扫一扫,分享给好友
不同列使用OR条件查询
1.待优化场景 SELECT.... FROM`t1` a WHERE a.token= '16149684' AND a.store_id= '242950' AND(a.registrationId IS NOT NULL AND a.registrationId<> '') OR a.uid= 308475 AND a.registrationId IS NOT NULL AND a.registrationId<> ''1234567891011执行计划 +--------------+-----------------------+-----------------+----------------+-------------------+-------------------+---------------+----------------+---------------------------------------------+| id | select_type | table | type | key | key_len | ref | rows | Extra |+--------------+-----------------------+-----------------+----------------+-------------------+-------------------+---------------+----------------+---------------------------------------------+| 1 | SIMPLE | a | range |idx_registrationid | 99 | | 100445 | Using index condition; Using where |+--------------+-----------------------+-----------------+----------------+-------------------+-------------------+---------------+----------------+---------------------------------------------+12345共返回1行记录,花费 5 ms 。 2.场景解析 从查询条件中可以研磨令牌和uid过滤性都非常好,但是由于使用了,或者,需要采用索引合并的方法才能获得比较好的性能。但在实际执行过程中MySQL优化器替代选择了使用registrationId的索引,导致SQL的性能很差。 3.场景优化 我们将SQL改写成union all的形式。 SELECT......FROM`t1` aWHERE a.token = '16054473'AND a.store_id = '138343'AND b.is_refund = 1AND (a.registrationId IS NOT NULLAND a.registrationId <> '')union allSELECT......FROM`t1` awhere a.uid = 181579AND a.registrationId IS NOT NULLAND a.registrationId <> ''1234567891011121314151617+--------------+-----------------------+-----------------+----------------+------------------------------+---------------+-------------------+------------------------------+----------------+------------------------------------+| id | select_type | table | type | possible_keys | key | key_len | ref | rows | Extra |+--------------+-----------------------+-----------------+----------------+------------------------------+---------------+-------------------+------------------------------+----------------+------------------------------------+| 1 | PRIMARY | a | ref | IDX_TOKEN,IDX_STORE_ID_TOKEN | IDX_TOKEN | 63 | const | 1 | Using index condition; Using where || 1 | PRIMARY | b | eq_ref | PRIMARY | PRIMARY | 4 | youdian_life_sewsq.a.role_id | 1 | Using where || 2 | UNION | a | const | PRIMARY | PRIMARY | 4 | const | 1 | || 2 | UNION | b | const | PRIMARY | PRIMARY | 4 | const | 0 | unique row not found || | UNION RESULT | 通过对比优化前后的执行计划,可以明显修剪,将SQL合并成两个子查询,再使用union对结果进行合并,稳定性和安全性更好,性能更高。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
2342 浏览 0 评论
Arduino Uno l两轮自平衡机器人 电机驱动无输出求解
3986 浏览 3 评论
TT电机,Arduino Uno,L298N 5AD ,MPU6050最简自平衡机器人资料
1465 浏览 0 评论
4122 浏览 0 评论
5118 浏览 0 评论
/9
GMT+8, 2025-12-2 09:38 , Processed in 0.589585 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3950
