您好,我不能用PIC32 MX775 F256H与外部PHY LN820A通信。我使用的是TCP/IP栈,其中函数_PhyDetectReset()在复位时陷入,而循环是HIGH.static in t_PhyDetectReset(void){_BMCONbits_t bmcon;unsigned in t tStart,tWaitReset;bmcon.w=_PhyReadReg(PHY_REG_BMCON,_PhyAdd);//读取BMCON注册表(bmcon.RESET){//这已经是可疑的但是要给它一个机会来清除它自己/*CODE STUCKS HERE BMCON.RESET总是高的*/tWaitReset=(GetSystemClock()/2000)*PHY_RESET_CLR_TMO*PHY_RESET_CLR_CLR_TMO;tStart=ReadCoreTimer();tStart=ReadCoreTimer();在bmcon(bmcon.bmcon.w=_Phy读取Reg_PhyReadRegG_BMCON_REG_BMCON_BMCON,_PhyAdd);}}}(bmcon(bmcon.RESET.RESET&&&;(ReadCoreTimer()-tStarlt;tWaitReset);//w a it reset(PHY_REG_BMCON,_PhyAdd);如果(bmcon.RESET){bmcon.RESET//tmo清除复位0;}}}}还无法使用EthMIIMWWWWWritStar(PHY_REWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW写到PHY的任何数据(PHY_REREWWWWWWWWWWWWWWWWWWWWWWWWWWW写开始(PHY_REG_REG_BMY_BMCON_BMREG_BMCON_BMCON_BMCON_BMCON_BMCON_BMCON_BMCON_BMCON_BMCON_G_BMCON,_PhyAdD);/ /读回控制寄存器的位保持相同,PHY初始化失败。使用50 MHz时钟,使用RMII模式。控制reg位总是很高。有人能告诉我为什么PHY模块(LN 8720a)寄存器0的RESET位应该在读或写操作时变低?
以上来自于百度翻译 以下为原文 Hello , Am unable to communicate with external PHY LN8720a with PIC32mx775f256h . Am using TCP/IP stack where my function _PhyDetectReset() gets stuck in while loop as reset is HIGH. static int _PhyDetectReset(void) { __BMCONbits_t bmcon; unsigned int tStart, tWaitReset; bmcon.w=_PhyReadReg(PHY_REG_BMCON, _PhyAdd); // read the BMCON register if(bmcon.RESET) { // that is already suspicios...but give it a chance to clear itself /*CODE STUCKS HERE BMCON.RESET IS ALWAYS HIGH*/ tWaitReset=(GetSystemClock()/2000)*PHY_RESET_CLR_TMO; tStart=ReadCoreTimer(); do { bmcon.w=_PhyReadReg(PHY_REG_BMCON, _PhyAdd); }while(bmcon.RESET && (ReadCoreTimer()-tStart) bmcon.w=_PhyReadReg(PHY_REG_BMCON, _PhyAdd); if(bmcon.RESET) { // tmo clearing the reset return 0; } } Also am unable to write any data to PHY using EthMIIMWriteStart(PHY_REG_BMCON, _PhyAdd, _BMCON_LOOPBACK_MASK|_BMCON_ISOLATE_MASK); // write control bits bmcon.w=_PhyReadReg(PHY_REG_BMCON, _PhyAdd); // read back The bits of Control register remains same and PHy failed to initialise. have used 50 Mhz clock ,using RMII mode . The control reg bits remains always high. Can any one suggest me why the RESET bit of register 0 of PHY module ( LN 8720a) should go low forread or write operation? |
3个回答
LAN820A正在使用中?SMI(MIDO和MCLK)。你能看到数据信号吗?非常容易忽略上拉是必需的,所以总是可以调整范围以确保上拉值是正确的,并且您可以看到数据。SMI访问的最大时钟速度是2.5Mhz.AC320004-3 LAN8720A PHY子板LAN8720A Sch.Checklist
以上来自于百度翻译 以下为原文 LAN8720A is being used? SMI (MDIO and MCLK). Can you see the data signal? Very easy to overlook the pull ups are required, so always good to scope to make sure pull up value is correct and you see the data. Maximum Clock Speed for SMI access is 2.5Mhz. AC320004-3 LAN8720A PHY Daughter Board LAN8720A Schematic Checklist |
谢谢你的回复。问题解决了。这是高上限值连接到MIDO线:)
以上来自于百度翻译 以下为原文 Thank you for your reply. The problem is solved. it was high cap value connected to MDIO line :) |
只有小组成员才能发言,加入小组>>
5237 浏览 9 评论
2027 浏览 8 评论
1950 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3202 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2253 浏览 5 评论
772浏览 1评论
662浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
590浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
672浏览 0评论
572浏览 0评论
GMT+8, 2024-12-22 00:30 , Processed in 1.420230 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
