// // File: f2802x_examples_ccsv4/adc_soc/Example_F2802xAdcSoc.c // // title: F2802x ADC Start-Of-Conversion (SOC) Example Program. // // Group: C2000 // Target Device: TMS320F2802x // //! addtogroup example_list //! ADC Start-Of-Conversion (SOC)//! //! Interrupts are enabled and the ePWM1 is setup to generate a periodic //! ADC SOC - ADCINT1. Two channels are converted, ADCINA4 and ADCINA2. //! //! Watch Variables: //! //! - Voltage1[10] - Last 10 ADCRESULT0 values //! - Voltage2[10] - Last 10 ADCRESULT1 values //! - ConversionCount - Current result number 0-9 //! - LoopCount - Idle loop counter // // (C) Copyright 2012, Texas Instruments, Inc. //############################################################################# // $TI Release: f2802x Support Library v200 $ // $Release Date: Tue Jul 24 10:01:39 CDT 2012 $ //############################################################################# #include "DSP28x_Project.h" // Device Headerfile and Examples Include File #include "f2802x_common/include/adc.h" #include "f2802x_common/include/clk.h" #include "f2802x_common/include/flash.h" #include "f2802x_common/include/gpio.h" #include "f2802x_common/include/pie.h" #include "f2802x_common/include/pll.h" #include "f2802x_common/include/wdog.h" // Prototype statements for functions found within this file. interrupt void adc_isr(void); void Adc_Config(void); // Global variables used in this example: uint16_t LoopCount; uint16_t ConversionCount; uint16_t Voltage1[10]; uint16_t Voltage2[10]; ADC_Handle myAdc; CLK_Handle myClk; FLASH_Handle myFlash; GPIO_Handle myGpio; PIE_Handle myPie; PWM_Handle myPwm; void main(void) [ CPU_Handle myCpu; PLL_Handle myPll; WDOG_Handle myWDog; // Initialize all the handles needed for this application myAdc = ADC_init((void *)ADC_BASE_ADDR, sizeof(ADC_Obj)); myClk = CLK_init((void *)CLK_BASE_ADDR, sizeof(CLK_Obj)); myCpu = CPU_init((void *)NULL, sizeof(CPU_Obj)); myFlash = FLASH_init((void *)FLASH_BASE_ADDR, sizeof(FLASH_Obj)); myGpio = GPIO_init((void *)GPIO_BASE_ADDR, sizeof(GPIO_Obj)); myPie = PIE_init((void *)PIE_BASE_ADDR, sizeof(PIE_Obj)); myPll = PLL_init((void *)PLL_BASE_ADDR, sizeof(PLL_Obj)); myPwm = PWM_init((void *)PWM_ePWM1_BASE_ADDR, sizeof(PWM_Obj)); myWDog = WDOG_init((void *)WDOG_BASE_ADDR, sizeof(WDOG_Obj)); // Perform basic system initialization WDOG_disable(myWDog); CLK_enableAdcClock(myClk); (*Device_cal)(); //Select the internal oscillator 1 as the clock source CLK_setOscSrc(myClk, CLK_OscSrc_Internal); // Setup the PLL for x10 /2 which will yield 50Mhz = 10Mhz * 10 / 2 PLL_setup(myPll, PLL_Multiplier_10, PLL_DivideSelect_ClkIn_by_2); // Disable the PIE and all interrupts PIE_disable(myPie); PIE_disableAllInts(myPie); CPU_disableGlobalInts(myCpu); CPU_clearIntFlags(myCpu); // If running from flash copy RAM only functions to RAM #ifdef _FLASH memcpy(&RamfuncsRunStart, &RamfuncsLoadStart, (size_t)&RamfuncsLoadSize); #endif // Setup a debug vector table and enable the PIE PIE_setDebugIntVectorTable(myPie); PIE_enable(myPie); // Register interrupt handlers in the PIE vector table PIE_registerPieIntHandler(myPie, PIE_GroupNumber_10, PIE_SubGroupNumber_1, (intVec_t)&adc_isr); // Initialize the ADC ADC_enableBandGap(myAdc); ADC_enableRefBuffers(myAdc); ADC_powerUp(myAdc); ADC_enable(myAdc); ADC_setVoltRefSrc(myAdc, ADC_VoltageRefSrc_Int); // Enable ADCINT1 in PIE PIE_enableAdcInt(myPie, ADC_IntNumber_1); // Enable CPU Interrupt 1 CPU_enableInt(myCpu, CPU_IntNumber_10); // Enable Global interrupt INTM