嗨ST。关于TDA7498和TDA7498E的应用,我有几个问题。
TDA7498E应用电路在输出端有肖特基二极管,但TDA7498没有,有这样的原因吗? 由于音圈和交叉网络的组合电感约为4mH,我想要驱动的扬声器设计具有高电感。你能协助计算缓冲电路的C和R的正确值吗?我的低通滤波器基于6欧姆滤波器值(由于扬声器阻抗下降)。数据简报以330pF和22R为起点,我怀疑我需要与此不同。 扬声器系统是8欧姆系统,但最小阻抗为4.9欧姆。我更好地将PCB改为使用TDA7498而不是TDA7498,从可靠性的角度来看,IC更好。 该设计旨在尽可能可靠,从0.4K / W散热器开始,以保持封装冷却。 谢谢, 马库斯 以上来自于谷歌翻译 以下为原文 Hi ST. I have a few questions regarding the application of the TDA7498 and TDA7498E. The TDA7498E application circuit has schottky diodes on the output but the TDA7498 does not, is there a reason for this? The loudspeaker design I am wanting to drive has high inductance due to both the voice coil and crossover network with a combined inductance of approximately 4mH. Can you assist in calculating the correct values for C and R for the snubber circuit. I am basing my low pass filter on the 6 ohm filter values (due to speaker impedance dips). The data brief says 330pF and 22R as a starting point, I suspect I need to differ from this. The loudspeaker system is an 8 ohm system but has a minimum impedance of 4.9 ohms. Is it better for me to change my PCB to use the TDA7498E instead of the TDA7498 and from a reliability point of view which IC is better. The design is intended to be as reliable as practically possible starting with a 0.4K/W heatsink to keep the package running cold. Thanks, Marcus |
1个回答
在Marcus,由于TDA7498E可以在单声道BTL模式下提供更高的输出电流来驱动低阻抗负载(2欧姆),那么这些二极管已用于降低尖峰电压电平。
我想你在谈论BTL输出之间的缓冲网络22R + 330pF,你可以在输出和地之间将其改为10R + 680pF。但是对于感性负载,你需要用低输出功率的扬声器加交叉滤波器检查实际频率响应(否则你的高音扬声器可能烧坏),然后调整L + C值以平衡你在高频段的响应。 由于你的负载阻抗可能是4.9欧姆,那么36V电源的输出电流可能很小,最好使用TDA7498E。 谢谢 YT 以上来自于谷歌翻译 以下为原文 hi Marcus,due to TDA7498E can deliver higher output current to drive low impedance load (2 ohm ) in mono BTL mode , then those diode had been used to reduce spike voltage level. I supposed you are talking about snubber networks 22R+330pF between BTL output, you may change it to 10R+680pF between output and ground . but regarding inductive load , you need to check the real frequency response with speaker plus crossover filter in low output power(otherwise your tweeter may be burnt out) , then adjusted L+C value to flat your response in upper audio band . since your load impedance could be 4.9 ohm , then output current may be marginal with 36V supply , it's better to use TDA7498E . Thanks YT |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2490 浏览 1 评论
3167 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1731 浏览 1 评论
3553 浏览 6 评论
5927 浏览 21 评论
894浏览 4评论
1268浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
535浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1254浏览 3评论
1307浏览 3评论
GMT+8, 2024-10-12 00:40 , Processed in 1.001402 second(s), Total 80, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
