“Mark Carangi写道:>嗨; >>有没有人有使用VEE和来自Wentworth的LABMASTER软件的经验?>> LABMASTER旨在控制Wentworth生产的可编程>半自动分析晶圆探测器的XYZ定位。> LABMASTER是一个基于Windows的
图形应用程序,但不直接与测试和测量仪器接口,而是>(似乎)在PC>和探测器之间使用简单的TTL级别握手协议。我想添加一个GPIB接口并使用VEE来刺激 测量晶圆上芯片管芯的响应。> Wentworth已经记录了2个PC,3个GPIB卡配置,用于探测器和仪器控制。相反,我想使用一台PC并且> LABMASTER“呼叫”VEE 例程(或反之亦然?)。有没有人有> LABMASTER的经验?或者,更一般地说,我如何从LABMASTER内部调用VEE>例程或从VEE内部调用LABMASTER?通过网络快速阅读说Labmaster是ActiveX能力的, 所以 从VEE中获取它应该只是从Labmaster人那里得到正确的文档。 在那个poiunt你会把它作为VEE中的Active X自动化对象并从一个公式框中运行。从他们的支持人员开始并获得所需的文档 - 并希望使用ActiveX接口的示例程序或两个。取决于他们的代码如何 通过Active X-或直接从VEE控制Labmaster,你可以控制探测器,假设你也可以找到它的文档.Stan -------------------- -------------------------------------------------- 以上来自于谷歌翻译 以下为原文 "Mark Carangi wrote: > Hi; > > Does anyone have experience using VEE with LABMASTER software from > Wentworth? > > LABMASTER is designed to control the XYZ positioning of programmable > semiautomatic analytical wafer probers manufactured by Wentworth. > LABMASTER is a windows based graphical application but does not > interface to test and measurement instrumentation directly and instead > (appears) to use a simple TTL level handshake protocol between the PC > and the prober. I'd like to add a GPIB interface and use VEE to > stimulate and measure response from chip dies on the wafer under test. > Wentworth has documented a 2 PC, 3 GPIB card configuration for prober > and instrument control. I'd like, instead, to use one PC and have > LABMASTER "call" VEE routines (or vise versa?). Does anyone have > experience with LABMASTER? Or, more generally, how do I call VEE > routines from inside LABMASTER or call LABMASTER from inside VEE? quick perusal via the web says that Labmaster is ActiveX capable, so driving it from VEE should just be a case of getting the right docs from Labmaster folks. At that poiunt you'll be adding it as an Active X automation object in VEE and exercising it from a formula box. Start with their support folks and get the needed docs- and hopefully an example program or two using the ActiveX interface. Depending upon how their code works you'll be able to control the prober by controlling Labmaster via Active X- or directly from VEE assuming you can find the docs for that also. Stan |
1个回答
嗨,有没有人有使用Wentworth的VEEwith LABMASTER软件的经验?
LABMASTER设计用于控制由Wentworth制造的可编程半自动分析晶圆探测器的XYZ定位.LABMASTER是一个基于窗口的图形应用程序,但不直接与测试和测量仪器接口,而是(似乎)在PC和PC之间使用简单的TTL级别握手协议。 探测器。 我想添加一个GPIB接口,并使用VEE来激发和测量被测晶圆上芯片裸片的响应.Wentworth已经记录了一个用于探测器和仪器控制的2个PC,3个GPIB卡配置。我想,相反, 使用一台PC并让LABMASTER“调用”VEE例程(反之亦然?)。 有没有人有使用LABMASTER的经验? 或者,更一般地说,如何从LABMASTER内部调用VEE例程或从VEE内部调用LABMASTER?感谢提前标记---您目前订阅了vrf:r***@soco.agilent.com要订阅,请发送空白电子邮件至“join-vrf” @ it.lists.it.agilent.com“。要取消订阅,请发送一封空白电子邮件至”leave-vrf@it.lists.it.agilent.com“。要发送邮件至此邮件列表,请发送电子邮件至”vrf@agilent.com ”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 Hi; Does anyone have experience using VEE with LABMASTER software from Wentworth? LABMASTER is designed to control the XYZ positioning of programmable semiautomatic analytical wafer probers manufactured by Wentworth. LABMASTER is a windows based graphical application but does not interface to test and measurement instrumentation directly and instead (appears) to use a simple TTL level handshake protocol between the PC and the prober. I'd like to add a GPIB interface and use VEE to stimulate and measure response from chip dies on the wafer under test. Wentworth has documented a 2 PC, 3 GPIB card configuration for prober and instrument control. I'd like, instead, to use one PC and have LABMASTER "call" VEE routines (or vise versa?). Does anyone have experience with LABMASTER? Or, more generally, how do I call VEE routines from inside LABMASTER or call LABMASTER from inside VEE? Thanks in advance Mark ---You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email]To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
只有小组成员才能发言,加入小组>>
1033 浏览 0 评论
2278 浏览 1 评论
2065 浏览 1 评论
1937 浏览 5 评论
2808 浏览 3 评论
800浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
586浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
683浏览 0评论
2465浏览 0评论
1522浏览 0评论
GMT+8, 2024-9-21 07:05 , Processed in 1.335386 second(s), Total 79, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
