#include
#include typedef unsigned char uchar; typedef unsigned char uint; //****************************************NRF24L01端口定义*************************************** ***it MISO =P1^6; //nRF24L01引脚定义 ***it MOSI =P1^5; ***it SCK =P1^7; ***it CE =P1^2; ***it CSN =P1^3; ***it IRQ =P1^4; //************************************按键*************************************************** ***it KEY1=P3^5; ***it KEY2=P3^4; //************************************数码管位选********************************************* ***it led3=P2^0; ***it led2=P2^1; ***it led1=P2^2; ***it led0=P2^3; ***it le1=P1^0; ***it le2=P1^1; //************************************蜂明器*************************************************** ***it BELL=P3^6; int n; uchar num; //***********************************数码管0-9编码******************************************* uchar seg[10]={0xC0,0xCF,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90}; //0~~9段码 uchar seg1[10]={0x40,0x4F,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10}; //0~~9段码 char temp[6]; uchar RxBuf[20]={0}; //*********************************************NRF24L01************************************* #define TX_ADR_WIDTH 5 // 5 uints TX address width #define RX_ADR_WIDTH 5 // 5 uints RX address width #define TX_PLOAD_WIDTH 20 // 20 uints TX payload #define RX_PLOAD_WIDTH 20 // 20 uints TX payload uint const TX_ADDRESS[TX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //本地地址 uint const RX_ADDRESS[RX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //接收地址 //***************************************NRF24L01寄存器指令******************************************************* #define READ_REG 0x00 // 读寄存器指令 #define WRITE_REG 0x20 // 写寄存器指令 #define RD_RX_PLOAD 0x61 // 读取接收数据指令 #define WR_TX_PLOAD 0xA0 // 写待发数据指令 #define FLUSH_TX 0xE1 // 冲洗发送 FIFO指令 #define FLUSH_RX 0xE2 // 冲洗接收 FIFO指令 #define REUSE_TX_PL 0xE3 // 定义重复装载数据指令 #define NOP 0xFF // 保留 //*************************************SPI(nRF24L01)寄存器地址**************************************************** #define CONFIG 0x00 // 配置收发状态,CRC校验模式以及收发状态响应方式 #define EN_AA 0x01 // 自动应答功能设置 #define EN_RXADDR 0x02 // 可用信道设置 #define SETUP_AW 0x03 // 收发地址宽度设置 #define SETUP_RETR 0x04 // 自动重发功能设置 #define RF_CH 0x05 // 工作频率设置 #define RF_SETUP 0x06 // 发射速率、功耗功能设置 #define STATUS 0x07 // 状态寄存器 #define OBSERVE_TX 0x08 // 发送监测功能 #define CD 0x09 // 地址检测 #define RX_ADDR_P0 0x0A // 频道0接收数据地址 #define RX_ADDR_P1 0x0B // 频道1接收数据地址 #define RX_ADDR_P2 0x0C // 频道2接收数据地址 #define RX_ADDR_P3 0x0D // 频道3接收数据地址 #define RX_ADDR_P4 0x0E // 频道4接收数据地址 #define RX_ADDR_P5 0x0F // 频道5接收数据地址 #define TX_ADDR 0x10 // 发送地址寄存器 #define RX_PW_P0 0x11 // 接收频道0接收数据长度 #define RX_PW_P1 0x12 // 接收频道0接收数据长度 #define RX_PW_P2 0x13 // 接收频道0接收数据长度 #define RX_PW_P3 0x14 // 接收频道0接收数据长度 #define RX_PW_P4 0x15 // 接收频道0接收数据长度 #define RX_PW_P5 0x16 // 接收频道0接收数据长度 #define FIFO_STATUS 0x17 // FIFO栈入栈出状态寄存器设置 //************************************************************************************** void Delay(unsigned int s); void inerDelay_us(unsigned char n); void init_NRF24L01(void); uint SPI_RW(uint uchar); uchar SPI_Read(uchar reg); void SetRX_Mode(void); uint SPI_RW_Reg(uchar reg, uchar value); uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars); uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars); unsigned char nRF24L01_RxPacket(unsigned char* rx_buf); void nRF24L01_TxPacket(unsigned char * tx_buf); //*****************************************长延时***************************************** void Delay(unsigned int s) { unsigned int i; for(i=0; i //****************************************************************************************** uint bdata sta; //状态标志 ***it RX_DR =sta^6; ***it TX_DS =sta^5; ***it