CPU_enableGlobalInts(myCpu); // Enable Global realtime interrupt DBGM CPU_enableDebugInt(myCpu); LoopCount = 0; ConversionCount = 0; // Configure ADC //Note: Channel ADCINA4 will be double sampled to workaround the ADC 1st sample issue for rev0 silicon errata ADC_setIntPulseGenMode(myAdc, ADC_IntPulseGenMode_Prior); //ADCINT1 trips after AdcResults latch ADC_enableInt(myAdc, ADC_IntNumber_1); //Enabled ADCINT1 ADC_setIntMode(myAdc, ADC_IntNumber_1, ADC_IntMode_ClearFlag); //Disable ADCINT1 Continuous mode ADC_setIntSrc(myAdc, ADC_IntNumber_1, ADC_IntSrc_EOC2); //setup EOC2 to trigger ADCINT1 to fire ADC_setSocChanNumber (myAdc, ADC_SocNumber_0, ADC_SocChanNumber_A4); //set SOC0 channel select to ADCINA4 ADC_setSocChanNumber (myAdc, ADC_SocNumber_1, ADC_SocChanNumber_A4); //set SOC1 channel select to ADCINA4 ADC_setSocChanNumber (myAdc, ADC_SocNumber_2, ADC_SocChanNumber_A2); //set SOC2 channel select to ADCINA2 ADC_setSocTrigSrc(myAdc, ADC_SocNumber_0, ADC_SocTrigSrc_EPWM1_ADCSOCA); //set SOC0 start trigger on EPWM1A, due to round-robin SOC0 converts first then SOC1 ADC_setSocTrigSrc(myAdc, ADC_SocNumber_1, ADC_SocTrigSrc_EPWM1_ADCSOCA); //set SOC1 start trigger on EPWM1A, due to round-robin SOC0 converts first then SOC1 ADC_setSocTrigSrc(myAdc, ADC_SocNumber_2, ADC_SocTrigSrc_EPWM1_ADCSOCA); //set SOC2 start trigger on EPWM1A, due to round-robin SOC0 converts first then SOC1, then SOC2 ADC_setSocSampleWindow(myAdc, ADC_SocNumber_0, ADC_SocSampleWindow_7_cycles); //set SOC0 S/H Window to 7 ADC Clock Cycles, (6 ACQPS plus 1) ADC_setSocSampleWindow(myAdc, ADC_SocNumber_1, ADC_SocSampleWindow_7_cycles); //set SOC1 S/H Window to 7 ADC Clock Cycles, (6 ACQPS plus 1) ADC_setSocSampleWindow(myAdc, ADC_SocNumber_2, ADC_SocSampleWindow_7_cycles); //set SOC2 S/H Window to 7 ADC Clock Cycles, (6 ACQPS plus 1) // Enable PWM clock CLK_enablePwmClock(myClk, PWM_Number_1); // Setup PWM PWM_enableSocAPulse(myPwm); // Enable SOC on A group PWM_setSocAPulseSrc(myPwm, PWM_SocPulseSrc_CounterEqualCmpAIncr); // Select SOC from from CPMA on upcount PWM_setSocAPeriod(myPwm, PWM_SocPeriod_FirstEvent); // Generate pulse on 1st event PWM_setCmpA(myPwm, 0x0080);// Set compare A value PWM_setPeriod(myPwm, 0xFFFF); // Set period for ePWM1 PWM_setCounterMode(myPwm, PWM_CounterMode_Up); // count up and start // Wait for ADC interrupt for(;;) [ LoopCount++; ] ] interrupt void adc_isr(void) [ //discard ADCRESULT0 as part of the workaround to the 1st sample errata for rev0 Voltage1[ConversionCount] = ADC_readResult(myAdc, ADC_ResultNumber_1); Voltage2[ConversionCount] = ADC_readResult(myAdc, ADC_ResultNumber_2); // If 10 conversions have been logged, start over if(ConversionCount == 9) [ ConversionCount = 0; ] else ConversionCount++; // Clear ADCINT1 flag reinitialize for next SOC ADC_clearIntFlag(myAdc, ADC_IntNumber_1); // Acknowledge interrupt to PIE PIE_clearInt(myPie, PIE_GroupNumber_10); return; ] |
6 个讨论
只有小组成员才能发言,加入小组>>
340 浏览 1 评论
535 浏览 2 评论
NA555DR VCC最低电压需要在5V供电,为什么用3.3V供电搭了个单稳态触发器也使用正常?
781 浏览 3 评论
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
655 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
1138 浏览 1 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
65浏览 29评论
172浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
255浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
205浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
60浏览 13评论
GMT+8, 2024-12-24 07:08 , Processed in 1.020832 second(s), Total 56, Slave 48 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
