发 帖
[问答]
求大神,让其可正常显示倒计时
2026 计时器
2021-1-6 18:59:18   评论 分享淘帖 邀请回答 举报
5个回答
2021-1-7 12:42:00 2 评论
举报
2 条评论
2021-1-7 20:26:50 1 评论
举报
1 条评论
  • 2021-1-8 09:37
    #include<reg52.h>
    #include <absacc.h>
    #define a8255_PA XBYTE[0xd900] /*PA 口地址 */
    #define a8255_PB XBYTE[0xdb00] /*PB 口地址 */
    #define a8255_PC XBYTE[0xD5FF] /*PC 口地址 */
    #define a8255_CON XBYTE[0xde00] /*控制字地址 */
    #define uchar unsigned char
    #define uint unsigned long int
    uint a,n,i,j,x=1,b=1,tt=0;
    uint table[]={0x80,0x9B,0x42,0x0A,0x19,0x0C,0x04,0x9A,0x00,0x08};
    void delay1(void)
            unsigned char i;
            for(i=250; i>0;i--);
    uchar inkey()
            uchar i,j=0x10,k;
    uchar keytab[20]={0x18, /*0*/
    0x28, /*1*/
    0x48, /*2*/
    0x88, /*3*/
    0x14, /*4*/
    0x24, /*5*/
    0x44, /*6*/
    0x84, /*7*/
    0x12, /*8*/
    0x22, /*9*/
    0x42, /*10*/
    0x82, /*11*/
    0x11, /*12*/
    0x21, /*13*/
    0x41, /*14*/
    0x81 /*15*/
            a8255_CON=0x81;
            a8255_PC=0x00;
            for(i=0;i<4;i++)
                    a8255_PC=j;
                    a8255_PA=0xff;
                    a8255_PB=0xff;
                    k=a8255_PC;
                    k=k&0x0f;
                    if(k!=0)
                    { delay1();
                            k=a8255_PC;
                             k=k&0x0f;
                                    if(k!=0)
                                    break;
            j=j<<1;
            delay1();
            k=k+j;
            for(i=0;i<16;i++)
            if(keytab==k) break;
    return i;
    void delay(uint z)
            uint x,y;
            for(x=z;x>0;x--)
            for(y=11;y>0;y--);
    void display(uint a)
            uint wan,qian,bai,shi,ge;
            wan=a/10000;
            qian=a%10000/1000;
            bai=a%1000/100;
            shi=a%100/10;
            ge=a%10;
            a8255_PA=0xfd;
            a8255_PB=table[wan];
            delay(1);
            a8255_PA=0xfb;
            a8255_PB=table[qian];
            delay(1);
            a8255_PA=0xf7;
            a8255_PB=table[bai];
            delay(1);
            a8255_PA=0xef;
            a8255_PB=table[shi];
            delay(1);
            a8255_PA=0xdf;
            a8255_PB=table[ge];
            delay(1);
    void display1()
            a8255_PA=0xdf;
            a8255_PB=0x80;
            delay(1);
            a8255_PA=0xef;
            a8255_PB=0x7f;
            delay(1);
    void init()
    {         a8255_PA=0xff;
            a8255_CON=0x81;
            tt=0;
            TMOD=0x01;
            TH0=0x3c;
            TL0=0xb0;
            EA=1;
            ET0=1;
            TR0=1;
            EX0=1;
            IT1=1;
    void main()
            uchar n=0,k=0xdf;
            init();
            a=0;
            while(1)
            n=inkey();
            switch(n)
                    case 0:         a=99999;        break;
                    case 1:         a=9999;         break;
                 case 2:         a=999;                 break;
                case 3:         a=99;                 break;
               case 4:                 a=9;                 break;
            if(n==5)
                    do
                            display1();
                            n=inkey();
                            if((n!=5)&&(n!=16))
                                    x=0;
                    }while(x);
                    x=1;
            display(a);
    void timer0() interrupt 1
            TH0=0x3c;
            TL0=0xb0;
            tt++;
            if(tt==20)
                    tt=0;
                    if(a)
                            a--;
2021-1-8 11:06:49 评论
举报
2021-1-8 16:09:01 1 评论
举报
1 条评论
撰写答案
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
您需要登录后才可以回帖 登录/注册
声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容图片侵权或者其他问题,请联系本站作侵删。 侵权投诉
快速回复 返回顶部 返回列表
关注微信公众号
电子发烧友网
电子发烧友论坛
社区合作
刘勇
联系电话:15994832713
邮箱地址:liuyong@huaqiu.com
社区管理
elecfans短短
微信:elecfans_666
邮箱:users@huaqiu.com
关闭
站长推荐 上一条 /9 下一条
快速回复 返回顶部 返回列表