MAX_RT =sta^4; /****************************************************************************************** /*延时函数 /******************************************************************************************/ void inerDelay_us(unsigned char n) { for(;n>0;n--) _nop_(); } //**************************************************************************************** /*NRF24L01初始化 //***************************************************************************************/ void init_NRF24L01(void) { inerDelay_us(100); CE=0; // chip enable CSN=1; // Spi disable SCK=0; // Spi clock line init high SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); // 写本地地址 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); // 写接收端地址 SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // 频道0自动 ACK应答允许 SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // 允许接收地址只有频道0,如果需要多频道,可以参考Page21 SPI_RW_Reg(WRITE_REG + RF_CH, 40); // 设置信道工作为2.4GHZ,收发必须一致 SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //设置接收数据长度,本次设置为32纸? SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); //设置发射速率为1MHZ,发射功率为最大值0dB } /**************************************************************************************************** /*函数:uint SPI_RW(uint uchar) /*功能:NRF24L01的SPI写时序 /*详细请参考Page19 /****************************************************************************************************/ uint SPI_RW(uint uchar) { uint bit_ctr; for(bit_ctr=0;bit_ctr<8;bit_ctr++) // output 8-bit { MOSI = (uchar & 0x80); // output 'uchar', MSB to MOSI uchar = (uchar << 1); // shift next bit into MSB.. SCK = 1; // Set SCK high.. uchar |= MISO; // capture current MISO bit SCK = 0; // ..then set SCK low again } return(uchar); // return read uchar } /**************************************************************************************************** /*函数:uchar SPI_Read(uchar reg) /*功能:NRF24L01的SPI时序 /*详细请参考Page19 /****************************************************************************************************/ uchar SPI_Read(uchar reg) { uchar reg_val; CSN = 0; // CSN low, initialize SPI communication... SPI_RW(reg); // Select register to read from.. reg_val = SPI_RW(0); // ..then read registervalue CSN = 1; // CSN high, terminate SPI communication return(reg_val); // return register value } /****************************************************************************************************/ /*功能:NRF24L01读写寄存器函数 /****************************************************************************************************/ uint SPI_RW_Reg(uchar reg, uchar value) { uint status; CSN = 0; // CSN low, init SPI transaction status = SPI_RW(reg); // select register SPI_RW(value); // ..and write value to it.. CSN = 1; // CSN high again return(status); // return nRF24L01 status uchar } /****************************************************************************************************/ /*函数:uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars) /*功能: 用于读数据,reg:为寄存器地址,pBuf:为待读出数据地址,uchars:读出数据的个数 /****************************************************************************************************/ uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars) { uint status,uchar_ctr; CSN = 0; // Set CSN low, init SPI tranaction status = SPI_RW(reg); // Select register to write to and read status uchar for(uchar_ctr=0;uchar_ctr CSN = 1; return(status); // return nRF24L01 status uchar } /********************************************************************************************************* /*函数:uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars) /*功能: 用于写数据:为寄存器地址,pBuf:为待写入数据地址,uchars:写入数据的个数 /*********************************************************************************************************/ uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars) { uint status,uchar_ctr; CSN = 0; //SPI使能 status = SPI_RW(reg); for(uchar_ctr=0; uchar_ctr CSN = 1; //关闭SPI return(status); // } /****************************************************************************************************/ /*函数:void SetRX_Mode(void) /*功能:数据接收配置 /****************************************************************************************************/ void SetRX_Mode(void) { CE=0; SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // IRQ收发完成中断响应,16位CRC ,主接收 CE = 1; inerDelay_us(130); } /******************************************************************************************************/ /*函数:unsigned char nRF24L01_RxPacket(unsigned char* rx_buf) /*功能:数据读取后放如rx_buf接收缓冲区中 /******************************************************************************************************/ unsigned char nRF24L01_RxPacket(unsigned char* rx_buf) { unsigned char revale=0; sta=SPI_Read(STATUS); // 读取状态寄存其来判断数据接收状况 if(RX_DR) // 判断是否接收到数据 { CE = 0; SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer revale =1; //读取数据完成标志 } SPI_RW_Reg(WRITE_REG+STATUS,sta); //接收到数据后RX_DR,TX_DS,MAX_PT都置高为1,通过写1来其清除中断标志 return revale; } /*********************************************************************************************************** /*函数:void nRF24L01_TxPacket(unsigned char * tx_buf) /*功能:发送 tx_buf中数据 /**********************************************************************************************************/ void nRF24L01_TxPacket(unsigned char * tx_buf) { CE=0; //StandBy I模式 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 装载接收端地址 SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // 装载数据 SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // IRQ收发完成中断响应,16位CRC,主发送 CE=1; //置高CE,激发数据发送 inerDelay_us(10); } //***********************************************串口初始化*********************************************** void StartUART( void ) { SCON = 0x50; TMOD = 0x20; TH1 = 0xFA; TL1 = 0xFA; //波特率4800 PCON = 0x00; TR1 = 1; } //***********************************************通过串口向PC发送*********************************************** void R_S_Byte(uchar R_Byte) { SBUF = R_Byte; while( TI == 0 ); //查询法 TI = 0; } //***********************************************数码动态扫描显示*********************************************** void disdignit() { P0=0xC6; //C led0=0; Delay(10); led0=1; P0=seg[temp[1]]; //小数位 led1=0; Delay(10); led1=1; P0=seg1[temp[5]]; //十位 led2=0; Delay(10); led2=1; P0=seg[temp[4]]; //个位 led3=0; Delay(10); led3=1; } //************************************主函数************************************************************ void main(void) { uchar i=0; init_NRF24L01() ; //NRF24L01初始化 StartUART(); Delay(1); BELL=1; while(1) { //*********************************************************************************************** SetRX_Mode(); if(nRF24L01_RxPacket(RxBuf)) { temp[0]=RxBuf[3]; //符号位 temp[2]=((RxBuf[2]<<4)|RxBuf[1]); //整数位 temp[1]=RxBuf[0]; //小数位 temp[4]=RxBuf[2]; //十位 temp[5]=RxBuf[1]; //个位 disdignit(); //数码管显示温度 R_S_Byte('t'); //串口显示温度 disdignit(); //数码管显示温度 disdignit(); //数码管显示温度 R_S_Byte(0x30+temp[4]); //串口显示温度 R_S_Byte(0x30+temp[5]); //串口显示温度 R_S_Byte('.'); //串口显示温度 R_S_Byte(0x30+temp[1]); //串口显示温度 disdignit(); //数码管显示温度 disdignit(); //数码管显示温度 disdignit(); //数码管显示温度 for(i=0;i<3;i++) { R_S_Byte(temp[2-i]); //串口显示温度 Delay(60); } } disdignit(); //数码管显示温度 if(temp[2]>=0x30) //大于30度时报警,0x30转换成10进制为48 { BELL=0; //打开蜂明器 Delay(10); } else { BELL=1; //关闭蜂明器 } } }#include #include typedef unsigned char uchar; typedef unsigned char uint; //****************************************NRF24L01端口定义*************************************** ***it