仿真电路图:
仿真实验结果: C语言程序代码: //------------------------------------------------*/ #include #include ***it RS = P2^4; //定义端口 ***it RW = P2^5; ***it EN = P2^6; #define RS_CLR RS=0 #define RS_SET RS=1 #define RW_CLR RW=0 #define RW_SET RW=1 #define EN_CLR EN=0 #define EN_SET EN=1 #define DataPort P0 /*------------------------------------------------ uS延时函数,含有输入参数 unsigned char t,无返回值 unsigned char 是定义无符号字符变量,其值的范围是 0~255 这里使用晶振12M,精确延时请使用汇编,大致延时 长度如下 T=tx2+5 uS ------------------------------------------------*/ void DelayUs2x(unsigned char t) { while(--t); } /*------------------------------------------------ mS延时函数,含有输入参数 unsigned char t,无返回值 unsigned char 是定义无符号字符变量,其值的范围是 0~255 这里使用晶振12M,精确延时请使用汇编 ------------------------------------------------*/ void DelayMs(unsigned char t) { while(t--) { //大致延时1mS DelayUs2x(245); DelayUs2x(245); } } /*------------------------------------------------ 判忙函数 ------------------------------------------------*/ bit LCD_Check_Busy(void) { DataPort= 0xFF; RS_CLR; RW_SET; EN_CLR; _nop_(); EN_SET; return (bit)(DataPort & 0x80); } /*------------------------------------------------ 写入命令函数 ------------------------------------------------*/ void LCD_Write_Com(unsigned char com) { // while(LCD_Check_Busy()); //忙则等待 DelayMs(5); RS_CLR; RW_CLR; EN_SET; DataPort= com; _nop_(); EN_CLR; } /*------------------------------------------------ 写入数据函数 ------------------------------------------------*/ void LCD_Write_Data(unsigned char Data) { //while(LCD_Check_Busy()); //忙则等待 DelayMs(5); RS_SET; RW_CLR; EN_SET; DataPort= Data; _nop_(); EN_CLR; } /*------------------------------------------------ 清屏函数 ------------------------------------------------*/ void LCD_Clear(void) { LCD_Write_Com(0x01); DelayMs(5); } /*------------------------------------------------ 写入字符串函数 ------------------------------------------------*/ void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s) { if (y == 0) { LCD_Write_Com(0x80 + x); //表示第一行 } else { LCD_Write_Com(0xC0 + x); //表示第二行 } while (*s) { LCD_Write_Data( *s); s ++; } } /*------------------------------------------------ 写入字符函数 ------------------------------------------------*/ void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data) { if (y == 0) { LCD_Write_Com(0x80 + x); } else { LCD_Write_Com(0xC0 + x); } LCD_Write_Data( Data); } /*------------------------------------------------ 初始化函数 ------------------------------------------------*/ void LCD_Init(void) { LCD_Write_Com(0x38); /*显示模式设置*/ DelayMs(5); LCD_Write_Com(0x38); DelayMs(5); LCD_Write_Com(0x38); DelayMs(5); LCD_Write_Com(0x38); LCD_Write_Com(0x08); /*显示关闭*/ LCD_Write_Com(0x01); /*显示清屏*/ LCD_Write_Com(0x06); /*显示光标移动设置*/ DelayMs(5); LCD_Write_Com(0x0C); /*显示开及光标设置*/ } /*------------------------------------------------ 主函数[上面已经把显示功能封装好了,今后再写其他显示就直接调用] ------------------------------------------------*/ void main(void) { unsigned char i; unsigned char *p; LCD_Init();//初始化 while(1) { i=1; p="Xian of China"; LCD_Clear();//清屏 LCD_Write_String(2,0,"Welcome to"); DelayMs(250); while(*p) { LCD_Write_Char(i,1,*p); i++;//位置移动一个 p++;//字符串移动一个 DelayMs(250); } DelayMs(250); } } |
只有小组成员才能发言,加入小组>>
2186 浏览 0 评论
1168浏览 3评论
645浏览 2评论
[求助]atmega1280与atmega2560在程序上有什么区别?
2253浏览 1评论
330浏览 1评论
1194浏览 0评论
GMT+8, 2024-4-27 16:14 , Processed in 1.062592 second(s), Total 75, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
