亲爱的All,我有一个54831D O-scope,现在通过Rs232端口快速通信。
我有一个NULL MODEM电缆,我在两台计算机之间测试它,但它工作但我试图通过RS232端口发送命令到O-scope但没有答案。 O-scope是否具有可用于交换命令的RS232协议? 因为手册说该端口仅用于打印机等.... 我在PC机箱中使用Ubunto Linux作为操作系统。 谢谢你,兰花 以上来自于谷歌翻译 以下为原文 Dear All, I have a 54831D O-scope and for now the fast way to communicate with it is via Rs232 port. I have a NULL MODEM cable that I tested it between two computers and it works but I tried to send commands to the O-scope through the RS232 port but no answer from it. Is the O-scope has a working RS232 protocol for exchanging commands? because the manual says the port is only used for printer etc .... ? I use Ubunto Linux as OS in the PC box. Thank you, rachid |
2个回答
Rachid,LAN是一个更好的解决方案,Linux的控制并不太难。
不过,我建议您首先查看安捷伦网站。 通过LAN有一整套关于仪器控制的应用笔记。 一个好的起点是在Agilent主页(www.agilent.com)上搜索“Linux”。 人 以上来自于谷歌翻译 以下为原文 Rachid, LAN is a much better solution, and control from Linux is not too hard. I would recommend that you look on the Agilent website, first, though. There is a whole set of Application Notes on instrument control through LAN. A good place to start is to search on "Linux" on the main Agilent web page (www.agilent.com). Al |
nvywyerwer 发表于 2019-7-16 11:02 Al,当你从这个线程开始这里为了让局域网丢失,所以我继续在这里。 我已经使用过低级插槽编程并且可以处理它,但正如您所说,安捷伦用户程序员手册中有准备好的LAN例程,并且还有我的计算机中的文件。 阻止我在这里的唯一的事情是O-scope我得到它是一个使用它的Windows 98它似乎无法识别我们的局域网,我试图按照他们在手册中说的设置以太网: 转到属性等....但我没有成功将范围连接到以太网。 可能Windows版本已经老了,并没有一些驱动程序.....我想我应该安装Windows 7例如? 覆盖事物是否有风险或者可以做到? 拉希德 以上来自于谷歌翻译 以下为原文 Al, As you started here in this thread to discsuss LAN so I continue here. I already worked with low level sockets programming and can deal with it but as you said there are ready LAN routines in Agilent user programmer's manual and also have the files in my computer. The only thing that block me here is the O-scope I get it a used one and it has windows 98 on it and it seems it does not recognize our LAN, I tried to follow what they said in the manual to setup the ethernet: going to properties etc .... but I did not succeed to connect the scope to ethernet. Probably windows version is old and did not has some drivers ..... I think I should install windows 7 for example? is it risky to overwrite things or it can be done? Rachid |
只有小组成员才能发言,加入小组>>
1229 浏览 0 评论
2350 浏览 1 评论
2160 浏览 1 评论
2026 浏览 5 评论
2908 浏览 3 评论
973浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
706浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
807浏览 0评论
1229浏览 0评论
GMT+8, 2024-11-25 13:32 , Processed in 1.634955 second(s), Total 82, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
