电子发烧友论坛|
更新:我注意到我忘记在main.c中包含app.h文件,即使它包含在项目中(还有一个问题,但是还有一天)。项目现在构建,但是带有警告……src/main.c:78:警告:(359)指针类型之间的非法转换。希望有人能告诉我为什么。试着在工作中做一个项目,测试PCB上的继电器。他们在4个银行中,有一个使用SPI的继电器驱动器/锁存器和一个芯片选择线。我有四个函数向这些库发送数据,每个选择行一个。这个函数有一个函数指针作为参数。我有一个函数测试所有的库。我已经包括了源代码和构建输出的文本文件。谢谢你的帮助!上传修改文件的问题。再试一次
错误的.txt(5.82 KB)-下载65次Meal.C(1.96 KB)-下载46次 以上来自于百度翻译 以下为原文 Update: I noticed I forgot to include my app.h file in the main.c even though it was included in the project (another question there but for another day). Project now builds but with warnings .. src/main.c:78: warning: (359) illegal conversion between pointer types Would appreciate anyone cluing me in as to why. Trying to do a project at work that tests relays on a PCB. They are in 4 banks with a relay driver/latch using SPI and a chip select line. I have four functions that send data to these, one for each select line. I have one function that tests one of these banks at a time, given which select line to use. This is the function that has a function pointer as a parameter. I have one function that tests all of the banks. I've included source code and text file of output from build. Thanks for the help! having issues uploading revised files .. will try once more Attachment(s) app.h (0.54 KB) - downloaded 31 times error.txt (5.82 KB) - downloaded 65 times main.c (1.96 KB) - downloaded 46 times |
1个回答
如果您希望函数不返回值,则将其声明为无效。否则编译器会假设它们返回int。
以上来自于百度翻译 以下为原文 If you want you function to not return a value declare them as void. Otherwise the compiler will assume they return an int. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1122浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
473浏览 0评论
/9
GMT+8, 2025-12-1 21:31 , Processed in 0.727972 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1654
