电子发烧友论坛扫一扫,分享给好友
RCC的配置:
void RCC_Configuration(void) { /* RCC system reset(for debug purpose) */ RCC_DeInit(); /* Enable HSE */ RCC_HSEConfig(RCC_HSE_ON); /* Wait till HSE is ready */ HSEStartUpStatus = RCC_WaitForHSEStartUp(); if(HSEStartUpStatus == SUCCESS) { /* HCLK = SYSCLK */ RCC_HCLKConfig(RCC_SYSCLK_Div1); /* PCLK2 = HCLK */ RCC_PCLK2Config(RCC_HCLK_Div1); /* PCLK1 = HCLK/2 */ RCC_PCLK1Config(RCC_HCLK_Div2); /* Flash 2 wait state */ FLASH_SetLatency(FLASH_Latency_2); /* Enable Prefetch Buffer */ FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); /* PLLCLK = 8MHz * 9 = 72 MHz */ RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9); /* Enable PLL */ RCC_PLLCmd(ENABLE); /* Wait till PLL is ready */ while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) { } /* Select PLL as system clock source */ RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); /* Wait till PLL is used as system clock source */ while(RCC_GetSYSCLKSource() != 0x08) { } } /* Enable USART1, GPIOA, GPIOx and AFIO clocks */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO| RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE ,ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE); /* Enable USART2 clock */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE); /* RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2 | RCC_APB1Periph_USART3 | RCC_APB1Periph_TIM2 | RCC_APB1Periph_TIM3 | RCC_APB1Periph_WWDG, ENABLE); */ } NVIC的配置: void NVIC_Configuration(void) { NVIC_InitTypeDef NVIC_InitStructure; /* Configure the NVIC Preemption Priority Bits */ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0); /* Enable the USART2 Interrupt */ NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQChannel; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } GPIO的配置: void GPIO_Configuration (void) { GPIO_InitTypeDef GPIO_InitStructure; //AD GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_3; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; GPIO_Init(GPIOC, &GPIO_InitStructure); //RFM23 SDI,SCK,NSEL GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_15; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz; GPIO_Init(GPIOB, &GPIO_InitStructure); //RFM23 SDO,IRQ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_14; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOB, &GPIO_InitStructure); //R485 & 串口1 /*串口1 RX管脚配置*/ /* Configure USART1 Rx as input floating */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); /*R485 RX管脚配置*/ /* Configure R485 Rx as input floating */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); /*串口1 TX管脚配置*/ /* Configure USART1 Tx as alternate function push-pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); /*R485 TX管脚配置*/ /* Configure R485 Tx as alternate function push-pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); /* 配置RS485方向控制管脚*/ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure); } 485(串口2)的配置: void R485_Configuration (void) { /*配置串口1 */ USART_InitStructure.USART_BaudRate = 115200; /*设置波特率为115200*/ USART_InitStructure.USART_WordLength = USART_WordLength_8b;/*设置数据位为8*/ USART_InitStructure.USART_StopBits = USART_StopBits_1; /*设置停止位为1位*/ USART_InitStructure.USART_Parity = USART_Parity_No; /*无奇偶校验*/ USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;/*无硬件流控*/ USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; /*发送和接收*/ USART_Init(USART1, &USART_InitStructure); /*配置R485*/ USART_InitStructure.USART_BaudRate = 9600; /*设置波特率为115200*/ USART_InitStructure.USART_WordLength = USART_WordLength_8b;/*设置数据位为8*/ USART_InitStructure.USART_StopBits = USART_StopBits_1; /*设置停止位为1位*/ USART_InitStructure.USART_Parity = USART_Parity_No; /*无奇偶校验*/ USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;/*无硬件流控*/ USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; /*发送和接收*/ USART_Init(USART2, &USART_InitStructure); /* 使能串口1 */ //USART_Cmd(USART1, ENABLE); /* 使能 R485, 配置完毕 */ USART_Cmd(USART2, ENABLE); //使能485 GPIO_ResetBits(GPIOB,GPIO_Pin_0); //初始化时首先进入接收模式 USART_ITConfig(USART2,USART_IT_RXNE,ENABLE); //开接收中断 } 以上是配置,还请路过的大侠指点下~~~ |
8个回答
又见伸手党
参考我们的串口中断.
这已经是参考过很多例子的,还是找不到原因,会不会和启动文件相关?我用的是STM32F10x.s,是每次建工程时系统自动生成的,请大侠们指点~~,感激不尽~~
建议你先做串口中断.做好了之后再稍作修改就可以适应485通信了.
你中断进不了,参考我们的串口实验.我们的串口实验有接收中断的(发送中断,没做.). 至于你说的很多例子,我不知道有没有我们的例子.因为网上很多开发板都是千篇一律的.. |
不知道是咋回事,之前在这个程序中写的ADC和DMA也都不能进中断,但是System tick就可以。现在程序我试过了,可以用查询方式去读收到的值,但就是不中断,可以确定是配置问题。用开发板上的例程改写的简单的485收发程序在自己划的板子上运行都收发自如,但自己配的就不行(驱动程序是单独写在一个.C文件里,会不会有影响?),请大侠帮忙看下程序,帮忙指点下错误,感激不尽~~
哦,搞定了,犯得错误有点弱智,就不说了,以上程序都是对的,没有问题,有需要的可以参考,感谢原子大哥的支持~
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4140 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3228 浏览 1 评论
2753 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2181 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14984 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3092浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1898浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2070浏览 3评论
1981浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2171浏览 3评论
/9
GMT+8, 2025-12-3 03:07 , Processed in 5.918474 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
11976
