电子发烧友论坛|
大家好,我有原装hp 66311b,需要维修。
我正在寻找维修手册和原理图。 有谁知道如何获得一个。 我从安捷伦的网站上下载了服务手册,但主板与手册中显示的不一致。 电源通过所有自检。 转动显示后几秒显示“端口”,风扇进入高速档。 输出电压编程对输出电压没有影响,显示器显示“0.008V”,无论编程值是多少。谢谢'Mickey 以上来自于谷歌翻译 以下为原文 Hi All, I have original hp 66311b, which need repair. I am looking for the repair manual and schematic. Does anyone knows how to get one. I did downloaded service manual from Agilent's website, but main board doesn't match with one shown in the manual. Power supply passes all the self tests. A few seconds after turns on display shows "port" and fan goes into high gear. Programming of the output voltage has no effect on the output voltage with display showing "0.008V" no matter what is the programmed value. Thanks' Mickey |
3个回答
您好Mickey,我可以帮助您,我需要一些附加信息。
您的设备的序列号是多少?2。 该装置是否在前面板上说安捷伦?3。 当该单位进入“保护”什么是保护时,可以取消注意,OT,等等? 以上来自于谷歌翻译 以下为原文 Hello Mickey, I may be able to help you I need some aditional information. 1. What is the serial number of your unit? 2. Does the unit say Agilent on the front panel? 3. When the unit goes into "protect" what is the protect, could be unreg, OT, ect? |
“你好Mickey,我可以帮助你,我需要一些附加信息.1。你的设备的序列号是多少?2。设备是否在前面板上说安捷伦?3。当设备进入”保护“状态时
什么是保护,可以是unreg,OT等等?“嗨,这里是你要求的信息.1)看起来序列号在背面磨损了。 还有其他地方我可以找到序列号吗?2)设备说“HP”不是Agilent.3)在“保护”消息和风扇进入高速档显示之前短暂显示“过载”状态。 控制板为hp“5064-0088”序列号“8U101LD”。 主板是hp“66311-60021”序列号“2asyi”(黄色贴纸靠近AC连接器)。 两块板都是表面安装的。 Thanks'Mickey 以上来自于谷歌翻译 以下为原文 " Hi here are the information you requested. 1) It looks like serial number has worn off on the back. Is there an other place I can find the serial number? 2) The unit say "HP" not Agilent. 3) Before the "protect" message and fan going into high gear display show "overload" condition briefly. The control board is hp "5064-0088" serial number "8U101LD". the main board is hp "66311-60021" serial number "2asyi"(yellow sticker close to AC connector). Both boards are surface mounted. Thanks' Mickey |
http://cp.literature.agilent.com/litweb/pdf/5964-8176.pdfHello Mickey,上面的链接是服务手册。
拍摄信息时遇到一些麻烦。 本手册可以帮助您修理设备。不幸的是,主要没有包括所有原理图,因为该产品具有SMT组件。 整个组件将被替换的那个。 经测试的组件66311-61021不再可用。 该装置于1999年更换。建议:尝试使用上面的维修手册对本机进行故障排除。 该产品现在在交换中,对您来说可能更有成本效益交换许多SMT部件在推出SMT版本1999时不可用。如果您需要任何其他帮助,请告诉我! 以上来自于谷歌翻译 以下为原文 http://cp.literature.agilent.com/litweb/pdf/5964-8176.pdf Hello Mickey, The above link is the service manual. It has some trouble shooting information. The manual may help you repair the unit. Unfortunatly there is no over all schematic included mainally because this product has SMT assemblies. That ment that the entire assembly would be replaced. The tested assembly 66311-61021 is no longer avaliable. This unit was changed back in 1999. RECOMMENDATION: Try to trouble shoot the unit using the service manual above. The product is now on exchange it may be more cost affective for you the do the exchange Many of the SMT parts are not available at the time of introduction of the SMT version 1999. Let me know if you need any additional help! |
只有小组成员才能发言,加入小组>>
250 浏览 0 评论
1863 浏览 0 评论
2753 浏览 1 评论
2656 浏览 1 评论
2477 浏览 5 评论
1863浏览 0评论
431浏览 0评论
253浏览 0评论
/9
GMT+8, 2025-12-12 00:34 , Processed in 0.531009 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4973
