u8 t;
u8 len; u16 times=0; NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置系统中断优先级分组2 delay_init(167); //延时初始化 uart_init(115200); //串口初始化波特率为115200_** LED_Init(); //初始化与LED连接的硬件接口 _ 就是我改变这个115200到其他数值,波特率寄存器不是应该会发生变化,但**_是寄存器的值为什么会没变????_* USART_InitStructure.USART_BaudRate = bound;//波特率设置 USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式 USART_InitStructure.USART_StopBits = USART_StopBits_2;//一个停止位 USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式 USART_Init(USART1, &USART_InitStructure); //初始化串口1 typedef struct { uint32_t USART_BaudRate; /*!< This member configures the USART communication baud rate. The baud rate is computed using the following formula: - IntegerDivider = ((PCLKx) / (8 * (OVR8+1) * (USART_InitStruct->USART_BaudRate))) - FractionalDivider = ((IntegerDivider - ((u32) IntegerDivider)) * 8 * (OVR8+1)) + 0.5 Where OVR8 is the "oversampling by 8 mode" configuration bit in the CR1 register. */ uint16_t USART_WordLength; /*!< Specifies the number of data bits transmitted or received in a frame. This parameter can be a value of @ref USART_Word_Length */ uint16_t USART_StopBits; /*!< Specifies the number of stop bits transmitted. This parameter can be a value of @ref USART_Stop_Bits */ uint16_t USART_Parity; /*!< Specifies the parity mode. This parameter can be a value of @ref USART_Parity @NOTE When parity is enabled, the computed parity is inserted at the MSB position of the transmitted data (9th bit when the word length is set to 9 data bits; 8th bit when the word length is set to 8 data bits). */ uint16_t USART_Mode; /*!< Specifies wether the Receive or Transmit mode is enabled or disabled. This parameter can be a value of @ref USART_Mode */ uint16_t USART_HardwareFlowControl; /*!< Specifies wether the hardware flow control mode is enabled or disabled. This parameter can be a value of @ref USART_Hardware_Flow_Control */ } USART_InitTypeDef; /** * @Brief USART Clock Init Structure definition */ typedef struct { uint16_t USART_Clock; /*!< Specifies whether the USART clock is enabled or disabled. This parameter can be a value of @ref USART_Clock */ uint16_t USART_CPOL; /*!< Specifies the steady state of the serial clock. This parameter can be a value of @ref USART_Clock_Polarity */ uint16_t USART_CPHA; /*!< Specifies the clock transition on which the bit capture is made. This parameter can be a value of @ref USART_Clock_Phase */ uint16_t USART_LastBit; /*!< Specifies whether the clock pulse corresponding to the last transmitted data bit (MSB) has to be output on the SCLK pin in synchronous mode. This parameter can be a value of @ref USART_Last_Bit */ } USART_ClockInitTypeDef; |
1个回答
没看到uart_init()这个函数。你可以直接去USART_InitStructure.USART_BaudRate = bound;//波特率设置这里改。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2776 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2379 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2255 浏览 0 评论
2367 浏览 1 评论
1625 浏览 1 评论
/9
GMT+8, 2025-12-1 19:10 , Processed in 0.701977 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2242
