扫一扫,分享给好友
我在运行ti官方给的demo时,rebuild工程后总是会出现如下的错误提示
**** Clean-only build of configuration Debug for project mmwave_sdk_68xx_dsp_dss **** "E:\CCS9.3.1\ccs\utils\bin\gmake" -k -j 4 clean -O DEL /F "xwr68xx_mmw_demo_dss.hex" "configPkglinker.cmd" "configPkgcompiler.opt" "xwr68xx_mmw_demo_dss.xe674" DEL /F "dss_main.oe674" "objectdetection.oe674" DEL /F "dss_main.d" "objectdetection.d" RMDIR /S/Q "configPkg" 找不到 E:ccs9.3_projectmmwave_sdk_68xx_dsp_dssDebugxwr68xx_mmw_demo_dss.hex 找不到 E:ccs9.3_projectmmwave_sdk_68xx_dsp_dssDebugxwr68xx_mmw_demo_dss.xe674 找不到 E:ccs9.3_projectmmwave_sdk_68xx_dsp_dssDebugdss_main.oe674 Finished clean **** Build Finished **** **** Build of configuration Debug for project mmwave_sdk_68xx_dsp_dss **** "E:\CCS9.3.1\ccs\utils\bin\gmake" -k -j 4 all -O rm -f E:/ccs9.3_project/mmwave_sdk_68xx_dsp_dss/Debug/mmwave_sdk_68xx_dss.bin makefile:193: recipe for target 'pre-build' failed process_begin: CreateProcess(NULL, rm -f E:/ccs9.3_project/mmwave_sdk_68xx_dsp_dss/Debug/mmwave_sdk_68xx_dss.bin, ...) failed. make (e=2): 系统找不到指定的文件。 gmake[1]: [pre-build] Error 2 (ignored) Building file: "../mmw_dss.cfg" Invoking: XDCtools "E:/CCS9.3.1/xdctools_3_60_02_34_core/xs" --xdcpath="C:/ti/bios_6_73_01_01/packages;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C674 -p ti.platforms.c6x:IWR68XX:false:600 -r release -c "E:/CCS9.3.1/ccs/tools/compiler/ti-cgt-c6000_8.3.5" --compileOptions "--enum_type=int " "../mmw_dss.cfg" making package.mak (because of package.bld) ... generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ... configuring mmw_dss.xe674 from package/cfg/mmw_dss_pe674.cfg ... generating custom ti.sy***ios library makefile ... Starting build of library sources ... making E:/ccs9.3_project/mmwave_sdk_68xx_dsp_dss/src/sy***ios/sy***ios.ae674 ... Build of libraries done. cle674 package/cfg/mmw_dss_pe674.c ... Finished building: "../mmw_dss.cfg" Building file: "../dss_main.c" Invoking: C6000 Compiler "E:/CCS9.3.1/ccs/tools/compiler/ti-cgt-c6000_8.3.5/bin/cl6x" -mv6740 --abi=eabi -O3 --opt_for_speed=3 --include_path="E:/ccs9.3_project/mmwave_sdk_68xx_dsp_dss" --include_path="C:/ti/mmwave_sdk_03_05_00_04/packages" --include_path="C:/ti/mmwave_sdk_03_05_00_04/packages/ti/demo/xwr68xx/mmw" --include_path="C:/ti/mmwave_sdk_03_05_00_04/packages/ti/demo/utils" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16/c64P" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="E:/CCS9.3.1/ccs/tools/compiler/ti-cgt-c6000_8.3.5/include" --define=SOC_XWR68XX --define=SUBSYS_DSS --define=MMWAVE_L3RAM_NUM_BANK=6 --define=MMWAVE_SHMEM_TCMA_NUM_BANK=0 --define=MMWAVE_SHMEM_TCMB_NUM_BANK=0 --define=MMWAVE_SHMEM_BANK_SIZE=0x20000 --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED --define=_LITTLE_ENDIAN --define=OBJDET_NO_RANGE --define=APP_RESOURCE_FILE='<'ti/demo/xwr68xx/mmw/mmw_res.h'>' -g --gcc --diag_error=10015 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="dss_main.d_raw" --cmd_file="configPkg/compiler.opt" "../dss_main.c" Finished building: "../dss_main.c" Building file: "../objectdetection.c" Invoking: C6000 Compiler "E:/CCS9.3.1/ccs/tools/compiler/ti-cgt-c6000_8.3.5/bin/cl6x" -mv6740 --abi=eabi -O3 --opt_for_speed=3 --include_path="E:/ccs9.3_project/mmwave_sdk_68xx_dsp_dss" --include_path="C:/ti/mmwave_sdk_03_05_00_04/packages" --include_path="C:/ti/mmwave_sdk_03_05_00_04/packages/ti/demo/xwr68xx/mmw" --include_path="C:/ti/mmwave_sdk_03_05_00_04/packages/ti/demo/utils" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16/c64P" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="E:/CCS9.3.1/ccs/tools/compiler/ti-cgt-c6000_8.3.5/include" --define=SOC_XWR68XX --define=SUBSYS_DSS --define=MMWAVE_L3RAM_NUM_BANK=6 --define=MMWAVE_SHMEM_TCMA_NUM_BANK=0 --define=MMWAVE_SHMEM_TCMB_NUM_BANK=0 --define=MMWAVE_SHMEM_BANK_SIZE=0x20000 --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED --define=_LITTLE_ENDIAN --define=OBJDET_NO_RANGE --define=APP_RESOURCE_FILE='<'ti/demo/xwr68xx/mmw/mmw_res.h'>' -g --gcc --diag_error=10015 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="objectdetection.d_raw" --cmd_file="configPkg/compiler.opt" "../objectdetection.c" Finished building: "../objectdetection.c" Building target: "xwr68xx_mmw_demo_dss.xe674" Invoking: C6000 Linker "E:/CCS9.3.1/ccs/tools/compiler/ti-cgt-c6000_8.3.5/bin/cl6x" -mv6740 --abi=eabi -O3 --opt_for_speed=3 --define=SOC_XWR68XX --define=SUBSYS_DSS --define=MMWAVE_L3RAM_NUM_BANK=6 --define=MMWAVE_SHMEM_TCMA_NUM_BANK=0 --define=MMWAVE_SHMEM_TCMB_NUM_BANK=0 --define=MMWAVE_SHMEM_BANK_SIZE=0x20000 --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED --define=_LITTLE_ENDIAN --define=OBJDET_NO_RANGE --define=APP_RESOURCE_FILE='<'ti/demo/xwr68xx/mmw/mmw_res.h'>' -g --gcc --diag_error=10015 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 -z -m"xwr68xx_mmw_demo_dss.map" --heap_size=0x800 --stack_size=0x800 -i"E:/CCS9.3.1/ccs/tools/compiler/ti-cgt-c6000_8.3.5/lib" -i"E:/ccs9.3_project/mmwave_sdk_68xx_dsp_dss" -i"C:/ti/mmwave_sdk_03_05_00_04/packages/ti/control/mmwave/lib" -i"C:/ti/mmwave_sdk_03_05_00_04/packages/ti/control/mmwavelink/lib" -i"C:/ti/mmwave_sdk_03_05_00_04/packages/ti/control/dpm/lib" -i"C:/ti/mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/lib" -i"C:/ti/mmwave_sdk_03_05_00_04/packages/ti/drivers/crc/lib" -i"C:/ti/mmwave_sdk_03_05_00_04/packages/ti/drivers/soc/lib" -i"C:/ti/mmwave_sdk_03_05_00_04/packages/ti/drivers/osal/lib" -i"C:/ti/mmwave_sdk_03_05_00_04/packages/ti/drivers/mailbox/lib" -i"C:/ti/mmwave_sdk_03_05_00_04/packages/ti/drivers/edma/lib" -i"C:/ti/mmwave_sdk_03_05_00_04/packages/ti/drivers/adcbuf/lib" -i"C:/ti/mmwave_sdk_03_05_00_04/packages/ti/drivers/cbuff/lib" -i"C:/ti/mmwave_sdk_03_05_00_04/packages/ti/utils/hsiheader/lib" -i"C:/ti/mmwave_sdk_03_05_00_04/packages/ti/utils/mathutils/lib" -i"C:/ti/mmwave_sdk_03_05_00_04/packages/ti/datapath/dpc/dpu/dopplerproc/lib" -i"C:/ti/mmwave_sdk_03_05_00_04/packages/ti/datapath/dpc/dpu/cfarcaproc/lib" -i"C:/ti/mmwave_sdk_03_05_00_04/packages/ti/datapath/dpc/dpu/aoaproc/lib" -i"C:/ti/mmwave_sdk_03_05_00_04/packages/ti/datapath/dpedma/lib" -i"C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/lib" -i"C:/ti/mathlib_c674x_3_1_2_1/packages/ti/mathlib/lib" -i"E:/CCS9.3.1/ccs/tools/compiler/ti-cgt-c6000_8.3.5/include" --reread_libs --disable_auto_rts --define=MMWAVE_L3RAM_NUM_BANK=6 --define=MMWAVE_SHMEM_TCMA_NUM_BANK=0 --define=MMWAVE_SHMEM_TCMB_NUM_BANK=0 --define=MMWAVE_SHMEM_BANK_SIZE=0x20000 --diag_error=10015 --diag_warning=225 --diag_wrap=off --display_error_number --warn_sections --xml_link_info="xwr68xx_mmw_demo_dss_linkInfo.xml" --ram_model --unused_section_elimination=on -o "xwr68xx_mmw_demo_dss.xe674" "./dss_main.oe674" "./objectdetection.oe674" "../c674x_linker.cmd" "../mmw_dss_linker.cmd" -l"configPkg/linker.cmd" -ldsplib.ae64P -lmathlib.ae674 -llibmathutils.ae674 -llibsoc_xwr68xx.ae674 -llibosal_xwr68xx.ae674 -llibcrc_xwr68xx.ae674 -llibmailbox_xwr68xx.ae674 -llibmmwavelink_xwr68xx.ae674 -llibmmwave_xwr68xx.ae674 -llibedma_xwr68xx.ae674 -llibadcbuf_xwr68xx.ae674 -llibmmwavealg_xwr68xx.ae674 -llibcbuff_xwr68xx.ae674 -llibhsiheader_xwr68xx.ae674 -llibcfarcaproc_dsp_xwr68xx.ae674 -llibdopplerproc_dsp_xwr68xx.ae674 -llibaoaproc_dsp_xwr68xx.ae674 -llibdpm_xwr68xx.ae674 -llibdpedma_hwa_xwr68xx.ae674 -lrts6740_elf.lib -llibc.a Finished building target: "xwr68xx_mmw_demo_dss.xe674" C:/ti/mmwave_sdk_03_05_00_04/packages/scripts/ImageCreator/out2rprc/out2rprc.exe xwr68xx_mmw_demo_dss.xe674 xwr68xx_mmw_demo_dss.bin Parsing the input object file, xwr68xx_mmw_demo_dss.xe674. Appending zeros 8482632 Appending zeros 8496024 Appending zeros 8500064 Appending zeros 8500264 File conversion complete! **** Build Finished **** 请问这是什么原因造成的? 谢谢各位前辈的解答 |
相关推荐 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
TMS320C6748 板卡设计中是否一定需要有SDRAM或者DDR
1958 浏览 0 评论
988 浏览 0 评论
3654 浏览 1 评论
【六岳微LY-F335开发板试用体验】epwm启动ADC并在OLED上显示结果
4493 浏览 0 评论
【六岳微LY-F335开发板试用体验】软件开发环境及调试下载
4541 浏览 0 评论
/9
GMT+8, 2025-12-2 05:44 , Processed in 0.429446 second(s), Total 41, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5394
