扫一扫,分享给好友
为什么建立的DMA 工程会出现下列错误呢?
TEST.axf: Warning: L6373E: libattrs.map file not found in System Library directory D:Program FilesKeilARMRV31LIBarmlib. Library selection may be impaired. TEST.axf: Error: L6366E: Object dc.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object use_no_semi_2.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object __2printf.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object noretval__2printf.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object __printf.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object _printf_hex_ll.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object _printf_hex_int.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object _printf_hex_int_ll.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object _printf_hex_ptr.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object _printf_hex_int_ptr.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object _printf_hex_ll_ptr.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object _printf_hex_int_ll_ptr.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object __printf_flags.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object __printf_ss.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object __printf_flags_ss.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object __printf_wp.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object __printf_flags_wp.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object __printf_ss_wp.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object __printf_flags_ss_wp.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object _printf_x.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object _printf_percent.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object heapauxi.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object __main.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object fadd.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object fmul.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object fdiv.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object ffltui.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object ffixui.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object use_no_semi.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object rtentry.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object _printf_intcommon.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object _printf_char_common.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object _printf_percent_end.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object ferror.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object ferror_locked.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object iusefp.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object fepilogue.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object rtentry2.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object rtentry4.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object __printf_nopercent.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object sys_stackheap_outer.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object exit.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object boardinit1.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object boardinit2.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object boardinit3.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object libinit.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object libspace.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object rtexit.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object libinit2.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object fpinit.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object rtexit2.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6367E: Section .emb_text from object argv_veneer.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object boardshut.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object _get_argv_nomalloc.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object no_argv.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object libshutdown.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object sys_command.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object hrguard.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object defsig_rtmem_outer.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object defsig_rtmem_formal.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object libshutdown2.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object rt_raise.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object defsig_exit.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object defsig_rtmem_inner.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object __raise.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object defsig_general.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object sys_wrch.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object defsig.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object defsig_abrt_inner.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object defsig_fpe_inner.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object defsig_rtred_inner.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object defsig_stak_inner.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object defsig_pvfn_inner.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object defsig_cppl_inner.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object defsig_segv_inner.o attributes are not compatible with the provided cpu and fpu attributes. TEST.axf: Error: L6366E: Object defsig_other.o attributes are not compatible with the provided cpu and fpu attributes. Target not created |
3个回答
你还是学会新建工程再来建你现在的工程吧.
我已经解决了,是我安装的keil usion4有问题。
好犀利啊!!!!!!!!!!!!!!!!这么多错误
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
868 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
649 浏览 1 评论
410 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
324 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
725 浏览 2 评论
1470浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
143浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
180浏览 3评论
164浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
165浏览 3评论
GMT+8, 2024-6-26 11:39 , Processed in 1.439930 second(s), Total 81, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
