[Start: Spectrum Digital XDS560V2 STM USBEmulator_0] Execute the command: %ccs_base%/common/uscif/dbgjtag -f%boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity [Result] -----[Print the board config pathname(s)]------------------------------------ C:UsersYISENAppDataLocalTEXASI~1CCS ti3 BrdDattestBoard.dat -----[Print the reset-command softwarelog-file]----------------------------- This utility has selected a 560/2xx-classproduct. This utility will load the program'sd560v2u.out'. The library build date was 'Apr 30 2019'. The library build time was '11:41:17'. The library package version is'8.1.0.00012'. The library component version is'35.35.0.0'. The controller does not use a programmableFPGA. The controller has a version number of '6'(0x00000006). The controller has an insertion length of'0' (0x00000000). The cable+pod has a version number of '8'(0x00000008). The cable+pod has a capability number of'7423' (0x00001cff). This utility will attempt to reset thecontroller. This utility has successfully reset thecontroller. -----[Print the reset-command hardwarelog-file]----------------------------- The scan-path will be reset by toggling theJTAG TRST signal. The controller is the Nano-TBC VHDL. The link is a 560-classsecond-generation-560 cable. The software is configured for Nano-TBCVHDL features. The controller will be software reset viaits registers. The controller has a logic ONE on itsEMU[0] input pin. The controller has a logic ONE on itsEMU[1] input pin. The controller will use falling-edge timingon output pins. The controller cannot control the timing oninput pins. The scan-path link-delay has been set toexactly '2' (0x0002). The utility logic has not previouslydetected a power-loss. The utility logic is not currentlydetecting a power-loss. -----[The log-file for the JTAG TCLK outputgenerated from the PLL]---------- Test Size Coord MHz Flag Result Description ~~~~ ~~~~ ~~~~~~~ ~~~~~~~~ ~~~~ ~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~ 1 none - 01 00 500.0kHz - similar isit internal clock 2 none - 01 09 570.3kHz - similar isit internal clock 3 64 - 01 00 500.0kHz O good value measure path length 4 16 - 01 00 500.0kHz O goodvalue auto step initial 5 16 - 01 0D 601.6kHz O good value auto step delta 6 16 - 01 1C 718.8kHz O good value auto step delta 7 16 - 01 2E 859.4kHz O good value auto step delta 8 16 + 00 02 1.031MHz O good value auto step delta 9 16 + 00 0F 1.234MHz O good value auto step delta 10 16 + 00 1F 1.484MHz O good value auto step delta 11 16 + 00 32 1.781MHz O good value auto step delta 12 16 + 01 04 2.125MHz O good value auto step delta 13 16 + 01 11 2.531MHz O good value auto step delta 14 16 + 01 21 3.031MHz O good value auto step delta 15 16 + 01 34 3.625MHz O good value auto step delta 16 16 + 02 05 4.313MHz O good value auto step delta 17 16 + 02 13 5.188MHz O good value auto step delta 18 16 + 02 23 6.188MHz O good value auto step delta 19 16 + 02 37 7.438MHz O good value auto step delta 20 16 + 03 07 8.875MHz O good value auto step delta 21 16 + 03 15 10.63MHz O good value auto step delta 22 16 + 03 1E 11.75MHz {O} good value auto step delta 23 64 + 02 3E 7.875MHz O good value auto power initial 24 64 + 03 0E 9.750MHz O good value auto power delta 25 64 + 03 16 10.75MHz O good value auto power delta 26 64 + 03 1A 11.25MHz O good value auto power delta 27 64 + 03 1C 11.50MHz O good value auto power delta 28 64 + 03 1D 11.63MHz O good value auto power delta 29 64 + 03 1D 11.63MHz O good value auto power delta 30 64 + 03 13 10.38MHz {O} good value auto margin initial The first internal/external clock testresuts are: The expect frequency was 500000Hz. The actual frequency was 499110Hz. The delta frequency was 890Hz. The second internal/external clock testresuts are: The expect frequency was 570312Hz. The actual frequency was 569976Hz. The delta frequency was 336Hz. In the scan-path tests: The test length was 2048 bits. The JTAG IR length was 6 bits. The JTAG DR length was 1 bits. The IR/DR scan-path tests used 30frequencies. The IR/DR scan-path tests used 500.0kHz asthe initial frequency. The IR/DR scan-path tests used 11.75MHz asthe highest frequency. The IR/DR scan-path tests used 10.38MHz asthe final frequency. -----[Measure the source and frequency ofthe final JTAG TCLKR input]-------- The frequency of the JTAG TCLKR input ismeasured as 10.37MHz. The frequency of the JTAG TCLKR input andTCLKO output signals are similar. The target system likely uses the TCLKOoutput from the emulator PLL. -----[Perform the standard path-length teston the JTAG IR and DR]----------- This path-length test uses blocks of 6432-bit words. The test for the JTAG IR instructionpath-length succeeded. The JTAG IR instruction path-length is 6bits. The test for the JTAG DR bypass path-lengthsucceeded. The JTAG DR bypass path-length is 1 bits. -----[Perform the Integrity scan-test onthe JTAG IR]------------------------ This test will use blocks of 64 32-bitwords. This test will be applied just once. Do a test using 0xFFFFFFFF. Scan tests: 1, skipped: 0, failed: 0 Do a test using 0x00000000. Scan tests: 2, skipped: 0, failed: 0 Do a test using 0xFE03E0E2. Scan tests: 3, skipped: 0, failed: 0 Do a test using 0x01FC1F1D. Scan tests: 4, skipped: 0, failed: 0 Do a test using 0x5533CCAA. Scan tests: 5, skipped: 0, failed: 0 Do a test using 0xAACC3355. Scan tests: 6, skipped: 0, failed: 0 All of the values were scanned correctly. The JTAG IR Integrity scan-test hassucceeded. -----[Perform the Integrity scan-test onthe JTAG DR]------------------------ This test will use blocks of 64 32-bitwords. This test will be applied just once. Do a test using 0xFFFFFFFF. Scan tests: 1, skipped: 0, failed: 0 Do a test using 0x00000000. Scan tests: 2, skipped: 0, failed: 0 Do a test using 0xFE03E0E2. Scan tests: 3, skipped: 0, failed: 0 Do a test using 0x01FC1F1D. Scan tests: 4, skipped: 0, failed: 0 Do a test using 0x5533CCAA. Scan tests: 5, skipped: 0, failed: 0 Do a test using 0xAACC3355. Scan tests: 6, skipped: 0, failed: 0 All of the values were scanned correctly. The JTAG DR Integrity scan-test hassucceeded. [End: Spectrum Digital XDS560V2 STM USBEmulator_0] 这是test connection的结果 但进入debug后点击connect target就跳出图片对话框,驱动也是正常的,这个问题折磨我一个星期了,希望大家指导一下
1 条评论
1个回答
楼主解决了吗,遇到了同样的问题
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 10:59 , Processed in 0.600011 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1818
