Linear公司的LTCR2145-14/LTC2144-14/LTC2143-14是
The LTCR2145-14/LTC2144-14/LTC2143-14 are 2-channel simultaneous sampling 14-bit A/D converters designed for digitizing high frequency, wide dynamic range signals. They are perfect for demanding communications applications with AC performance that includes 73.1dB SNR and 90dB spurious free dynamic range (SFDR). Ultralow jitter of 0.08psRMS allows undersampling of IF frequencies with excellent noise performance. DC specs include ±1LSB INL (typ), ±0.3LSB DNL (typ) and no missing codes over temperature. The transition noise is 1.2LSBRMS. The digital outputs can be either full rate CMOS, double data rate CMOS, or double data rate LVDS. A separate output power supply allows the CMOS output swing to range from 1.2V to 1.8V. The ENC+ and ENC– inputs may be driven differentially or single-ended with a sine wave, PECL, LVDS, TTL, or CMOS inputs. An optional clock duty cycle stabilizer allows high performance at full speed for a wide range of clock duty cycles. LTC2145-14主要特性: Two-Channel Simultaneously Sampling ADC 73.1dB SNR 90dB SFDR Low Power: 189mW/149mW/113mW Total 95mW/75mW/57mW per Channel Single 1.8V Supply CMOS, DDR CMOS, or DDR LVDS Outputs Selectable Input Ranges: 1VP-P to 2VP-P 750MHz Full Power Bandwidth S/H Optional Data Output Randomizer Optional Clock Duty Cycle Stabilizer Shutdown and Nap Modes Serial SPI Port for Configuration 64-Pin (9mm × 9mm) QFN Package LTC2145-14应用: Communications Cellular Base Stations Software Defined Radios Portable Medical Imaging Multi-Channel Data Acquisition Nondestructive Testing 图1.LTC2145-14功能方框图 图2.LTC2145-14输入频率5MHz-150MHz的前端电路图 图3.LTC2145-14输入频率150MHz-250MHz的前端电路图 图4.LTC2145-14输入频率大于250MHz的前端电路图 图5.LTC2145-14采用高速差分放大器的前端电路图 图6.LTC2145-14典型应用电路图 1620A演示板 Demonstration circuit 1620A supports a family of 16-/14-/12-bit, 25Msps to 125Msps ADCs. Each assembly features one of the following devices: LTC®2185, LTC2184, LTC2183, LTC2182, LTC2181, LTC2180, LTC2145-14, LTC2144-14, LTC2143-14, LTC2142-14, LTC2141-14, LTC2140-14, LTC2145-12, LTC2144-12, LTC2143-12, LTC2142-12, LTC2141-12, or LTC2140-12 high speed, high dynamic range ADCs. Demonstration circuit 1620A supports the LTC2185/LTC2145 family DDR LVDS output mode. The versions of the 1620A demo board supporting the LTC2185 and LTC2145 series of A/D converters. Depending on the required resolution and sample rate, the DC1620A is supplied with the appropriate ADC. The circuitry on the analog inputs is optimized for analog input frequencies from 5MHz to 70MHz. Refer to the data sheet for proper input networks for different input frequencies. 图7.1620A演示板外形图 图8.1620A演示板电路图(1) 图9.1620A演示板电路图(2) 1620A演示板材料清单(BOM): |
只有小组成员才能发言,加入小组>>
709 浏览 2 评论
12711 浏览 0 评论
4044 浏览 7 评论
2273 浏览 9 评论
2083 浏览 2 评论
400浏览 2评论
710浏览 2评论
461浏览 1评论
528浏览 1评论
AD7656在没有输入信号时,测量输入端都会有几mV至几十mV的电压,怎么消除呢?
423浏览 1评论
GMT+8, 2024-9-29 04:59 , Processed in 0.859065 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
