电子发烧友论坛|
你好,
我正在尝试从提供的HDMI输入获取VGA输出。 为此我尝试了xapp495代码的解码器部分代码。 所以现在当我提供HDMI输入时,我获得的HSync和Vsync频率是45 KHz和60 Hz,720p @ 60 Hz分辨率。 然后我的显示器上也会显示“超出范围”之类的错误。 任何人都可以帮我弄清楚出了什么问题!! 我的显示器支持分辨率高达1080p。 谢谢 以上来自于谷歌翻译 以下为原文 Hello, I'm trying to obtain the VGA output from the HDMI input provided. For this I tried out xapp495 code's decoder part of code. So now when I provide the HDMI input the HSync and Vsync frequency I obtain is 45 KHz and 60 Hz for 720p @ 60 Hz resolution. Then too on my monitor it shows the error like " Out of Range". Can anybody help me to figure out what is going wrong !! And my monitor support resolution upto 1080p. Thanks |
2个回答
---我的显示器支持分辨率高达1080p。
本应用笔记XAPP495成功演示了一种高清TMDS视频连接解决方案,该解决方案具有并行处理多个高清频道的功能。 该设计演示了DVI或HDMI应用中的Spartan-6 FPGA(包括480p,1080i和720p视频格式)。 请注意,1080i和1080p具有相同的分辨率,但它们并不完全相同。 所以我不确定XAPP495对1080p的演示。 _______________________________________________如果有助于解决您的查询,请将此帖子标记为“接受为解决方案”。 因此,它将有助于其他论坛用户直接参考答案。如果您认为该信息有用且面向答复,请给予此帖子称赞。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 --- And my monitor support resolution upto 1080p. This application note XAPP495 successfully demonstrates a high-definition TMDS video connectivity solution featuring the processing of multiple HD channels in parallel. The design demonstrates the Spartan-6 FPGA in DVI or HDMI applications (including the 480p, 1080i, and 720p video formats). Please note that 1080i and 1080p are having the same resolution but they aren't exactly the same. So I am not sure about XAPP495 demonstratiion with 1080p. ________________________________________________ Please mark this post as an "Accept as solution" in case if it helped to resolve your query. So that it will help to other forum users to directly refer to the answer. Give kudos to this post in case if you think the information is useful and reply oriented. View solution in original post |
本应用笔记XAPP495成功演示了一种高清TMDS视频连接解决方案,该解决方案具有并行处理多个高清频道的功能。 该设计演示了DVI或HDMI应用中的Spartan-6 FPGA(包括480p,1080i和720p视频格式)。 请注意,1080i和1080p具有相同的分辨率,但它们并不完全相同。 所以我不确定XAPP495对1080p的演示。 _______________________________________________如果有助于解决您的查询,请将此帖子标记为“接受为解决方案”。 因此,它将有助于其他论坛用户直接参考答案。如果您认为该信息有用且面向答复,请给予此帖子称赞。 以上来自于谷歌翻译 以下为原文 --- And my monitor support resolution upto 1080p. This application note XAPP495 successfully demonstrates a high-definition TMDS video connectivity solution featuring the processing of multiple HD channels in parallel. The design demonstrates the Spartan-6 FPGA in DVI or HDMI applications (including the 480p, 1080i, and 720p video formats). Please note that 1080i and 1080p are having the same resolution but they aren't exactly the same. So I am not sure about XAPP495 demonstratiion with 1080p. ________________________________________________ Please mark this post as an "Accept as solution" in case if it helped to resolve your query. So that it will help to other forum users to directly refer to the answer. Give kudos to this post in case if you think the information is useful and reply oriented. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 13:41 , Processed in 0.706378 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3240
