大家好,我是个新手,现在在做一个数字音频功放项目,模拟音频信号输入CS5340转换成24位的数字信号经过I2S送给TAS5731M,TAS5731M配置成PBTL模式,输出至喇叭,滤波频率设置成20Hz到100Hz。原理图已经画好做出样板了,但CS5340和TAS5731M的文档我翻了好几遍,发现它们都不能提供MCLK,现在的图上两边的主时钟就是直接连上的,开始以为是作主机的CS5340会提供主时钟的,结果好像不是这样。
以下是找的网上的初始化参数设置,现在板子一点反应也没有,怎么也工作不了,请各位大神帮忙看一看。 首先硬件上是不是还需要一个提供一个外部MCLK给这两个芯片的I2S用,再有就是下面这个初始化程序还有哪些地方不对。 void tas_PUP(void) [ const uint8_t out_MuxReg[4] = [0x01,0x00,0x22,0x45]; //addr = 0x25,ti ?§3?é??? const uint8_t in_MuxReg[4] = [0x00,0x99,0x77,0x72]; //addr = 0x20,BD mode,select R_CH to PBTL uint8_t i; // code uint8_t out_MuxReg[4] = [0x01,0x01,0x23,0x45]; //addr = 0x25,TI ???????t // code uint8_t out_MuxReg[4] = [0x01,0x10,0x32,0x45]; //addr = 0x25,datasheet pag25 // code uint8_t in_MuxReg[4] = [0X00,0X88,0X77,0X72]; //addr = 0x20,BD mode,select L_CH to PBTL tas_nRST = 0; RST_5340 = 0; M0_5340 = 0; M1_5340 = 0; tas_delay(1000); tas_nRST = 1; RST_5340 = 1; tas_delay(1000); sendbuf[0] = 0x00; writeNbyte(0x1b,1); //Trim oscillator (write 0x00 to register 0x1B) and wait at least 50 ms //PutStr("Trim oscillatorn"); tas_delay(2000); /****************Configure the DAP via I2C****************/ sendbuf[0] = 0x80; writeNbyte(0x03,1); //sys ctrl reg 1;Soft unmute on recovery from clock error //tas_WrByte(0X05,0x04); //éè??I2Sêy?Y??ê?£?24bit I2S PHLIP mode //tas_WrByte(0X30,0x07); //éè??master volume for 0dB sendbuf[0] = 0x30; writeNbyte(0x07,1); sendbuf[0] = 0xB8; writeNbyte(0x11,1); //for BD mode , if chg to AD mode,need chg the conf sendbuf[0] = 0x60; writeNbyte(0x12,1); //for BD mode,System ??è??aAD?£ê? sendbuf[0] = 0xA0; writeNbyte(0x13,1); //for BD mode sendbuf[0] = 0x48; writeNbyte(0x14,1); //for BD mode for(i=0;i<4;i++) [ sendbuf = in_MuxReg; ] writeNbyte(0x20,4); for(i=0;i<4;i++) [ sendbuf = out_MuxReg; ] writeNbyte(0x25,4); sendbuf[0] = 0x3A; writeNbyte(0x19,1); //for PBTL mode /*********************Exit shutdown***********************/ sendbuf[0] = 0x00; //0x02 writeNbyte(0x05,1); //exit shutdown command may not be serviced for as much as 240 ms //after trim following AVDD/DVDD power-up ramp //ADR/FAULT pin is configured as fault output tas_delay(2000); //tas_WrByte(0X30,0x07);//éè??master volume for 0dB //tas_WrByte(0Xc0,0x08);//éè?? CH1 ò?á? ] |
2 个讨论
只有小组成员才能发言,加入小组>>
351 浏览 1 评论
545 浏览 2 评论
NA555DR VCC最低电压需要在5V供电,为什么用3.3V供电搭了个单稳态触发器也使用正常?
790 浏览 3 评论
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
660 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
1140 浏览 1 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
84浏览 29评论
298浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
261浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
210浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
68浏览 13评论
GMT+8, 2024-12-28 07:00 , Processed in 1.018713 second(s), Total 57, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
