你好,
我需要精确测量正弦频率的频率,容限为0.01赫兹。主振荡器被设置为24MHz的外部晶体(低ppm和温度ToIP COEF)。 除了网站上提供的众多主题和文档之外,有没有人有线索或轨道来进行如此精确的测量? 当做, 米歇尔 以上来自于百度翻译 以下为原文 Hello, I need to accurately measure the frequency of a sinusoïde with a tolerance of 0.01 Hz. The master oscillator is set to 24Mhz by an external crystal (low ppm & temp coef.). Apart from the numerous topics & documentation available on the site, does anybody have a clue or a track for such an accurate measurement? Regards, Michel |
2个回答
不太复杂:
MAXF = 350hz *100 = 35khz测量频率,当我们加倍(Nyquist)我们得到的东西一样,100khz。 信号调理器和比较器为计数器触发信号的捕获。计数器的计数,在重新捕获中断在捕捉,所以有足够的时间去捕获的价值和用它做什么。 鲍勃 以上来自于百度翻译 以下为原文 Not too complicated: Maxf = 350Hz * 100 = 35kHz measurement frequency, When we double that (Nyquist) we get something like 100kHz. Signal conditioning and a comparator give a trigger signal for a counter's capture. Counter is counting up, reloaded at capture, interrupt at capture, so there is time enough to get the captured value and do something with it. Bob |
鲍勃,
柜台:H: γ-ELIF(CtRefEnguleStand Lt:16U)/* 16位计数器*/yIF(CysPSOC3)/*8位地址空间*/y*定义cTrfEnthyStAutoCurtTylLSB(*(Req16*)cTrfEnthysAdUdBbSc16OrdpUu0Fy0FReg) 很难猜测CfTuffiSnistAutoTytTyLSB与FIFO有关(即使@ F0/F1被称为TRM中属于UDB的FIFO寄存器)。 没关系,非常感谢。 以上来自于百度翻译 以下为原文 Bob, In Counter.h: #elif(CTRFrequence_Resolution <= 16u) /* 16-bit Counter */ #if(CY_PSOC3) /* 8-bit address space */ #define CTRFrequence_STATICCOUNT_LSB (*(reg16 *) CTRFrequence_CounterUDB_sC16_counterdp_u0__F0_REG ) Difficult to guess that CTRFrequence_STATICCOUNT_LSB is related to the FIFO (even if @F0/F1 are mentionned as the FIFO registers belonging to the UDB in the TRM). No matter, thanks a lot. |
只有小组成员才能发言,加入小组>>
717个成员聚集在这个小组
加入小组1903 浏览 1 评论
1655 浏览 1 评论
3410 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1570 浏览 6 评论
1382 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
191浏览 2评论
184浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
325浏览 2评论
352浏览 1评论
63浏览 1评论
GMT+8, 2024-4-27 15:23 , Processed in 0.614100 second(s), Total 74, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
