你好,
我正在使用Spartan 6 75T设备进行设计,我想使用bistream加密功能,并且不关心电池备份,因为设备将启动(在设计/调试期间)或使用eFuse的密钥存储。 问题是:在这种情况下,Vbatt引脚连接应该是什么。 我在手册中找到了以下注释: 当未应用VCCAUX时,VBATT需要维持电池备份RAM(BBR)AES密钥。 应用VCCAUX后,VBATT可以不连接。 不使用BBR时,Xilinx建议连接到VCCAUX或GND。 但是,VBATT可以是未连接的。 这对我来说不是很有帮助(一个帖子说同样的,一个webcase应该打开,但我找不到它)。 那么,Vbatt接地是否允许: - 使用eFuse功能:答案是肯定的(如其他帖子中所述) - 在设备通电时使用加密(VCCaux存在)而不使用eFuse:我不能从说明中说出来。 它应该没有连接吗? 在此先感谢您的澄清。 帕斯卡尔 以上来自于谷歌翻译 以下为原文 Hello, I am designing with a Spartan 6 75T device and I want to use the bistream encryption feature, and do not care about the battery backup as the device will be either powered up (during design/debug) or the key store using the eFuse. The question is: what the Vbatt pin connection shall be in such a case. I found the following note in the manuals: VBATT is required to maintain the battery backed RAM (BBR) AES key when VCCAUX is not applied. Once VCCAUX is applied, VBATT can be unconnected. When BBR is not used, Xilinx recommends connecting to VCCAUX or GND. However, VBATT can be unconnected. Which is not very helpul to me (a post said the same and that a webcase shall be opened but i cannot find it). So, is Vbatt grounded allows: - using the eFuse feature: the answer is yes (as already stated in other post) - using the encryption when the device is powered up (VCCaux is present) without using eFuse: I cannot say from the note. Shall it be unconnected ? Thanks in advance for the clarification. Pascal |
4个回答
是的,这是真的。
-------------------------------------------------- ---------------------------------------------请将帖子标记为 如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Yes, that's true.----------------------------------------------------------------------------------------------- Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue. Give Kudos to a post which you think is helpful.View solution in original post |
嗨Pascal,有一个不使用VBATT的反面。
如果设备断电,则存储在BBRAM中的密钥将被删除。如果您确定VCCAUX可以连续使用,那么您可以移除VBATT.Vbatt应该在Vccaux处于活动状态时保持浮动。注意,Krishna -------------------------------------------------- ---------------------------------------------请将帖子标记为 如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。 以上来自于谷歌翻译 以下为原文 Hi Pascal, There is a flip-side of not using VBATT. If the device is powered down then the key stored in BBRAM would be erased. If you are sure that VCCAUX would be available continuously, then you can remove the VBATT. Vbatt should be left floating while Vccaux is active. Regards, Krishna----------------------------------------------------------------------------------------------- Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue. Give Kudos to a post which you think is helpful. |
你好克里斯纳,
不过,我会将VCCAUX和VBATT组合在一起,以便为与密钥存储相关的内部电路供电。 因此将它绑在GND无关紧要。 从你回答,我知道加密功能不适用于VCCAUX和VBATT连接到GND。 那是对的吗 ? 以上来自于谷歌翻译 以下为原文 Hello Krisna, I would have though that VCCAUX and VBATT would be ORed together to power the internal circuitry related to the key storage. Hence tying it to GND does not matter. From you answer, i understand that the encryption feature will not work with VCCAUX on and VBATT connected to GND. Is that correct ? |
是的,这是真的。
-------------------------------------------------- ---------------------------------------------请将帖子标记为 如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。 以上来自于谷歌翻译 以下为原文 Yes, that's true.----------------------------------------------------------------------------------------------- Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue. Give Kudos to a post which you think is helpful. |
只有小组成员才能发言,加入小组>>
2180 浏览 7 评论
2618 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2090 浏览 9 评论
3156 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2213 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
453浏览 1评论
1541浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2186浏览 0评论
516浏览 0评论
1659浏览 0评论
GMT+8, 2024-5-15 20:15 , Processed in 1.457344 second(s), Total 82, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