MISO =P1^6; //nRF24L01引脚定义 ***it MOSI =P1^5; ***it SCK =P1^7; ***it CE =P1^2; ***it CSN =P1^3; ***it IRQ =P1^4; //************************************按键*************************************************** ***it KEY1=P3^5; ***it KEY2=P3^4; //************************************数码管位选********************************************* ***it led3=P2^0; ***it led2=P2^1; ***it led1=P2^2; ***it led0=P2^3; ***it le1=P1^0; ***it le2=P1^1; //************************************蜂明器*************************************************** ***it BELL=P3^6; int n; uchar num; //***********************************数码管0-9编码******************************************* uchar seg[10]={0xC0,0xCF,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90}; //0~~9段码 uchar seg1[10]={0x40,0x4F,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10}; //0~~9段码 char temp[6]; uchar RxBuf[20]={0}; //*********************************************NRF24L01************************************* #define TX_ADR_WIDTH 5 // 5 uints TX address width #define RX_ADR_WIDTH 5 // 5 uints RX address width #define TX_PLOAD_WIDTH 20 // 20 uints TX payload #define RX_PLOAD_WIDTH 20 // 20 uints TX payload uint const TX_ADDRESS[TX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //本地地址 uint const RX_ADDRESS[RX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //接收地址 //***************************************NRF24L01寄存器指令******************************************************* #define READ_REG 0x00 // 读寄存器指令 #define WRITE_REG 0x20 // 写寄存器指令 #define RD_RX_PLOAD 0x61 // 读取接收数据指令 #define WR_TX_PLOAD 0xA0 // 写待发数据指令 #define FLUSH_TX 0xE1 // 冲洗发送 FIFO指令 #define FLUSH_RX 0xE2 // 冲洗接收 FIFO指令 #define REUSE_TX_PL 0xE3 // 定义重复装载数据指令 #define NOP 0xFF // 保留 //*************************************SPI(nRF24L01)寄存器地址**************************************************** #define CONFIG 0x00 // 配置收发状态,CRC校验模式以及收发状态响应方式 #define EN_AA 0x01 // 自动应答功能设置 #define EN_RXADDR 0x02 // 可用信道设置 #define SETUP_AW 0x03 // 收发地址宽度设置 #define SETUP_RETR 0x04 // 自动重发功能设置 #define RF_CH 0x05 // 工作频率设置 #define RF_SETUP 0x06 // 发射速率、功耗功能设置 #define STATUS 0x07 // 状态寄存器 #define OBSERVE_TX 0x08 // 发送监测功能 #define CD 0x09 // 地址检测 #define RX_ADDR_P0 0x0A // 频道0接收数据地址 #define RX_ADDR_P1 0x0B // 频道1接收数据地址 #define RX_ADDR_P2 0x0C // 频道2接收数据地址 #define RX_ADDR_P3 0x0D // 频道3接收数据地址 #define RX_ADDR_P4 0x0E // 频道4接收数据地址 #define RX_ADDR_P5 0x0F // 频道5接收数据地址 #define TX_ADDR 0x10 // 发送地址寄存器 #define RX_PW_P0 0x11 // 接收频道0接收数据长度 #define RX_PW_P1 0x12 // 接收频道0接收数据长度 #define RX_PW_P2 0x13 // 接收频道0接收数据长度 #define RX_PW_P3 0x14 // 接收频道0接收数据长度 #define RX_PW_P4 0x15 // 接收频道0接收数据长度 #define RX_PW_P5 0x16 // 接收频道0接收数据长度 #define FIFO_STATUS 0x17 // FIFO栈入栈出状态寄存器设置 //************************************************************************************** void Delay(unsigned int s); void inerDelay_us(unsigned char n); void init_NRF24L01(void); uint SPI_RW(uint uchar); uchar SPI_Read(uchar reg); void SetRX_Mode(void); uint SPI_RW_Reg(uchar reg, uchar value); uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars); uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars); unsigned char nRF24L01_RxPacket(unsigned char* rx_buf); void nRF24L01_TxPacket(unsigned char * tx_buf); //*****************************************长延时***************************************** void Delay(unsigned int s) { unsigned int i; for(i=0; i //****************************************************************************************** uint bdata sta; //状态标志 ***it RX_DR =sta^6; ***it TX_DS =sta^5; ***it MAX_RT =sta^4; /****************************************************************************************** /*延时函数 /******************************************************************************************/ void inerDelay_us(unsigned char n) { for(;n>0;n--) _nop_(); } //**************************************************************************************** /*NRF24L01初始化 //***************************************************************************************/ void init_NRF24L01(void) { inerDelay_us(100); CE=0; // chip enable CSN=1; // Spi disable SCK=0; // Spi clock line init high SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); // 写本地地址 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); // 写接收端地址 SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // 频道0自动 ACK应答允许 SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // 允许接收地址只有频道0,如果需要多频道,可以参考Page21 SPI_RW_Reg(WRITE_REG + RF_CH, 40); // 设置信道工作为2.4GHZ,收发必须一致 SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //设置接收数据长度,本次设置为32纸? SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); //设置发射速率为1MHZ,发射功率为最大值0dB } /**************************************************************************************************** /*函数:uint SPI_RW(uint uchar) /*功能:NRF24L01的SPI写时序 /*详细请参考Page19 /****************************************************************************************************/ uint SPI_RW(uint uchar) { uint bit_ctr; for(bit_ctr=0;bit_ctr<8;bit_ctr++) // output 8-bit { MOSI = (uchar & 0x80); // output 'uchar', MSB to MOSI uchar = (uchar << 1); // shift next bit into MSB.. SCK = 1; // Set SCK high.. uchar |= MISO; // capture current MISO bit SCK = 0; // ..then set SCK low again } return(uchar); // return read uchar } /**************************************************************************************************** /*函数:uchar SPI_Read(uchar reg) /*功能:NRF24L01的SPI时序 /*详细请参考Page19 /****************************************************************************************************/ uchar SPI_Read(uchar reg) { uchar reg_val; CSN = 0; // CSN low, initialize SPI communication... SPI_RW(reg); // Select register to read from.. reg_val = SPI_RW(0); // ..then read registervalue CSN = 1; // CSN high, terminate SPI communication return(reg_val); // return register value } /****************************************************************************************************/ /*功能:NRF24L01读写寄存器函数 /****************************************************************************************************/ uint SPI_RW_Reg(uchar reg, uchar value) { uint status; CSN = 0; // CSN low, init SPI transaction status = SPI_RW(reg); // select register SPI_RW(value); // ..and write value to it.. CSN = 1; // CSN high again return(status); // return nRF24L01 status uchar } /****************************************************************************************************/ /*函数:uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars) /*功能: 用于读数据,reg:为寄存器地址,pBuf:为待读出数据地址,uchars:读出数据的个数 /****************************************************************************************************/ uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars) { uint status,uchar_ctr; CSN = 0; // Set CSN low, init SPI tranaction status = SPI_RW(reg); // Select register to write to and read status uchar for(uchar_ctr=0;uchar_ctr CSN = 1; return(status); // return nRF24L01 status uchar } /********************************************************************************************************* /*函数:uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars) /*功能: 用于写数据:为寄存器地址,pBuf:为待写入数据地址,uchars:写入数据的个数 /*********************************************************************************************************/ uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars) { uint status,uchar_ctr; CSN = 0; //SPI使能 status = SPI_RW(reg); for(uchar_ctr=0; uchar_ctr