//抢占优先级3 25 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //子优先级3 26 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能 27 NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器 28 29 //USART 初始化设置 30 31 USART_InitStructure.USART_BaudRate = bound;//一般设置为9600; 32 USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式 33 USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位 34 USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位 35 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制 36 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式 37 38 USART_Init(USART1, &USART_InitStructure); //初始化串口 39 USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启中断 40 USART_Cmd(USART1, ENABLE); //使能串口 41 42 } 43 void USART1_IRQHandler(void) //串口1中断服务程序 44 { 45 u8 Res; 46 if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) //接收中断(接收到的数据必须是0x0d 0x0a结尾) 47 { 48 //USART_ClearITPendingBit(USART1,USART_IT_RXNE); 49 Res =USART_ReceiveData(USART1);//(USART1-》DR); //读取接收到的数据 50 USART_RX_BUF[buf_index++]=Res; 51 52 } 53 54 } 这是较为普遍的源码例程的写法,用原子的版本改的。这本身没问题,但是,一旦运行,就会发现,只能接收一个字节,后面的都会丢失,调了1天没找到原因,一搜索发现很多类似的情况。 后来正准备改用DMA时偶然找到问题所在,就是这句: 24 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//抢占优先级3 25 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //子优先级3 改为 24 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=1 ; 25 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; 后问题解决。 注意,不要在中断中执行发送接收过程,存在中断嵌套的问题,会造成只执行一次的现象。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4182 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3252 浏览 1 评论
2782 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2214 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
15087 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3143浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1929浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2097浏览 3评论
2009浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2203浏览 3评论
/9
GMT+8, 2025-12-10 03:44 , Processed in 0.530959 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2993
