configure:3362: /shared/cross-gcc/build/build-ARM-none-cygwin/./gcc/xgcc -B/shared/cross-gcc/build/build-arm-none-cygwin/./gcc/ -B/usr/local/arm-none-eabi-cygwin/arm-none-eabi/bin/ -B/usr/local/arm-none-eabi-cygwin/arm-none-eabi/lib/ -isystem /usr/local/arm-none-eabi-cygwin/arm-none-eabi/include -isystem /usr/local/arm-none-eabi-cygwin/arm-none-eabi/sys-include -V >&5
xgcc: error: unrecognized command line option '-V' xgcc: fatal error: no input files compilation terminated. configure:3373: $? = 1 configure:3362: /shared/cross-gcc/build/build-arm-none-cygwin/./gcc/xgcc -B/shared/cross-gcc/build/build-arm-none-cygwin/./gcc/ -B/usr/local/arm-none-eabi-cygwin/arm-none-eabi/bin/ -B/usr/local/arm-none-eabi-cygwin/arm-none-eabi/lib/ -isystem /usr/local/arm-none-eabi-cygwin/arm-none-eabi/include -isystem /usr/local/arm-none-eabi-cygwin/arm-none-eabi/sys-include -qversion >&5 xgcc: error: unrecognized command line option '-qversion' xgcc: fatal error: no input files compilation terminated. configure:3373: $? = 1 configure:3389: /shared/cross-gcc/build/build-arm-none-cygwin/./gcc/xgcc -B/shared/cross-gcc/build/build-arm-none-cygwin/./gcc/ -B/usr/local/arm-none-eabi-cygwin/arm-none-eabi/bin/ -B/usr/local/arm-none-eabi-cygwin/arm-none-eabi/lib/ -isystem /usr/local/arm-none-eabi-cygwin/arm-none-eabi/include -isystem /usr/local/arm-none-eabi-cygwin/arm-none-eabi/sys-include -o conftest -g -O2 conftest.c >&5 Assembler messages: Fatal error: can't create /tmp/ccgZ7d6T.o: No such file or directory configure:3392: $? = 1 configure:3580: checking for suffix of object files configure:3602: /shared/cross-gcc/build/build-arm-none-cygwin/./gcc/xgcc -B/shared/cross-gcc/build/build-arm-none-cygwin/./gcc/ -B/usr/local/arm-none-eabi-cygwin/arm-none-eabi/bin/ -B/usr/local/arm-none-eabi-cygwin/arm-none-eabi/lib/ -isystem /usr/local/arm-none-eabi-cygwin/arm-none-eabi/include -isystem /usr/local/arm-none-eabi-cygwin/arm-none-eabi/sys-include -c -g -O2 conftest.c >&5 Assembler messages: Error: can't open /tmp/ccnR0jZR.s for reading: No such file or directory configure:3606: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "GNU C Runtime Library" | #define PACKAGE_TARNAME "libgcc" | #define PACKAGE_VERSION "1.0" | #define PACKAGE_STRING "GNU C Runtime Library 1.0" | #define PACKAGE_BUGREPORT "" | #define PACKAGE_URL "http://www.gnu.org/software/libgcc/" | /* end confdefs.h. */ | | int | main () | { | | ; | return 0; | } configure:3620: error: in `/shared/cross-gcc/build/build-arm-none-cygwin/arm-none-eabi/libgcc': configure:3623: error: cannot compute suffix of object files: cannot compile See `config.log' for more details. 出错的地方应该就是 xgcc 编译 conftest.c 没有生成临时文件,直接copy 上面的 C代码为 conftest.c 然后使用log中的命令也出现同样的错误。 /shared/cross-gcc/build/build-arm-none-cygwin/./gcc/xgcc -B/shared/cross-gcc/build/build-arm-none-cygwin/./gcc/ -B/usr/local/arm-none-eabi-cygwin/arm-none-eabi/bin/ -B/usr/local/arm-none-eabi-cygwin/arm-none-eabi/lib/ -isystem /usr/local/arm-none-eabi-cygwin/arm-none-eabi/include -isystem /usr/local/arm-none-eabi-cygwin/arm-none-eabi/sys-include -c -g -O2 conftest.c |
2个回答
有没有哪位大神遇到过相同问题的?如何解决?在BAIDU上找到一篇文章说 gcc.c 的配置模板 struct compiler default_compilers 定义了各种扩展名文件类型的编译方法,其中包含使用的编译器文件名,该文件么和 cygwin 不兼容(需要带后缀.exe),按照该方法修改,重新 configure 并重新编译,问题依旧。
帮顶 .....
只有小组成员才能发言,加入小组>>
请问下图大疆lightbridge2遥控器主板电源芯片型号是什么?
4474 浏览 1 评论
使用常见的二极管、三极管和mos做MCU和模组的电平转换电路,但是模组和MCU无法正常通信,为什么?
346浏览 2评论
为了提高USIM卡电路的可靠性和稳定性,在电路设计中须注意的点有哪些?
349浏览 2评论
372浏览 2评论
366浏览 2评论
416浏览 2评论
GMT+8, 2024-12-24 00:32 , Processed in 1.196137 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
