电子发烧友论坛|
我的办公室有2台电脑第一台电脑使用WinXP,主板有RS232端口第二台电脑使用Win XP,主板无法插上RS232。
我使用ATEN USB转RS232适配器连接到34401A第一台计算机可以毫无问题地连接到34401A。 只需安装Benchvue并使用RS232电缆连接它们。 但这款电脑配置不好,它采用双核处理器,512MB Ram,所以操作速度很慢。 第二台计算机配置更好。 但由于它没有配备RS232端口。 我使用ATEN USB转RS232适配器连接PC和34401A。 但是当我尝试在Benchvue中启动DMM应用程序时,PC和34401A都无法相互通信。 并且34401A前面板“ERROR”指示灯亮起。 我想这个问题的出现是因为USB转RS232适配器不支持某种握手。 我的问题是,是否有任何品牌和型号的USB转RS232已经获得KEYSIGHT认可,可用于其万用表产品? 谢谢 以上来自于谷歌翻译 以下为原文 My office have 2 computers first computer use WinXP, motherboard have RS232 Port second computer use Win XP, motherboard cannot plug in RS232. I use the ATEN USB to RS232 Adapter to connect to 34401A The first computer can connect to 34401A without any problem. Simply just installed Benchvue and use an RS232 cable to connect between them. But this computer config is bad, it is using dual core processor, 512MB Ram, so the operation is very slow. The second computer had a better config. But since it does not come with RS232 Port. I use ATEN USB to RS232 Adaptor to connect between PC and 34401A. But when I try to launch the DMM apps in Benchvue, both PC and 34401A cannot communicate with each other. And the 34401A front panel "ERROR" light is on. I guess this problem occur because of the USB to RS232 adapter do not support some kind of handshaking. My question is, is there any brand and model of USB to RS232 that are already approved by KEYSIGHT that can be use on their multimeter product ? Thanks |
1个回答
假设您在两台机器上都设置了相同的RS-232端口参数,我建议使用FTDI-US232R-100。
我发现它与34401A配合得很好。 它有完整的握手。 布赖恩 以上来自于谷歌翻译 以下为原文 Assuming you have the RS-232 port parameters set the same way on both machines, I would recommend the FTDI-US232R-100. I have found it to work well with the 34401A. It has full handshaking. Brian |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1843浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 17:48 , Processed in 0.646839 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
12637
