我用的是赛元的SC92F7422单片机,设置了两个通道进行ADC读取,现在的问题是单独进行输入电压显示时可以正常读取并显示出数值,但是同时开的时候数值就以叠加的形式显示出来了
代码如下: #include "Function_Init.H" #include "SC92F742x_C.H" #include "intrins.H" #include unsigned long ADCValue; unsigned short i,b,a=0,u=0; bit AdcFlag = 0; unsigned short J,K; unsigned char times_delay = 0,adc_delay=0,s_delay=0; //#define LED2 P25 ***it TL=P1^3; ***it WP=P1^0; #define N 1000 int TempAdd=0; uint value=0,step=0; unsigned int t1 = 0; unsigned int t2 = 0; unsigned int t3 = 0; unsigned int t4 = 0; unsigned int t5 = 0; unsigned int t6 = 0; unsigned int t7 = 0; unsigned int t8 = 0; unsigned int t9 = 0; unsigned int t10 = 0; unsigned int t11 = 0; unsigned int s0 = 0; unsigned int s1 = 0; unsigned int s3 = 0; unsigned int s4 = 0; unsigned int cnt1; unsigned int cnt2; unsigned int cnt3; unsigned int cnt4; unsigned int cnt5; unsigned int cnt6; unsigned int cnt7; unsigned int cnt8; unsigned int cnt9; unsigned int cnt10; unsigned int cnt11; unsigned long ADC_Value1,ADC_Value2; unsigned long sum; void Delay(uint time) { uint c = 0; for(c=0; c<100; c++) for(; time>0; time--) ; } void IO_Init(void) { P0CON=0X3f;//0011 1111 P0PH=0X00; P1CON = 0x84; //设置P1.7为强推挽模式//1000 1000 P1PH = 0x00;//0000 0000 P2CON = 0xD3; //设置P2为强推挽模式 P2PH = 0x00; } void Timer_Init(void) { TMCON = 0X01; // ;Timer0选择时钟Fsys //T0设置 TMOD |= 0x01; //0000 0001;Timer0设置工作方式1 TL0 = (65536 - 1200)%256; //溢出时间:时钟为Fsys,则12000*(1/Fsys)=1ms; 12MHz TH0 = (65536 - 1200)/256; TR0 = 0; ET0 = 1;//定时器0允许 TR0 = 1;//打开定时器0 EA = 1; } //void ADC_Init(void) //{ // ADCCON |= 0X80; //开启ADC,ADC采样频率为2M ,选择AIN9位ADC采样口 //// ADCVH=0; //// ADCVL=0;//清除数据 //// // ADCCON&= ~(0X10); //清中断标志位 // //IE |= 0X40; //允许ADC产生中断 //// EA = 1; //} unsigned long Voltage() { unsigned long L,M; if(adc_delay>2) { ADCCON|=0X40; if(!(ADCCON&0x10)==0) { ADCCON&= ~(0X10); //清中断标志位 } ADCValue =((ADCVH<<4)|(ADCVL>>4));//0000 1111 1111 1111 M=(M*N+ADCValue*(1024-N))/1024; adc_delay=0; } L=M/3; //if(L>99){L=99;} return L; } void ADC_channel(unsigned char channel) { ADCCON = ADCCON&0x80 | channel; //ADC 输入选择为 ADCchannel 口 } void ADC_Multichannel() { ADCCON |= 0X80; ADCCFG0=0x20; ADCCFG1=0X02;//ain9为adc输入,移除上拉电阻 ADC_channel(5); //ADC 入口切换至 AIN5 口 Delay(50); ADC_Value1 = Voltage(); //启动 ADC 转换,获得转换值 //ADC_Value1=8; ADC_channel(9); //ADC 入口切换至 AIN9 口 Delay(50); ADC_Value2 =Voltage(); //启动 ADC 转换,获得转换值 } unsigned int kaiguan(void) { if (TL==1) { value|=(1<<0);//1 } else { value&=~(1<<0);//0 } if (WP==1) { value|=(1<<1);//2 } else { value&=~(1<<1);//0 } return value; } void dlLCD(unsigned int data1,unsigned long data2) { unsigned short c=0; if((data2==-1)||(data2==-2)) { c=data2; data2*=-1; } t6=1; s0 = data1 &(1<<0);//1是off,0是on s1 = data1 &(1<<1); switch(s0) //激光 { case 0:t1= 1;t5=3;t10=0;break; case 1:t1=0;t5=1;t10=1;break; } switch(s1) //水保护 { case 0:t11 = 1;break; case 2:t11 = 2;t5=1;break; } s3=data2/10;//左边数字 s4=data2%10;//右边数字 if((c==-1)||(c==-2)) { s3=10; } switch(s3) { case 0:t7=3;t8=2;t9=3;t10=2;break; case 1:t7=1;t8=0;t9=1;break; case 