电子发烧友论坛|
你好!太恶心了!每当我忘记将电源应用到板上或插入编程连接器时,MPLABX就会挂起。它抱怨“没有发现目标设备(无法检测到目标电压VDD)。你必须连接到目标设备使用MPLAB真正的ICE。无助于运用权力。没有更多的方法来编程PIC。除非我离开MPLABX(然后点击“投诉”,该操作仍在运行)。然后重新启动它。然后再做整个项目的扫描…Nick
以上来自于百度翻译 以下为原文 Hi! It is quite disgusting! Whenever I forget to apply power to my board or to plug in the programming connector, MPLABX hangs. It complains with "Target device was not found (could not detect target voltage VDD). You must connect to a target device to use MPLAB REAL ICE." and then that's it. Doesn't help to apply power. No more way to program the PIC. Except I leave MPLABX (and click away the complain that the make is still running). And then restart it. And then it does that scan of the whole project again ... Nick |
2个回答
拔出USB端口连接到真正的ICE。这就是我忘了给主板供电的原因。这比退出MPLABX要好。
以上来自于百度翻译 以下为原文 Unplug the USB port connection to REAL ICE. That's what I do when I forget to power up the main board. That's better than quitting MPLABX. |
想想看,这和ashttp://www..hip.com/for./m938209.aspxandhttp://www..hip.com/for./m938034.aspx是一样的。至少对于几个人来说,在ICD3、PICkit3和Real ICE上会发生同样的事情。-拔出USB(对于ICD3和PICTIT3)确实不冻结MPLABX!这几乎和修理一样好,谢谢你,吉姆!DOM。
以上来自于百度翻译 以下为原文 Think this is the same as http://www.microchip.com/forums/m938209.aspx and http://www.microchip.com/forums/m938034.aspx So the same thing happens, for several people at least, on ICD3, PICkit3, and Real ICE. Be nice if microchip could acknowledge that they might have a look before the next release. Also - unplugging USB (for ICD3 and PICkit3) does indeed un-freeze MPLABX! That's almost as good as a fix, thankyou Jim! dom. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1097浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 07:05 , Processed in 0.687285 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2927
