电子发烧友论坛|
求助,S3C4510的openocd.cfg该怎样写????
各位大侠,小弟今天收到了100问网的OpenJTAG。光盘里面只有2440的openocd.cfg。我试着改了这个文件以适合s3c4510。SparkFun也找过了。都未遂。郁闷,问问大家知不知道怎么写这个??我是用的ubuntu9.04。 我的openocd.cfg是: ----------------------------------------------------- daemon configuration telnet_port 4444 gdb_port 3333 #interface interface ft2232 jtag_speed 0 ft2232_vid_pid 0x1457 0x5118 #ft2232_layout "jtagkey_prototype_v1" ft2232_layout "jtagkey_prototype_v1" ft2232_device_desc "USB<=>JTAG&RS232" #use combined on interfaces or targets that can't set TRST/SRST separately reset_config srst_only srst_pulls_trst #jtag scan chain #format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE) jtag_device 4 0x1 0xf 0xe #target configuration daemon_startup reset #target #target ARM7tdmi target arm7tdmi little reset_halt 0 arm7tdmi-s_r4 run_and_halt_time 0 30 ----------------------------------------------------- 输出是: ----------------------------------------------------- Info: options.c:50 configuration_output_handler(): jtag_speed: 0, 0 Info: options.c:50 configuration_output_handler(): Command separately not found Info: options.c:50 configuration_output_handler(): Open On-Chip Debugger 1.0 (2008-10-04-09:26) svn:717 Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x1f0f0f0f (Manufacturer: 0x787, Part: 0xf0f0, Version: 0x1) Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x07070fff (Manufacturer: 0x7ff, Part: 0x7070, Version: 0x0) Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x07070fff (Manufacturer: 0x7ff, Part: 0x7070, Version: 0x0) Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x07070fff (Manufacturer: 0x7ff, Part: 0x7070, Version: 0x0) Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x07070fff (Manufacturer: 0x7ff, Part: 0x7070, Version: 0x0) Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x07070fff (Manufacturer: 0x7ff, Part: 0x7070, Version: 0x0) Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x07070fff (Manufacturer: 0x7ff, Part: 0x7070, Version: 0x0) Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x07070fff (Manufacturer: 0x7ff, Part: 0x7070, Version: 0x0) Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x07070fff (Manufacturer: 0x7ff, Part: 0x7070, Version: 0x0) Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x07070fff (Manufacturer: 0x7ff, Part: 0x7070, Version: 0x0) Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x07070fff (Manufacturer: 0x7ff, Part: 0x7070, Version: 0x0) Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x07070fff (Manufacturer: 0x7ff, Part: 0x7070, Version: 0x0) Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x07070fff (Manufacturer: 0x7ff, Part: 0x7070, Version: 0x0) Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x07070fff (Manufacturer: 0x7ff, Part: 0x7070, Version: 0x0) Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x07070fff (Manufacturer: 0x7ff, Part: 0x7070, Version: 0x0) Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x07070fff (Manufacturer: 0x7ff, Part: 0x7070, Version: 0x0) Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x07070fff (Manufacturer: 0x7ff, Part: 0x7070, Version: 0x0) Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x07070fff (Manufacturer: 0x7ff, Part: 0x7070, Version: 0x0) Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x07070fff (Manufacturer: 0x7ff, Part: 0x7070, Version: 0x0) Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x07070fff (Manufacturer: 0x7ff, Part: 0x7070, Version: 0x0) Error: jtag.c:1399 jtag_examine_chain(): number of discovered devices in JTAG chain (20) doesn't match configuration (1) Error: jtag.c:1400 jtag_examine_chain(): check the config file and ensure proper JTAG communication (connections, speed, ...) Error: jtag.c:1556 jtag_init_inner(): trying to validate configured JTAG chain anyway... Error: embeddedice.c:191 embeddedice_build_reg_cache(): unknown EmbeddedICE version (comms ctrl: 0xf93cfeb7) ----------------------------------------------------- |
