电子发烧友论坛|
二级菜单的建立
在本例中,二级菜单只涉及到价格属性,因此,我们只需要在原先定义的节点中添加价格变量price, 同时每一项菜单原先只有一个指针域,指向下一项菜单。如果我们再添加一个指针域,让他指向下一级菜单(即第二级菜单的头部),那么,我们就完成了二级菜单的建立。 其中,next_Menu指向下一级菜单,link指向下一项菜单(同级)。 typedef struct Menus* Menu; struct Menus { unsigned char* name; //Menu name unsigned char position;//name of positon unsigned int font_num;//number of name float price; unsigned char function_mode;//Menu function 0:self check 1:Cal 2:Add 3:。。. unsigned char price_mode; Menu next_Menu;//the second Menu Menu link; //the next Menu }; 这时,我们需要新的添加节点函数,因为原先的添加节点函数变量初始化是基于第一级菜单的。 注意:根据你的需要,你需要自定义你的数据域! unsigned char *Menu_price_name[]={(unsigned char *)“1.5”,(unsigned char *)“2.5”,(unsigned char *)“3.5”,(unsigned char *)“4.5”,(unsigned char *)“5.5”,(unsigned char *)“6.5”}; //price of Menu unsigned char Menu_price_num[]={1.5 , 2.5 , 3.5 , 4.5 , 5.5 , 6.5}; unsigned int price_font_num[]={3,3,3,3,3,3}; //number of Menu Menu Attach_Menu_Price(Menu* pRear,int i,int mode) { Menu P; P = (Menu)malloc(sizeof(struct Menus)); P-》link = NULL; P-》next_Menu=NULL; P-》name = Menu_price_name; P-》font_num= price_font_num; P-》price=Menu_price_num; P-》function_mode=mode; P-》price_mode=1; (*pRear)-》link = P; *pRear = P; return P; } 我们还需要新的二级菜单初始化程序,暂定为价格菜单初始化程序,其原理是在当前节点的next_Menu创建一个新的菜单(循环链表)。 void Menu_Price_Init(Menu price,int mode) { Menu Start, Rear, t, End; int num; num= sizeof(Menu_price_num)/ sizeof(Menu_price_num[0]); Start = (Menu)malloc(sizeof(struct Menus)); Start-》link = NULL; Rear = Start; for (int i = 0; i 《 num-1; ++i) { Attach_Menu_Price(&Rear, i,mode); } End= Attach_Menu_Price(&Rear, num-1,mode); t = Start; Start = Start-》link; free(t); End-》link = Start; price-》next_Menu=Start; } 那么,我们还需要在一级菜单的初始化程序中,修改一下,添加一个if判断在哪项菜单添加二级菜单: Menu Menu_Init(void) { Menu Start, Rear, t, End; int num=5; num= sizeof(Menu_name)/ sizeof(Menu_name[0]); Start = (Menu)malloc(sizeof(struct Menus)); Start-》link = NULL; Rear = Start; for (int i = 0; i 《 num-1; i++) { Attach_Menu(&Rear, i); if (! strcmp((const char *)Rear-》name,“Cal_Price”)||! strcmp((const char *)Rear-》name,“Add_Price”)) { Menu_Price_Init(Rear,i); } } End= Attach_Menu(&Rear, num-1); t = Start; Start = Start-》link; free(t); End-》link = Start; return Start; } 至此,一个完整的二级菜单创建完毕,如果需要三级菜单,则需要在二级菜单的初始化程序中,假如if判断,步骤同二级菜单建立过程一样。 那么,在按键菜单功能中,如何进行菜单的选择呢? 如果按键为菜单、选择、确认。 我们需要定义两个Menu全局变量,第一个为Start,第二个为pRear,Start指向的菜单的第一项,pRear 指向的是当前选择的菜单,默认为第一项。 通过按键中断,如果是Select可以移动pRear移动到当前指向菜单的下一项(pRear=pRear-》link),pRear指向哪一项,就执行pRear所指的菜单的功能函数。当需要重新选择功能时(即再次进入菜单时,将pRear复位,令pRear=Start即可),令pRear指向开头的节点即可。如果是确认按键,先判断当前所指菜单是否有子菜单,如果有,进入子菜单,如果没有,再执行相应的函数即可。 注意:(再用按键中断进行菜单选择时,加入按键防抖程序处理效果会更好!) |
只有小组成员才能发言,加入小组>>
3038 浏览 0 评论
800浏览 1评论
1048浏览 0评论
823浏览 0评论
1005浏览 0评论
/9
GMT+8, 2025-12-2 13:42 , Processed in 0.736634 second(s), Total 74, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1539
