电子发烧友论坛|
“Al,当你从这个线程开始这个局域网,所以我继续在这里。我已经使用低级套接字编程并且可以处理它,但正如你所说,安捷伦用户程序员手册中有现成的LAN例程,并且还有文件
在我的电脑里。唯一阻止我的是O-scope我把它作为一个用过的,它上面有windows 98,它似乎无法识别我们的局域网,我试着按照他们在手册中说的那样 设置以太网:转到属性等....但我没有成功将范围连接到以太网。可能Windows版本是旧的,没有一些驱动程序.....我想我应该安装Windows 7例如? 覆盖事物是否有风险或者可以做到?“Rachid,我把这个讨论恰当地转移到了一个新线程。 首先,旧的示波器无法升级到Windows 7甚至XP。 主板无法处理它,范围FW将无法正常工作。 在范围界面下只有一台PC,运行(在您的情况下)Windows 95.您不应该使用Scope FW内置的LAN控制功能,而应该转到Windows并按照您想要的方式进行设置。 将键盘连接到示波器,然后重新启动它。 一旦它运行,使用“Windows”键(如果键盘有一个),或进入Windows菜单。 进入后,您可以使用cmd窗口或控制面板正确设置网络参数。 通过在作用域中使用ping来验证是否正确设置了内容。 如果您无法从那里开始工作,那么您的示波器上的LAN端口是坏的,或者您的网络上还有其他问题。 AlEdited by:algoss on April 4,2012 10:50 AM 以上来自于谷歌翻译 以下为原文 "Al, As you started here in this thread to discsuss LAN so I continue here. I already worked with low level sockets programming and can deal with it but as you said there are ready LAN routines in Agilent user programmer's manual and also have the files in my computer. The only thing that block me here is the O-scope I get it a used one and it has windows 98 on it and it seems it does not recognize our LAN, I tried to follow what they said in the manual to setup the ethernet: going to properties etc .... but I did not succeed to connect the scope to ethernet. Probably windows version is old and did not has some drivers ..... I think I should install windows 7 for example? is it risky to overwrite things or it can be done? " Rachid, I properly moved this discussion to a new thread. First, the older oscilloscopes can not be upgraded to Windows 7 or even XP. The Motherboard can't handle it, and the scope FW won't work. Under the scope interface is just a PC, running (in your case) Windows 95. Rather than using the LAN control capabilities built into the Scope FW, you should go to Windows and set things up the way you want. Attach a keyboard to the scope, and reboot it. Once it's running, use the "Windows" key (if the keyboard has one), or to get to the windows menu. Once you are there, you can use a cmd window, or Control Panel, to set the network parameters correctly. Verify that you have things set properly by using ping, both to and from the scope. If you can't get it working from there, then either the LAN port on your scope is bad, or you have some other problem on your network. Al Edited by: algoss on Apr 4, 2012 10:50 AM |
4 个讨论
Rachid,最好的方法是等待范围完全启动,包括范围应用程序,然后获取Windows菜单。
如果您过早地尝试,则可能会干扰范围应用程序。 除了正确设置网络并进行测试之外,请不要对Windows设置进行任何其他更改。 通过允许范围应用程序进行图标化,后期范围使Windows更易于访问。 目前,我们建议用户定期运行Microsoft Update,并加载一些防病毒软件。 这在90年代中期并不容易或推荐。 人 以上来自于谷歌翻译 以下为原文 Rachid, The best way is to wait for the scope to boot fully, including the scope application, then get the Windows menu. If you try it too early, you can interfere with the scope application. Please don't make any other changes to the Windows settings, besides setting the network up appropriately, and testing it. Later scopes made Windows more easily accessible, by allowing the scope application to be iconified. These days, we recommend that the user run Microsoft Update on a regular basis, and have some antivirus SW loaded. That was not easily possible or recommended back in the mid-90's. Al |
nvywyerwer 发表于 2019-7-29 16:45 Al,网络现在已经设置好,之前已经设置好了。 只是找到用于命令通信的IP,因为运行命令“ipconfig”将打开一个窗口并立即消失,没有时间查看输出和IP。 要开始测试命令,我们所拥有的示例文件是针对Windows而我在Linux中工作的。 此外,例如,在示例中打开一个带有o-scope的连接(路径描述符),他们调用一个以IP地址作为输入的例程,但它似乎是来自他们创建的库,我没有这个库用于linux和 还没有在Linux中创建它的代码。 拉希德 以上来自于谷歌翻译 以下为原文 Al, Network is set now and I things were already set before. Just to find the IP to use it for commands communication because running the command "ipconfig" will open a window and disappear immediately and do not have time to look at the output and IP. To start testing commands the examples files we have are done for windows nd I am working in Linux. Also it seems for example to open a connection (path descriptor) with the o-scope in the example they call a routine with IP address as input but it seems it's from a library that they created and I do not have this library for linux and do not also have the code to create it in Linux. Rachid |
cmh23 发表于 2019-7-29 16:51 Rachid,要检查作用域上的网络设置,首先需要打开命令窗口(运行'cmd'),然后在该窗口中执行ipconfig。 窗口将保持打开状态,直到你关闭它为止。至于在Linux中工作......我从未在Linux中进行过软件开发。 我在UNIX中做了很多,但那是在15年前。 我查看了安捷伦网站上的应用说明,并且有一些使用VXI和TCP进行仪器控制的示例。 这些概念与Windows相同,只是实际的实现方式不同。 您建立与仪器的连接,发送请求,获取响应,并最终关闭连接。 您应该打开标题为“从Linux控制范围”的主题。 您可能会找到可以提供帮助的人,但是他们跳过了这个主题,因为它并不能真正描述您的问题。 人 以上来自于谷歌翻译 以下为原文 Rachid, To check the network settings on the scope, you need to first open a command window (Run 'cmd'), THEN execute ipconfig in that window. The window will stay open until you close it.. As for working in Linux... I have never done SW development in Linux. I did quite a bit in UNIX, but that was more than 15 years ago. I have looked at the Application Notes on the Agilent Website, and there are some examples using both VXI and TCP for instrument control. The concepts are the same as for Windows, just the actual implementation is different. You make a connection to the instrument, send requests, get responses, and eventually close the connection. You should maybe open a thread titled, "Controlling a Scope from Linux". You might find someone who can help,but who skipped over this topic, since it's not really descriptive of what your issue is. Al |
nvywyerwer 发表于 2019-7-29 17:00 Al,是的,我也使用TCP / IP套接字,我可以快速检索我为其他应用程序编写的旧代码。 我刚刚问你可能现在有一个现成的代码可供使用。 我现在将打开新线程。 谢谢Rachid 以上来自于谷歌翻译 以下为原文 Al, Yes also I worked using TCP/IP sockets and I can retrieve quickly old code I wrote for other applications. I just asked you probably there is somewhere a ready code to use now. I will open now the new thread. Thank you, Rachid |
只有小组成员才能发言,加入小组>>
1846 浏览 0 评论
2740 浏览 1 评论
2641 浏览 1 评论
2451 浏览 5 评论
3461 浏览 3 评论
1849浏览 0评论
422浏览 0评论
/9
GMT+8, 2025-12-3 20:35 , Processed in 0.902957 second(s), Total 50, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
25959
