电子发烧友论坛|
78M6631 3相功率测量和监测SoC
The Teridian™ 78M6631 is a highly integrated 3-phase power measurement and monitoring system-on-chip (SoC), with a 10MHz 8051-compatible MPU core and Single Converter Technology® containing a 22-bit deltasigma converter and 32-bit compute engine (CE). The 78M6631 has been designed specifically for a wide variety of applications requiring 3-phase power and quality measurements. It supports both Delta and Wye configurations. At the measurement interface, the device provides six analog inputs including three differential current and three voltage for interfacing to current and voltage sensors. The device provides better than 0.5% accuracy over a wide 2000:1 dynamic range. The integrated MPU core and 128 KB of flash memory provide a flexible means of configuration, postprocessing, data formatting, interfacing to host processor via a UART or SPI interface, or using DIO pins for LEDs or relay control. Complete firmware is available from Maxim and can be loaded into the IC during manufacturing test. 78M6631 关键特性 < 0.5% Watt Accuracy Over 2000:1 Current Range and Over Temperature Exceeds IEC 62053/ANSI C12.20 Standards Voltage Reference < 40 ppm/°C Six Analog Inputs Supporting 3-Phase Voltage and Current Measurement Inputs Pin- or Bi-Selectable Delta or Wye Configuration 22-Bit Delta-Sigma ADC with Independent 32-Bit Compute Engine (CE) 8-Bit MPU (80515), One Clock Cycle per Instruction with 4KB MPU XRAM 128KB Flash with Security 32kHz Time Base with Hardware Watchdog Timer UART, I²C, and High-Speed Slave SPI Host Interface Options 17 General-Purpose 5V Tolerant I/O Pins Packaged in a RoHS-Compliant (6/6) Lead-Free 56-Pin TQFN Application Firmware Includes (per Phase): True RMS Current and Voltage Calculations Active, Reactive, Apparent, Fundamental, and HARMonic Power Calculations Fundamental and Harmonic Current and Voltage Calculations Line Frequency and Power Factor Calculations Phase Compensation (±18° at 60Hz) Built-In Calibration Routines Programmable Alarm Thresholds Command Line (UART) Communications High-Speed SPI Communications 78M6631应用/使用 楼宇自动化 数据中心、电信设备、存储设备电源和电源分配单元 电机诊断 太阳能逆变器 |
只有小组成员才能发言,加入小组>>
162个成员聚集在这个小组
加入小组1878 浏览 2 评论
2851 浏览 0 评论
1878浏览 2评论
请问MAX9291MAX9288上电后,i2c通信不通的原因?
1012浏览 1评论
4410浏览 1评论
654浏览 1评论
791浏览 1评论
/9
GMT+8, 2025-12-8 08:49 , Processed in 0.852039 second(s), Total 47, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2571
