电子发烧友论坛|
开发板很久没用了,用nandflash的U-boot启动内核失败,然后自动重启U-boot,串口打印如下内容,求大神帮忙看看是什么问题
Reading data from 0x25f800 -- 100% complete. 2097152 bytes read: OK ## Booting image at 30007fc0 ... Image Name: Linux-2.6.22.6 Created: 2013-08-23 7:33:38 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1848668 Bytes = 1.8 MB Load Address: 30008000 Entry Point: 30008000 Verifying Checksum ... OK XIP Kernel Image ... OK Starting kernel ... Uncompressing Linux...................................................................................................................... done, booting the kernel. Linux version 2.6.22.6 (book@book-desktop) (gcc version 3.4.5) #1 Fri Aug 23 15:33:35 CST 2013 CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177 Machine: SMDK2440 Memory policy: ECC disabled, Data cache writeback CPU S3C2440A (id 0x32440001) S3C244X: core 400.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz S3C24XX Clocks, (c) 2004 Simtec Electronics CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on CPU0: D VIVT write-back cache CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets Built 1 zonelists. Total pages: 16256 Kernel command line: noinitrd root=/dev/mtdblock3 init=/linuxrc console=ttySAC0 irq: clearing pending ext status 00080000 irq: clearing subpending status 00000003 irq: clearing subpending status 00000002 PID hash table entries: 256 (order: 8, 1024 bytes) timer tcon=00500000, tcnt a2c1, tcfg 00000200,00000000, usec 00001eb8 Console: colour dummy device 80x30 Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 64MB = 64MB total Memory: 60976KB available (3264K code, 458K data, 140K init) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok NET: Registered protocol family 16 S3C2410 Power Management, (c) 2004 Simtec Electronics S3C2440: Initialising architecture S3C2440: IRQ Support S3C2440: Clock Support, DVS off S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics DMA channel 0 at c4800000, irq 33 DMA channel 1 at c4800040, irq 34 DMA channel 2 at c4800080, irq 35 DMA channel 3 at c48000c0, irq 36 SCSI subsystem initialized u***core: registered new interface driver u***fs u***core: registered new interface driver hub u***core: registered new device driver u*** NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered NetWinder Floating Point Emulator V0.97 (double precision) Registering GDB sysrq handler JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc. yaffs Aug 23 2013 15:33:07 Installing. io scheduler noop registered io scheduler anticipatory registered (default) io scheduler deadline registered io scheduler cfq registered U-Boot 1.1.6 (Nov 26 2010 - 08:49:16) DRAM: 64 MB Flash: 0 kB NAND: 256 MiB In: serial Out: serial Err: serial UPLLVal [M:38h,P:2h,S:2h] MPLLVal [M:5ch,P:1h,S:1h] CLKDIVN:5h |
相关推荐 |
只有小组成员才能发言,加入小组>>
296个成员聚集在这个小组
加入小组为什么点亮LED的例子放在NORFlash上跑会出现奇怪的现象?
2466 浏览 6 评论
2201 浏览 5 评论
韦东山老师推出的《玩转ARM裸机实战》课程将帮你以上问题一扫而光!
4828 浏览 1 评论
/9
GMT+8, 2025-12-2 03:57 , Processed in 0.619022 second(s), Total 75, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1596
