***安格ALGOTEL AG9320 AG9300 AG9311 AG6320 AG6310 AG6201 AG6200 AG9310
Type-C转HDMI线,可以把手机一键连接到电视/电脑/投影仪等设备,进行分屏操作,互不影响,提高工作效率。 AG9320 TypeC转HDMI/VGA 功能特性: 嵌入式16位MCU 支持EDID和MCC通过 支持热插拔检测 固件升级支持外部SPI闪存 支持嵌入式HDCP 1.4 HDMI 1.4b TX支持4K@30Hz输出 VGA支持1920x1200p@60Hz输出 通过HDMI和VGA输出同时显示 2KV ESD性能 支持l下行扩频时钟(SSC) 适用范围 USB-C转接器 TypeC拓展坞 电视/投影仪TypeC接口 ALGOLTEK AG9311 is highly integration solution transmit video and audio streamfrom DP alternate mode over USB Type-C to HDMI output. The AG9311 providesDisplayPort 1.2 receiver over various @1.62Gbps, 2.7Gbps and 5.4Gbps up to 2 lanes;and supports HDMI frequencies up to 297MHz, which enables 4K x 2K@30Hz. Usereasily integrate AG9311 on any USB Type-C video conversion on dongles and dockingstations application. II. Features l DisplayPort -Compliant to DisplayPort specification Revision 1.2 -Support 1.62(RBR)/2.7(HBR)/5.4(HBR2) Gbps data rate -Support 1/2 Lane configurations -Down Spread Spectrum Clock (SSC) supported -Support Audio Extraction over I2S bus l HDMI -Compliant to HDMI1.4 and HDCP1.4 specifications -Support TMDS up to 3Gbps -Support resolution up to 4K x 2K @30Hz output -Pre-programmed with HDCP key -Transparent EDID and MCCS -Support LPCM 2-Channel of sample rate 48kHz/44.1KHz/32KHz l USB Type-C and Power Delivery -Support DisplayPort Alternate mode protocol -Compliant to USB Power Delivery specification Revision 3.0 -Integrated complete termination of the Type-C RP and RD resistors -Supports two USB Type-C port-Support USB Billboard function -Integrated USB2.0 Full-speed PHY l MCU System and Interface -Embedded 16 bit MCU on-chip -Embedded 64KB flash for firmware upgrade-Support I2C Master/Slave, UART and USB2.0 Full-speed-Support 3-Channel ADC-8bit resolutions Power Operation and ESD -3.3V: 3V to 3.6V operation -1.2V: 1.08 to 1.32V operation -1.2V Core power and 3.3V I/O power -HBM 2KV ESD performance |
GMT+8, 2025-12-1 20:25 , Processed in 0.613202 second(s), Total 68, Slave 49 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
756
