电子发烧友论坛|
嗨VRF关于删除库对象我有一个程序,其设计尽可能灵活。
因此,当进行测量时,数据通过“后处理器”。 处理器加载到函数库中,处理数据并输出答案。 到目前为止,这种方法运作良好。 但我觉得删除库函数没有释放用过的内存。最后我检查页面文件的使用率超过1GB,当veerun.exe报告少得多。 当程序关闭时,页面文件的使用率降至400mb左右。有一种方法可以确保程序在删除导入的用户功能时释放已用完的内存。 感谢Jacob Meachen ---您目前订阅了vrf:ming_meng@agilent.com要订阅,请发送电子邮件至:“vrf-request@lists.it.agilent.com”,邮件正文中包含subscribe一词。 要取消订阅,请发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。 要将邮件发送到此邮件列表,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 在“http://www.vrfarchive.com/vrf_archive”上搜索“unofficial vrf archive”。 在“http://vee.engineering.agilent.com”上搜索Agilent vrf存档。 以上来自于谷歌翻译 以下为原文 Hi VRF Concerning the delete library object I have a program which was designed to be as flexible as possible. Thus when a measurement is made, the data get passed through a "post processor". The processor loads in function libraries, processes the data and outputs an answer. So far this method has worked very well. But I get the feeling that the delete library function does not free up used memory. Last time I checked the page file usage goes up beyond 1GB when the veerun.exe is reporting much less. When the program closes the page file usage goes down to around 400mb. Is there a way to make sure that the program frees up used memory when the imported user functions are deleted. Thanks Jacob Meachen --- You are currently subscribed to vrf as: ming_meng@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com". |
2个回答
以上来自于谷歌翻译 以下为原文 Search the Agilent vrf archive at "http://vee.engineering.agilent.com". |
嗨,VRF!我在使用VEE 8.5仪器管理器上的“查找”按钮时遇到了一个问题。我的连接专家与仪器有连接,但当我点击时,我的VEE找不到连接到我电脑的任何接口
仪器管理器上的“查找”按钮。所以我尝试使用旧版I / O(默认首选项èI/ O选项卡è选中“启用Pre 8.0旧版I / O”复选框),然后确定。有人知道如何 我可以在不使用“添加仪器...”按钮的情况下设置非传统I / O吗?作为参考,我在我的系统上安装了三个版本的VEE Pro(7.5,8.0,8.5)。最好的问候!我的电子邮件地址有 已从jhchang@kornets.co.kr更改为HYPERLINK“mailto:jhchang@lxi.co.kr”jhchang@lxi.co.krsince 2008年1月15日.--------------- -------------------------------------------------- -------------------------------------------------- -------------------------------------------------- ------------------- Jin-Ho CHANGManagerKORNETS Co.,Ltd.TEL:031-563-9661,010-2024-7830FAX:0303-0799- 1090HYPERLINK“mailto:jhchang@lxi.co.kr”jhchang@lxi.co.krhttp://www.lxi.co.kr---您目前订阅了vrf:ming_meng@agilent.com要订阅,请发送给我们 发送电子邮件至:“vrf-request@lists.it.agilent.com”,邮件正文中包含“subscribe”字样。 要取消订阅,请发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。 要将邮件发送到此邮件列表,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 在“http://www.vrfarchive.com/vrf_archive”上搜索“unofficial vrf archive”。 在“http://vee.engineering.agilent.com”上搜索Agilent vrf存档。 以上来自于谷歌翻译 以下为原文 Hi, VRF! I’ve a question for using a “Find” Button on the Instrument Manager of VEE 8.5 My Connection Expert has a connection to an instrument, but my VEE can’t find any interfaces connected to my PC when I click the “Find” button on the Instrument Manager. So I have tried to use Legacy I/O (Default Preferences è I/O tab è Check an “Enable Pre 8.0 Legacy I/O” check box), then OK. Does anyone know how can I set the non legacy I/O without use “Add Instrument…” button? As reference, I have installed the three versions of VEE Pro(7.5, 8.0, 8.5) on my system. Best Regards! My e-mail address has been changed from jhchang@kornets.co.kr to HYPERLINK "mailto:jhchang@lxi.co.kr"jhchang@lxi.co.kr since January 15, 2008. ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Jin-Ho CHANG Manager KORNETS Co., Ltd. TEL : 031-563-9661, 010-2024-7830 FAX : 0303-0799-1090 HYPERLINK "mailto:jhchang@lxi.co.kr"jhchang@lxi.co.kr http://www.lxi.co.kr --- You are currently subscribed to vrf as: ming_meng@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com". |
只有小组成员才能发言,加入小组>>
315 浏览 0 评论
1872 浏览 0 评论
2757 浏览 1 评论
2659 浏览 1 评论
2480 浏览 5 评论
1872浏览 0评论
438浏览 0评论
319浏览 0评论
/9
GMT+8, 2025-12-18 06:54 , Processed in 0.720697 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4023
