电子发烧友论坛|
那么为什么我要使用1.34:这个项目从1.34开始,我不希望使用两个编译器的同一个项目。也许现在是时候更新到1.37或1.38?在一台相当旧的XP机器上,所有的电脑都很好用。我知道这个项目是在那里编译的。我不愿意更新太多的程序,直到我知道我可以把旧的盒子装箱。在Windows 10系统上尝试在家里处理它时,我发现它掉了一个MaFaCH文件错误。就我所知,编译某些文件时,XC8只需返回一个返回代码(错误级别)为1,但没有错误消息。“预”文件被截断为中线,它看起来仍然是处理头文件的东西,而不是程序代码。两个源文件受到影响,一个是模块,另一个是项目的“主”。较早的版本在两个版本上编译好。当前版本用XC8 1.37编译,这将是我现在的解决方案。
以上来自于百度翻译 以下为原文 So why am I using 1.34: Well the project started on 1.34 and I didn't want the same project using two compilers. Maybe it is time to update to 1.37 or 1.38 anyway? Everything's worked fine on the office computer which is a rather old XP machine. I know the project compiles there. I'm reluctant to update programs too far until I know I can bin the old box. Trying to work on it at home on a Windows 10 system I find that it drops out with a makefile error. As far as I can tell when compiling certain files XC8 just stops with a return code (error level) of 1 but no error message. The "pre" file is truncated mid-line, and it seems to be still processing header file stuff at that point not the program code. Two source files are affected, one is a module but the other is the "main" for the project. An earlier version compiles fine on either version. The current version compiles with XC8 1.37 which is going to be my solution for now. Just to clarify: I was using 1.34 succesfully on the other computer. |
3个回答
如果你说V1.34不起作用,但V1.37确实如此,那么是的,你需要更新编译器。
以上来自于百度翻译 以下为原文 If you are saying v1.34 does not work, but v1.37 does, then yes you would need to update your compiler. |
我只是想知道,是否有人认识到这是一个已知的问题,或者是否有一个明显的答案,为什么某样东西在一台计算机上编译良好,而在另一台计算机上使用相同的编译器失败,比如临时或配置文件权限的问题?
以上来自于百度翻译 以下为原文 I was just wondering if anyone recognised it as a known issue or if there was an obvious answer to why something compiled fine on one computer and failed on another using the same compiler, such as an issue with temp or config file permissions? |
相同的编译器版本不同的计算机。相同的IDE和版本?对不起,我没有洞察力,也许其他人会。
以上来自于百度翻译 以下为原文 Same compiler version different computers. Same IDE and Version? Sorry I have no insight. Maybe someone else will. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1121浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
473浏览 0评论
/9
GMT+8, 2025-12-1 19:48 , Processed in 0.731131 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1301
