电子发烧友论坛|
在使用CC2541DK-MINI Revision 1.0.4开发板时,套件里有个cc2540 dongle,但dongle的驱动一直没安装上,驱动安装时参考的《swru270c.pdf》,驱动文件用的是 :C:Texas InstrumentsBLE-CC254x-1.4.2.2AccessoriesDrivers;
电脑相关软件环境:Microsoft .NET Framework 4.6.2版本,win7 64 位旗舰版系统。 所有的USB口都一样,不是USB口的问题,希望可以解答一下,谢谢。 安装时系统打印的log如下 >>> [Build Driver List - USBVID_0451&PID_16AA53556723123784071545] >>> Section start 2017/08/10 14:50:50.329 cmd: "C:windowssystem32mmc.exe" "C:windowssystem32devmgmt.msc" dvi: Searching for hardware ID(s): dvi: u***vid_0451&pid_16aa&rev_0009 dvi: u***vid_0451&pid_16aa dvi: Searching for compatible ID(s): dvi: u***class_02&subclass_02&prot_01 dvi: u***class_02&subclass_02 dvi: u***class_02 cpy: Policy is set to make all digital signatures equal. dvi: Enumerating INFs from path list 'c:texas instrumentsble-cc254x-1.4.2.2accessoriesdrivers' sig: [_VERIFY_FILE_SIGNATURE] 14:50:50.336 sig: Key = ccxxxx_u***_cdc.inf sig: FilePath = c:texas instrumentsble-cc254x-1.4.2.2accessoriesdriversccxxxx_u***_cdc.inf sig: Catalog = c:texas instrumentsble-cc254x-1.4.2.2accessoriesdriversccxxxx_u***_cdc.cat ! sig: Verifying file against specific (valid) catalog failed! (0x800b0109) ! sig: Error 0x800b0109: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider. sig: [_VERIFY_FILE_SIGNATURE exit(0x800b0109)] 14:50:50.391 sig: [_VERIFY_FILE_SIGNATURE] 14:50:50.392 sig: Key = ccxxxx_u***_cdc.inf sig: FilePath = c:texas instrumentsble-cc254x-1.4.2.2accessoriesdriversccxxxx_u***_cdc.inf sig: Catalog = c:texas instrumentsble-cc254x-1.4.2.2accessoriesdriversccxxxx_u***_cdc.cat sig: Success: File is signed in Authenticode(tm) catalog. sig: Error 0xe0000241: The INF was signed with an Authenticode(tm) catalog from a trusted publisher. sig: [_VERIFY_FILE_SIGNATURE exit(0xe0000241)] 14:50:50.422 dvi: Created Driver Node: dvi: HardwareID - USBVID_0451&PID_16AA dvi: InfName - c:texas instrumentsble-cc254x-1.4.2.2accessoriesdriversccxxxx_u***_cdc.inf dvi: DevDesc - TI CC2540 USB CDC Serial Port dvi: DrvDesc - TI CC2540 USB CDC Serial Port dvi: Provider - Texas Instruments dvi: Mfg - Texas Instruments dvi: ModelsSec - DeviceList.NTamd64 dvi: InstallSec - DriverInstall dvi: ActualSec - DriverInstall.NTAMD64 dvi: Rank - 0x00ff0001 dvi: Signer - Texas Instruments, Inc. dvi: Signer Score - Authenticode dvi: DrvDate - 04/05/2013 dvi: Version - 1.2.0.0 inf: Searched 1 INFs in directory: 'c:texas instrumentsble-cc254x-1.4.2.2accessoriesdrivers' <<< Section end 2017/08/10 14:50:50.427 <<< [Exit status: SUCCESS] >>> [DIF_SELECTBESTCOMPATDRV - USBVID_0451&PID_16AA53556723123784071545] >>> Section start 2017/08/10 14:50:50.427 cmd: "C:windowssystem32mmc.exe" "C:windowssystem32devmgmt.msc" dvi: Using exported function 'PortsClassInstaller' in module 'C:Windowssystem32MsPorts.Dll'. dvi: Class installer == MsPorts.Dll,PortsClassInstaller dvi: No CoInstallers found dvi: Class installer: Enter 14:50:50.429 dvi: Class installer: Exit dvi: Default installer: Enter 14:50:50.430 dvi: [Select Best Driver] dvi: Selected driver installs from section [DriverInstall] in 'c:texas instrumentsble-cc254x-1.4.2.2accessoriesdriversccxxxx_u***_cdc.inf'. dvi: Class GUID of device changed to: [4d36e978-e325-11ce-bfc1-08002be10318]. dvi: [DIF_DESTROYPRIVATEDATA] 14:50:50.431 dvi: Class installer: Enter 14:50:50.431 dvi: Class installer: Exit dvi: Default installer: Enter 14:50:50.432 dvi: Default installer: Exit dvi: [DIF_DESTROYPRIVATEDATA - exit(0xe000020e)] 14:50:50.432 dvi: Set selected driver complete. dvi: Selected: dvi: Description - [TI CC2540 USB CDC Serial Port] dvi: InfFile - [c:texas instrumentsble-cc254x-1.4.2.2accessoriesdriversccxxxx_u***_cdc.inf] dvi: Section - [DriverInstall] dvi: Signer - [Texas Instruments, Inc.] dvi: Rank - [0x00ff0001] dvi: [Select Best Driver - exit(0x00000000)] dvi: Default installer: Exit <<< Section end 2017/08/10 14:50:50.435 <<< [Exit status: SUCCESS] |
5 个讨论
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 13:33 , Processed in 1.207264 second(s), Total 60, Slave 49 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
787
