/*24C02-多花样流水灯演示程序(C51)
/* 将演示数据先写入24C02芯片内,再将其数据逐个读出送P0口LED显示。 /*******************************************************************/ #include #include #define uchar unsigned char #define uint unsigned int #define OP_WRITE 0xa0 // 器件地址以及写入操作 #define OP_READ 0xa1 // 器件地址以及读取操作 uchar code display[72]={ 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xBF,0xDF,0xEF,0xF7,0xFB,0xFD,0xFE,0xFF, 0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00, 0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF, 0xFC,0xF9,0xF3,0xE7,0xCF,0x9F,0x3F, 0x9F,0xCF,0xE7,0xF3,0xF9,0xFC,0xFF, 0xE7,0xDB,0xBD,0x7E,0xBD,0xDB,0xE7,0xFF, 0xE7,0xC3,0x81,0x00,0x81,0xC3,0xE7,0xFF, 0xAA,0x55,0x18,0xFF,0xF0,0x0F, 0x00,0xFF,0x00,0xFF }; ***it SDA = P3^5; ***it SCL = P3^4; void start(); void stop(); uchar shin(); bit shout(uchar write_data); void write_byte( uchar addr, uchar write_data); void fill_byte(uchar fill_size,uchar fill_data); void delayms(uint ms); uchar read_current(); uchar read_random(uchar random_addr); #define delayNOP(); {_nop_();_nop_();_nop_();_nop_();}; /**********************************************************/ main(void) { uchar i; SDA = 1; SCL = 1; fill_byte(72,0xff); // 将前72字节填充0xff for(i = 0 ; i < 72; i++) //写入显示代码到AT24C02 { write_byte(i,display); } for(i =0 ;i <72 ; i++) //从AT24C02移出数据送到P0口显示 { P0 = read_random(i); delayms(350); } } /**********************************************************/ void start() //开始位 { SDA = 1; SCL = 1; delayNOP(); SDA = 0; delayNOP(); SCL = 0; } /**********************************************************/ void stop() // 停止位 { SDA = 0; delayNOP(); SCL = 1; delayNOP(); SDA = 1; } /**********************************************************/ uchar shin() // 从AT24C02移出数据到MCU { uchar i,read_data; for(i = 0; i < 8; i++) { SCL = 1; read_data <<= 1; read_data |= SDA; SCL = 0; } return(read_data); } /**********************************************************/ bit shout(uchar write_data) // 从MCU移出数据到AT24C02 { uchar i; bit ack_bit; for(i = 0; i < 8; i++) // 循环移入8个位 { SDA = (bit)(write_data & 0x80); _nop_(); SCL = 1; delayNOP(); SCL = 0; write_data <<= 1; } SDA = 1; // 读取应答 delayNOP(); SCL = 1; delayNOP(); ack_bit = SDA; SCL = 0; return ack_bit; // 返回AT24C02应答位 } /**********************************************************/ void write_byte(uchar addr, uchar write_data) // 在指定地址addr处写入数据write_data { start(); shout(OP_WRITE); shout(addr); shout(write_data); stop(); delayms(10); // 写入周期 } /**********************************************************/ void fill_byte(uchar fill_size,uchar fill_data) // 填充数据fill_data到EEPROM内fill_size字节 { uchar i; for(i = 0; i < fill_size; i++) { write_byte(i, fill_data); } } /**********************************************************/ uchar read_current() // 在当前地址读取 { uchar read_data; start(); shout(OP_READ); read_data = shin(); stop(); return read_data; } /**********************************************************/ uchar read_random(uchar random_addr) // 在指定地址读取 { start(); shout(OP_WRITE); shout(random_addr); return(read_current()); } /**********************************************************/ void delayms(uint ms) // 延时子程序 { uchar k; while(ms--) { for(k = 0; k < 120; k++); } } 本文来自电子工程师之家 |
8 个讨论
528 浏览 0 评论
654 浏览 0 评论
858 浏览 0 评论
837 浏览 0 评论
RT-Thread与英飞凌(infineon)合作得板子PSOC 6 板子学习
770 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
17060 浏览 31 评论
/9
GMT+8, 2025-12-14 12:24 , Processed in 0.635975 second(s), Total 48, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6652
