电子发烧友论坛|
你好,
为了在我的BlueNRG-MS设备上拥有6个以上的服务,我想创建一个可以添加/删除其他服务的服务。 一开始,它运作良好,我可以选择我想要激活的服务,但很快就会出现问题。实际上,在删除特性和服务后似乎没有释放内存:在少量添加/删除之后,由于内存不足错误,我不能再添加服务了。 我使用aci_gatt_del_char和aci_gatt_del_service函数来删除服务,但是还有什么可做的吗? 谢谢, 朱利安 #bluenrg-ms #ble 以上来自于谷歌翻译 以下为原文 Hello, In order to have more than 6 services on my BlueNRG-MS device, I wanted to create a service that will add/remove the other ones. At the beginning, it worked well, I could choose the services I wanted to activate but quickly, a problem appear. Indeed, it seems that the memory is not freed after deleting characteristics and services : after few adding/removing, I can't anymore add service because of a out of memory error. I use the aci_gatt_del_char and aci_gatt_del_service functions to remove a service but is there something more to do ? Thanks, Julien #bluenrg-ms #ble |
3个回答
嗨朱利安,
目前的实施 aci_gatt_del_char 和 aci_gatt_del_service 没有释放记忆。 Marchese.Graziella 可以提供进一步的信息。亲切的问候 安德里亚 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Hi Julien, the current implementation of the aci_gatt_del_char and aci_gatt_del_service doesn't free memory. Marchese.Graziella can provide further info.‌Kind regards Andrea Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
亲爱的顾客,
正如Andrea在函数之前所说的那样,aci_gatt_del_char()和aci_gatt_del_service()无法正常工作,因为它们没有正确地重新分配用于存储属性值的内存区域。 因此我们建议不要使用它们,而是删除characteriscitc和service重启系统(GATT init和 GAP init)并重新插入正确的服务和特性。 问候, Graziella酒店 以上来自于谷歌翻译 以下为原文 Dear Customer, as Andrea has said before the functions aci_gatt_del_char() and aci_gatt_del_service() don't work properly because they don't reallocate properly the memory area used to store attribute values. Therefore we suggest to not use them, instead to delete characteriscitc and service reboot the system (GATT init and GAP init) and re-insert the correct services and characteristics. Regards, Graziella |
不,在重新初始化GATT和GAP后,连接将丢失。
以上来自于谷歌翻译 以下为原文 No, after a re-initialization of GATT and GAP the connections will be lost. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1472 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1524 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3674 浏览 1 评论
3864 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2483 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
752浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
684浏览 5评论
730浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
975浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
779浏览 5评论
/9
GMT+8, 2025-12-14 13:40 , Processed in 0.812377 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1450
