电子发烧友论坛|
当我使用错误输出时,我没有得到错误。前错误接缝的原因是在“直接I / O”的后读,但他没有发送一些东西到
interface.I可以在总线活动上控制它。什么可以负责运行时的不同beet和写入直接I / O的开发?Thomas --------原始消息--------主题 :RE:[vrf] [VRF]错误在运行时但不在开发周围(2005年8月12日13:37)来自:shawn@testech-ltd.comTo:tw@huber-online.com >>这是一个问题 输出错误?>>可能不是。 默认值(如当前目录)可以不同。>建议:将字符串发送到消息框,然后再转到相关的From> String。 这将帮助您弄清楚发生了什么。> -SHAWN- >>>> To:tw@huber-online.com> vrf@agilent.comTo:shawn@testech-ltd.comCc:vrf@agilent.com--- 您目前订阅了vrf:r***@soco.agilent.com要订阅,请发送一封空白电子邮件至“join-vrf@it.lists.it.agilent.com”。要取消订阅,请发送空白电子邮件至“leave-vrf @ it .lists.it.agilent.com“。要发送邮件到这个邮件列表,请发送电子邮件至”vrf@agilent.com“。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 以上来自于谷歌翻译 以下为原文 when I do it with a error output, than I don't get a error. The reason for the former error seams to be in the back-reading from the "direct I/O", but he didn't send something to the interface. I can control it on the bus activity. What can be responsible for the different beetween runtime an development in writing to direct I/O ? Thomas -------- Original Message -------- Subject: RE: [vrf] [VRF] error in runtime but not in development surrounding (12-Aug-2005 13:37) From: shawn@testech-ltd.com To: tw@huber-online.com > > Is that a problem with a error output? > > Probably not. Defaults such as current directory can be different. > Suggestion: send your string to a message box before it gets to the From > String in question. This will help you figure out what's going on. > -SHAWN- > > > > To: tw@huber-online.com > vrf@agilent.com To: shawn@testech-ltd.com Cc: vrf@agilent.com --- You are currently subscribed to vrf as: r***@soco.agilent.com To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". |
2个回答
>当我使用错误输出时,>我没有得到错误。好吧,如果错误输出连接到消息框会发生什么?
捕捉错误与捕捉错误和做些事情不一样。再说一次,我很确定你知道差异所以...>什么可以负责>不同的beetween run a>开发写作直接 > I / O?文件vee.io有一件事(也许)。 这取决于事物的设置方式,IO Config是否嵌入,如何启动运行时...- SHAWN ----您目前订阅vrf为:r***@soco.agilent.com要订阅发送一个 空白电子邮件至“join-vrf@it.lists.it.agilent.com”。要取消订阅,请发送空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。要向此邮件列表发送邮件, 发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 以上来自于谷歌翻译 以下为原文 > when I do it with a error output, > than I don't get a error. Well, if the error output is wired to a Message Box what happens? Catching an error is not the same as catching an error and doing something about it. Then again, I'm pretty sure you know the difference so... > What can be responsible for the > different beetween runtime an > development in writing to direct > I/O ? The file vee.io for one thing (maybe). It depends on how things are set up, whether or not your IO Config is embedded, how you start the runtime... -SHAWN- --- You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email] To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". |
>当我使用错误输出时,我没有得到错误。我想我突然想起在witherror引脚之前注意到的一些奇怪的行为,但我没有找到它(或者至少所有注意到的奇怪行为都没有
与错误引脚丢失错误有任何关系。)如果你真的*得到一个错误引脚的未被捕获错误,你赢得theprize:一个新发现的错误!-SHAWN ----你目前订阅了vrf as:r*** @ soco.agilent.com要订阅,请发送一封空白电子邮件至“join-vrf@it.lists.it.agilent.com”。要取消订阅,请发送空白电子邮件至“leave-vrf@it.lists.it.agilent.com” 。要发送邮件到此邮件列表,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 以上来自于谷歌翻译 以下为原文 > when I do it with a error output, than I don't get a error. I thought I suddenly remembered some strange behavior noticed before with error pins, but I didn't find it (or at least all the strange behaviors noticed don't have anything to do with error pins missing errors). If you really *are* getting an uncaught error with an error pin, you win the prize: a newly discovered bug! -SHAWN- --- You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email] To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 07:04 , Processed in 0.703684 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1483