2:t7=3;t8=1;t9=2;t10=2;break; case 3:t7=3;t8=1;t9=1;t10=2;break; case 4:t7=1;t8=3;t9=1;break; case 5:t7=2;t8=3;t9=1;t10=2;break; case 6:t7=2;t8=3;t9=3;t10=2;break; case 7:t7=3;t8=0;t9=1;break; case 8:t7=3;t8=3;t9=3;t10=2;break; case 9:t7=3;t8=3;t9=1;t10=2;break; case 10:t7=0;t8=1;t9=0;break; } // if((s0==1)&(s3==0)==1){t10=3;} if((s0==0)&(s3==0)|(s3==2)|(s3==3)|(s3==5)|(s3==6)|(s3==8)|(s3==9)==1){t10=2;} if((s0==1)&(s3==0)==1){t10=3;} if((s0==1)&(s3==2)==1){t10=3;} if((s0==1)&(s3==3)==1){t10=3;} if((s0==1)&(s3==5)==1){t10=3;} if((s0==1)&(s3==6)==1){t10=3;} if((s0==1)&(s3==8)==1){t10=3;} if((s0==1)&(s3==9)==1){t10=3;} if((s3==4)&(s0==0)==1){t10=0;} if((s3==7)&(s0==0)==1){t10=0;} if((s3==1)&(s0==0)==1){t10=0;} switch(s4) { case 0:t2=3;t3=2;t4=3;t6=3;break; case 1:t2=1;t3=0;t4=1;break; case 2:t2=3;t3=1;t4=2;t6=3;break; case 3:t2=3;t3=1;t4=1;t6=3;break; case 4:t2=1;t3=3;t4=1;break; case 5:t2=2;t3=3;t4=1;t6=3;break; case 6:t2=2;t3=3;t4=3;t6=3;break; case 7:t2=3;t3=0;t4=1;break; case 8:t2=3;t3=3;t4=3;t6=3;break; case 9:t2=3;t3=3;t4=1;t6=3;break; } switch(step) { case 0: if (times_delay<45) { break; } times_delay=0; ///////////////////////////////////////////////////////////// P01=1; P0VO = 0X01;//P01(com1)先高电平,P0=1/2vdd switch(t1) { case 0:P02 = 1; cnt1 = 1;break; // case 1:P02 = 1; cnt1 = 2;break; // case 2:P02 = 0; cnt1 = 2;break; // case 3:P02 = 0; cnt1 = 1;break; // default:break; } switch(t2) { case 0:P03 = 1; cnt2 = 1;break; // case 1:P03 = 1; cnt2 = 2;break; // case 2:P03 = 0; cnt2 = 2;break; // case 3:P03 = 0; cnt2 = 1;break; // default:break; } switch(t3) { case 0:P04 = 1; cnt3 = 1;break; // case 1:P04 = 1; cnt3 = 2;break; // case 2:P04 = 0; cnt3 = 2;break; // case 3:P04 = 0; cnt3 = 1;break; // default:break; } switch(t4) { case 0:P05 = 1; cnt4 = 1;break; // case 1:P05 = 1; cnt4 = 2;break; // case 2:P05 = 0; cnt4 = 2;break; // case 3:P05 = 0; cnt4 = 1;break; // default:break; } switch(t5) { case 0:P17 = 1; cnt5 = 1;break; // case 1:P17 = 1; cnt5 = 2;break; // case 2:P17 = 0; cnt5 = 2;break; // case 3:P17 = 0; cnt5 = 1;break; // default:break; } switch(t6) { case 0:P20 = 1; cnt6 = 1;break; // case 1:P20 = 1; cnt6 = 2;break; // case 2:P20 = 0; cnt6 = 2;break; // case 3:P20 = 0; cnt6 = 1;break; // default:break; } switch(t7) { case 0:P21 = 1; cnt7 = 1;break; // case 1:P21 = 1; cnt7 = 2;break; // case 2:P21 = 0; cnt7 = 2;break; // case 3:P21 = 0; cnt7 = 1;break; // default:break; } switch(t8) { case 0:P24 = 1; cnt8 = 1;break; // case 1:P24 = 1; cnt8 = 2;break; // case 2:P24 = 0; cnt8 = 2;break; // case 3:P24 = 0; cnt8 = 1;break; // default:break; } switch(t9) { case 0:P12 = 1; cnt9 = 1;break; // case 1:P12 = 1; cnt9 = 2;break; // case 2:P12 = 0; cnt9 = 2;break; // case 3:P12 = 0; cnt9 = 1;break; // default:break; } switch(t10) { case 0:P26 = 1; cnt10 = 1;break; // case 1:P26 = 1; cnt10 = 2;break; // case 2:P26 = 0; cnt10 = 2;break; // case 3:P26 = 0; cnt10 = 1;break; // default:break; } switch(t11) { case 0:P27 = 1; cnt11 = 