CSN = 1; //关闭SPI return(status); // } /****************************************************************************************************/ /*函数:void SetRX_Mode(void) /*功能:数据接收配置 /****************************************************************************************************/ void SetRX_Mode(void) { CE=0; SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // IRQ收发完成中断响应,16位CRC ,主接收 CE = 1; inerDelay_us(130); } /******************************************************************************************************/ /*函数:unsigned char nRF24L01_RxPacket(unsigned char* rx_buf) /*功能:数据读取后放如rx_buf接收缓冲区中 /******************************************************************************************************/ unsigned char nRF24L01_RxPacket(unsigned char* rx_buf) { unsigned char revale=0; sta=SPI_Read(STATUS); // 读取状态寄存其来判断数据接收状况 if(RX_DR) // 判断是否接收到数据 { CE = 0; SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer revale =1; //读取数据完成标志 } SPI_RW_Reg(WRITE_REG+STATUS,sta); //接收到数据后RX_DR,TX_DS,MAX_PT都置高为1,通过写1来其清除中断标志 return revale; } /*********************************************************************************************************** /*函数:void nRF24L01_TxPacket(unsigned char * tx_buf) /*功能:发送 tx_buf中数据 /**********************************************************************************************************/ void nRF24L01_TxPacket(unsigned char * tx_buf) { CE=0; //StandBy I模式 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 装载接收端地址 SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // 装载数据 SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // IRQ收发完成中断响应,16位CRC,主发送 CE=1; //置高CE,激发数据发送 inerDelay_us(10); } //***********************************************串口初始化*********************************************** void StartUART( void ) { SCON = 0x50; TMOD = 0x20; TH1 = 0xFA; TL1 = 0xFA; //波特率4800 PCON = 0x00; TR1 = 1; } //***********************************************通过串口向PC发送*********************************************** void R_S_Byte(uchar R_Byte) { SBUF = R_Byte; while( TI == 0 ); //查询法 TI = 0; } //***********************************************数码动态扫描显示*********************************************** void disdignit() { P0=0xC6; //C led0=0; Delay(10); led0=1; P0=seg[temp[1]]; //小数位 led1=0; Delay(10); led1=1; P0=seg1[temp[5]]; //十位 led2=0; Delay(10); led2=1; P0=seg[temp[4]]; //个位 led3=0; Delay(10); led3=1; } //************************************主函数************************************************************ void main(void) { uchar i=0; init_NRF24L01() ; //NRF24L01初始化 StartUART(); Delay(1); BELL=1; while(1) { //*********************************************************************************************** SetRX_Mode(); if(nRF24L01_RxPacket(RxBuf)) { temp[0]=RxBuf[3]; //符号位 temp[2]=((RxBuf[2]<<4)|RxBuf[1]); //整数位 temp[1]=RxBuf[0]; //小数位 temp[4]=RxBuf[2]; //十位 temp[5]=RxBuf[1]; //个位 disdignit(); //数码管显示温度 R_S_Byte('t'); //串口显示温度 disdignit(); //数码管显示温度 disdignit(); //数码管显示温度 R_S_Byte(0x30+temp[4]); //串口显示温度 R_S_Byte(0x30+temp[5]); //串口显示温度 R_S_Byte('.'); //串口显示温度 R_S_Byte(0x30+temp[1]); //串口显示温度 disdignit(); //数码管显示温度 disdignit(); //数码管显示温度 disdignit(); //数码管显示温度 for(i=0;i<3;i++) { R_S_Byte(temp[2-i]); //串口显示温度 Delay(60); } } disdignit(); //数码管显示温度 if(temp[2]>=0x30) //大于30度时报警,0x30转换成10进制为48 { BELL=0; //打开蜂明器 Delay(10); } else { BELL=1; //关闭蜂明器 } } } 也就是
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
185 浏览 0 评论
340 浏览 0 评论
367 浏览 0 评论
752 浏览 0 评论
RT-Thread与英飞凌(infineon)合作得板子PSOC 6 板子学习
737 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16987 浏览 31 评论
/9
GMT+8, 2025-12-11 04:51 , Processed in 0.670321 second(s), Total 71, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1877
