亲爱的论坛成员,
我想分享一些关于我用来根据预定义技术要求选择运算放大器的常规过程的技巧。 我经常使用的工具是产品选择器,可以通过单击ST主页上的以下图标来访问它: 然后在产品树中选择: 放大器和比较器 >放大器。 这里也是直接链接到 http://www.st.com/stonline/stapp ... age=productSelector : http://www.st.com/stonline/stapp ... age=productSelector 然后,下一步是使用 FilterPanel®来优化技术要求。 提示1:使用箭头查看所有过滤参数。 提示2:使用靠近参数名称的图标在 tickcase 和 slider 之间切换过滤器类型。 在我的典型运算放大器选择中,我首先应对更明显(和限制性)的参数应用滤波器,如电压额定值 Vcc , 数量通道 或 汽车等级 。 然后,一旦选择范围缩小到有限数量的组件,我将使用排序选项,通过单击参数。如果列表按升序或降序排序,则会显示一个红色箭头。 例如,按最大供电电流排序: 在这种情况下,排序选项有助于解决Icc / GBW权衡问题。 不要犹豫,让我们知道您对产品选择器的评论,以及是否有其他功能您希望实现。 最好的祝福。 #比较运算放大器#product-selector-op-amps-filter 以上来自于谷歌翻译 以下为原文 Dear Forum Members, I�d like to share a few tips on the usual process I use to select an Op Amp based on pre-defined technical requirement. The tool I use more often is the product selector, which can be accessed by clicking on the following icon from ST home page: Then select in the product tree: �Amplifiers and Comparators� > �Amplifiers�. Here is also direct link to the http://www.st.com/stonline/stapp ... age=productSelector : http://www.st.com/stonline/stapp ... age=productSelector The next step is then to use the �Filter Panel� in order to refine the technical requirements. Tip1: use the arrows to see all the filtering parameters. Tip2: use the icon close to the parameter name to toggle the filter type between �tick case� and �slider�. In my typical Op Amp selection, I would firstly apply filter on the more obvious (and restrictive) parameters, like voltage rating �Vcc�, �number of channel� or �automotive grade�. Then once the selection is narrowed to a limited number of components, I would use the sorting option, by clicking on the parameter. A red arrow indicated if the list is sorted by ascending or descending order. For instance sorting by maximum supply current: In this case, the sorting option helps to address the Icc / GBW trade off. Don�t hesitate to let us know your comments about the product selector and if there are additional features you would like to see implemented. Best regards. #comparison-operational-amplifier #product-selector-op-amps-filter |
3个回答
你好,
我在设计中使用了来自不同供应商的几个运算放大器。 如何从STMicro中找到等效的运算放大器? 谢谢。 以上来自于谷歌翻译 以下为原文 Hello, I use several operational amplifiers from different suppliers in my designs. How can I find equivalent operational amplifiers from STMicro? Thank you. |
亲爱的让,
为了从ST产品组合中选择等效的运算放大器,您可以: - 通过输入您的技术要求,使用前一篇文章中所述的产品选择器 要么 - 使用ST网站提供的交叉引用工具。 要查找交叉引用:首先转到ST主页,选择屏幕右上角的“搜索”选项卡,在“交叉引用”字段中键入目标设备。 最好的祝福。 以上来自于谷歌翻译 以下为原文 Dear Jean, In order to select an equivalent Operational Amplifier from ST portfolio, you can either: - use the product selector as explained in previous post, by typing in your technical requirements or - use the cross reference tool provided in ST website. To find the cross reference: go first to ST home page, select the ''Search'' tab on top-right of the screen, type your target device in the ''cross reference'' field. Best regards. |
亲爱的论坛成员,
运算放大器选择过程中的另一个提示:您可能需要比较两个或更多设备,ST网站有专门的功能。 这是如何进行的:首先按照前面的说明进入产品选择器 http://www.st.com/stonline/stappl/productcatalog/app?page=productSelector 然后单击位于表格右下角的比较图标。 此操作将在右侧打开一个面板,您可以在其中拖放要比较的组件。完成后,点击?比较?按钮。 您将获得以粗体突出显示的差异的设备的参数比较。 希望这可以帮助你! 最好的祝福。 以上来自于谷歌翻译 以下为原文 Dear Forum Members, Another tip in your operational amplifier selection process: you may need to compare two or more devices, and ST website has a dedicated feature for this. Here?s how to proceed: first go to the product selector as explained before http://www.st.com/stonline/stappl/productcatalog/app?page=productSelector Then click on the comparison icon located on the bottom right of the table. This action opens a panel on the right where you may drag and drop the components you want to compare. Once this is done, click on the ?compare? button. You get the parametric comparison of devices with differences highlighted in bold. Hope this can help! Best regards. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2511 浏览 1 评论
3178 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1741 浏览 1 评论
3560 浏览 6 评论
5940 浏览 21 评论
906浏览 4评论
1277浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
546浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1264浏览 3评论
1320浏览 3评论
GMT+8, 2024-10-19 22:04 , Processed in 1.437108 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
