你好。我正在使用ST25R3911B和STM32F401从卡中读取一些APDU命令。
我正在使用 X-CUBE-NFC5软件扩展。 在我的所有命令完成之前,我收到“ERR_NOMEM”错误。 我正在清除(rfalIsoDepApduBufFormat)txBuf和 ( rfalIsoDepApduBufFormat)r xbuf每次运行rfalIsoDepStartApduTransceive(* par)之前;命令...有什么我还应该清除以防止内存不足错误?我还试图在我的APDU命令之间添加延迟,看看它是否会有所帮助。 #nfc05#x-cube-nfc5#st25r3911b 以上来自于谷歌翻译 以下为原文 Hi. I am Reading a few APDU Commands from a card using the ST25R3911B and the STM32F401. I am using the X-CUBE-NFC5 software expansion. Before all my commands are completed, i get a 'ERR_NOMEM' error. I am clearing the (rfalIsoDepApduBufFormat) txBuf and ( rfalIsoDepApduBufFormat) r xBuf every time before I run the rfalIsoDepStartApduTransceive(*par); command... Is there anything I should also clear to prevent the Out of Memory error? I have also tried to add delays between my APDU Commands to see if it would help. #nfc05 #x-cube-nfc5 #st25r3911b |
2个回答
嗨马吕斯,
我们需要更多信息来更好地理解这个问题, 您能否提供有关正在交换的APDU的更多详细信息? 是否在不同时刻使用相同或不同的卡观察到错误? 是否可以动态计算请求APDU并且它的长度或相同的静态序列是否被发送? 不仅在接收时,如果数据长度太大,也可能在传输时发生错误ERR_NOMEM。 亲切的问候 GP 以上来自于谷歌翻译 以下为原文 Hi Marius, We need some more information to better understand the issue, Could you provide more details about the APDUs being exchanged? Is the error observed on different moments with the same or different cards? Can it be that the the request APDUs are being calculated dynamically and and its length, or the same static sequence is sent? Not only upon reception, the error ERR_NOMEM can also occur on transmission if the data length is too large. Kind regards GP |
嗨Grégiore。
谢谢您的回复。今天早上我再次浏览了我的代码并在函数内部 SendApdu()我有一个检测响应的循环。在循环内部,我在调用rfalWorker()之前有一个2毫秒的HAL_Delay。这似乎导致了消息的一些时间问题,因此它有时会起作用而其他时候不起作用。一旦我从代码中删除了延迟,我就没有更多关于我的APDU响应的问题。在等待传入消息时,我从代码中删除了所有延迟。 感谢您的帮助。 以上来自于谷歌翻译 以下为原文 Hi Grégiore. Thank you for your reply. This morning I have gone through my code again and inside the function SendApdu() I have a loop that detects the response. Inside the loop I had a HAL_Delay of 2 milliseconds just before I call rfalWorker(). This seems to have caused some timing issues with the messages hence the reason why it sometimes work and other times not. As soon as I removed the delay from the code, I have had no more issues on my APDU responses. I removed all delays from my code when waiting for incoming message. Thank you for the assistance. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
663浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 08:59 , Processed in 0.765382 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
727