5个回答
试试这个:
#fast enable
telnet_port 4444 gdb_port 3333 interface ft2232 jtag_speed 0 ft2232_vid_pid 0x1457 0x5118 ft2232_layout "jtagkey" #jtag_device 4 0x1 0xf 0xe #nand device s3c2440 0 ft2232_device_desc "USB<=>JTAG&RS232 A" #debug_level 3 # Target configuration for the Samsung 2440 system on chip # Tested on a S3C2440 Evaluation board # Processor : ARM920Tid(wb) rev 0 (v4l) # Info: JTAG device found: 0x0032409d (Manufacturer: 0x04e, Part: 0x0324, Version: 0x0) # [Duane Ellis 27/nov/2008: Above 0x0032409d appears to be copy/paste from other places] # [and I do not believe it to be accurate, hence the 0xffffffff below] if { [info exists CHIPNAME] } { set _CHIPNAME $CHIPNAME } else { set _CHIPNAME s3c2450 } if { [info exists ENDIAN] } { set _ENDIAN $ENDIAN } else { # this defaults to a bigendian set _ENDIAN little } if { [info exists CPUTAPID ] } { set _CPUTAPID $CPUTAPID } else { # force an error till we get a good number set _CPUTAPID 0x07926f0f } #jtag scan chain jtag newtap $_CHIPNAME cpu -irlen 4 -ircapture 0x1 -irmask 0x0f -expected-id $_CPUTAPID set _TARGETNAME [format "%s.cpu" $_CHIPNAME] target create $_TARGETNAME arm926ejs -endian $_ENDIAN -chain-position $_TARGETNAME -variant arm926ejs $_TARGETNAME configure -work-area-virt 0 -work-area-phys 0x200000 -work-area-size 0x4000 -work-area-backup 1 #reset configuration reset_config trst_and_srst |
有问题请联系我QQ
南方兄,谢谢你的回复,我在“http://openfacts.berlios.de/inde ... enOCD_configuration”上找到了答案,我写了一个s3c4510的opencfg.cfg,已经正常运行了,可以没有flash的配置,因为我还不太会。
除了Philips LPC2000系列的,其他的ARM7在小端情况下都是可以用了。当然,你的OpenJTAG是“jtagkey_prototype_v1”的版本,比如100问网的,其他的OpenJTAG要做少量修改。 ---------------------------------------- #Daemon configuration telnet_port 4444 gdb_port 3333 daemon_startup attach #JTAG interface configuration interface ft2232 jtag_speed 0 reset_config trst_and_srst jtag_device 4 0x1 0xf 0xe jtag_nsrst_delay 100 jtag_ntrst_delay 50 ft2232_vid_pid 0x1457 0x5118 ft2232_layout "jtagkey_prototype_v1" #ft2232_layout "jtagkey" ft2232_device_desc "USB<=>JTAG&RS232" #Target configuration target arm7tdmi little reset_run 0 arm7tdmi run_and_halt_time 0 50 ---------------------------------------- 打印的信息是: ---------------------------------------- root@ubuntu:~/Documents/Project/Exam/Led/0000/Led/OpenOcd# openocd Open On-Chip Debugger 1.0 (2008-10-04-09:26) svn:717 $URL: svn://svn.berlios.de/openocd/trunk/src/openocd.c $ Info: options.c:50 configuration_output_handler(): Open On-Chip Debugger 1.0 (2008-10-04-09:26) svn:717 Info: options.c:50 configuration_output_handler(): jtag_speed: 0, 0 Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x1f0f0f0f (Manufacturer: 0x787, Part: 0xf0f0, Version: 0x1) Info: server.c:78 add_connection(): accepting 'telnet' connection from 0 User: target.c:957 target_arch_state(): target state: halted User: armv4_5.c:307 armv4_5_arch_state(): target halted in ARM state due to debug request, current mode: Supervisor cpsr: 0x60000013 pc: 0x00015dec User: target.c:957 target_arch_state(): target state: running |
OpenJTAG V2、V3都是“jtagkey”的版本
只有小组成员才能发言,加入小组>>
296个成员聚集在这个小组
加入小组为什么点亮LED的例子放在NORFlash上跑会出现奇怪的现象?
2471 浏览 6 评论
2208 浏览 5 评论
韦东山老师推出的《玩转ARM裸机实战》课程将帮你以上问题一扫而光!
4836 浏览 1 评论
/9
GMT+8, 2025-12-14 12:38 , Processed in 0.809652 second(s), Total 84, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4874