1;break; // case 1:P27 = 1; cnt11 = 2;break; // case 2:P27 = 0; cnt11 = 2;break; // case 3:P27 = 0; cnt11 = 1;break; // default:break; } step=1; break; case 1: if (times_delay<45) { break; } times_delay=0; ///////////////////////////////////////////////////////////////// // times_delay = 0; P00=0;//po低电平,P1=1/2vdd P0VO = 0X02; cnt1 -- ;if (cnt1 == 0){P02=~P02;cnt1 =2;} cnt2 -- ;if (cnt2 == 0){P03=~P03;cnt2 =2;} cnt3 -- ;if (cnt3 == 0){P04=~P04;cnt3 =2;} cnt4 -- ;if (cnt4 == 0){P05=~P05;cnt4 =2;} cnt5 -- ;if (cnt5 == 0){P17=~P17;cnt5 =2;} cnt6 -- ;if (cnt6 == 0){P20=~P20;cnt6 =2;} cnt7 -- ;if (cnt7 == 0){P21=~P21;cnt7 =2;} cnt8 -- ;if (cnt8 == 0){P24=~P24;cnt8 =2;} cnt9 -- ;if (cnt9 == 0){P12=~P12;cnt9 =2;} cnt10 -- ;if (cnt10 == 0){P26=~P26;cnt10 =2;} cnt11 -- ;if (cnt11 == 0){P27=~P27;cnt11 =2;} step=2; break; ///////////////////////////////////////////////////////////////// case 2: if (times_delay<45) { break; } times_delay=0; P01=0; P0VO = 0X01;//P0=1/2vdd,P1低电平 cnt1 -- ;if (cnt1 == 0){P02=~P02;cnt1 =2;} cnt2 -- ;if (cnt2 == 0){P03=~P03;cnt2 =2;} cnt3 -- ;if (cnt3 == 0){P04=~P04;cnt3 =2;} cnt4 -- ;if (cnt4 == 0){P05=~P05;cnt4 =2;} cnt5 -- ;if (cnt5 == 0){P17=~P17;cnt5 =2;} cnt6 -- ;if (cnt6 == 0){P20=~P20;cnt6 =2;} cnt7 -- ;if (cnt7 == 0){P21=~P21;cnt7 =2;} cnt8 -- ;if (cnt8 == 0){P24=~P24;cnt8 =2;} cnt9 -- ;if (cnt9 == 0){P12=~P12;cnt9 =2;} cnt10 -- ;if (cnt10 == 0){P26=~P26;cnt10 =2;} cnt11 -- ;if (cnt11 == 0){P27=~P27;cnt11 =2;} step=3; break; //////////////////////////////////////////////////////////////////// case 3: if (times_delay<45) { break; } times_delay = 0; P00=1;// P0VO = 0X02;//po高电平,P1=1/2vdd cnt1 -- ;if (cnt1 == 0){P02=~P02;cnt1 =2;} cnt2 -- ;if (cnt2 == 0){P03=~P03;cnt2 =2;} cnt3 -- ;if (cnt3 == 0){P04=~P04;cnt3 =2;} cnt4 -- ;if (cnt4 == 0){P05=~P05;cnt4 =2;} cnt5 -- ;if (cnt5 == 0){P17=~P17;cnt5 =2;} cnt6 -- ;if (cnt6 == 0){P20=~P20;cnt6 =2;} cnt7 -- ;if (cnt7 == 0){P21=~P21;cnt7 =2;} cnt8 -- ;if (cnt8 == 0){P24=~P24;cnt8 =2;} cnt9 -- ;if (cnt9 == 0){P12=~P12;cnt9 =2;} cnt10 -- ;if (cnt10 == 0){P26=~P26;cnt10 =2;} cnt11 -- ;if (cnt11 == 0){P27=~P27;cnt11 =2;} step=0; break; default: break; /////////////////////////////////////////////////////////////////////////// } } void main(void) { IO_Init(); Timer_Init(); // ADC_channel( ); while(1) { kaiguan(); Voltage(); ADC_Multichannel(); // ADC_Multichannel2(); if(u==0) { dlLCD(value,ADC_Value2); u=1; Delay(800); } else if(u==1) { dlLCD(value,ADC_Value1); u=0; Delay(800); } } } void timer0() interrupt 1 { TL0 = (65536 - 1200)%256; TH0 = (65536 - 1200)/256; times_delay++; adc_delay++; s_delay++; } |
1个回答
把ADC读取那段程序先关了吧,就留个显示程序
4 条评论
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
506 浏览 0 评论
607 浏览 0 评论
837 浏览 0 评论
832 浏览 0 评论
RT-Thread与英飞凌(infineon)合作得板子PSOC 6 板子学习
768 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
17058 浏览 31 评论
/9
GMT+8, 2025-12-14 07:56 , Processed in 0.615069 second(s), Total 79, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6084
