电子发烧友论坛|
问候一个,这是我的第一篇文章,所以我会努力使它成为一个好的。我是在菲尼克斯的精密测量实验室工作的国防部承包商。
我有一个3458A,我正在升级03458-91000 A2板,取代目前安装的03458-66502板。 据我所知,这将为我的3458A提供4ppm的Opt 002 Hi-Stability Reference。 换掉电路板并预热后,我启动了ACAL ALL。 在ACAL的AC部分期间,我收到此错误:“204,HARDWARE FAILURE,AC VOS DAC CONVERGENCE:1837035519。” 在做了研究之后,我发现这个错误(204)与我刚刚安装的卡有关。 我仔细检查了所有连接,重新运行ACAL并得到了同样的错误。 我把旧卡放回去,运行ACAL,它工作正常。 我的问题是; 我错过了什么吗? 是否需要将软件或其他类型的更新输入到设备中,或者我的91000 A2板是否有用?请提前感谢您的帮助。 以上来自于谷歌翻译 以下为原文 Greetings one and all, This is my first post, so I'll try to make it a good one. I am a DoD contractor working at a precision measurement lab in Phoenix. I have a 3458A that I am upgrading with a 03458-91000 A2 board, replacing the 03458-66502 board currently installed. It is my understanding that this will give my 3458A the Opt 002 Hi-Stability Reference, 4ppm. After swapping out the board and wARMing up the unit, I initiated ACAL ALL. During the AC portion of the ACAL, I receive this error: "204, HARDWARE FAILURE, AC VOS DAC CONVERGENCE: 1837035519." After doing research, I found that this error (204) pertains to the card I just installed. I double-checked all the connections, re-ran ACAL and got the same error. I put the old card back in, ran ACAL and it worked fine. My question is; am I missing something? Is there a software or some other kind of update that needs to be input into the unit, or is my 91000 A2 board a dud? Thanks in advance for your help. |
1个回答
更新:重新安装03458-91000并运行CAL 0,CAL 10,CAL 10K没有问题。
启动AC Adjustement并无误地运行SCAL 1E5。 但是,在启动SCAL 10时,我得到两个错误:101-校准错误和106-超出范围(预期频率为1E5,2E6或8E6)。 这些错误发生在100 kHz,2 MHz和8 MHz输入上。 以上来自于谷歌翻译 以下为原文 Update: Re-installed 03458-91000 and ran CAL 0, CAL 10, CAL 10K without problems. Started AC Adjustement and ran SCAL 1E5 without error. However, upon starting the SCAL 10, I get two errors: 101-Calibration Error and 106-Out of range (expected frequency to be 1E5, 2E6 or 8E6). These errors occur on the 100 kHz, 2MHz, and 8MHz inputs. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 02:33 , Processed in 1.405472 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
338
