扫一扫,分享给好友
嗨,我有两个距离感应(谐振器)。
我毫无问题地绘制了电感之间的电场和磁场E和H. 现在我想绘制特征阻抗(Z = E / H)和poynting矢量S = E X H ... - 是否可以表示Z和S? - 我努力进入一个等式? (我已经尝试过参数......)请,我需要帮助......我在这个问题上失去了很多时间..先谢谢西蒙 以上来自于谷歌翻译 以下为原文 Hi, I have two inductances (resonator) with a distance. I plotted the electric and magnetic fields E and H between the inductances without problem. Now i want to plot the characteristics impedance (Z=E/H) and the poynting vector S = E X H... -Is it possible to represent Z and S? - I musst toenter an equation? (i already tried with parameters...) Please, i need help... i lost a lot of time with this problem.. Thanks in advance Simon 附件
3个回答
嗨西蒙,通过访问EMPro支持主页,您可以提交项目文件并获得更多帮助,但我会在这里尝试回答您的问题。
1.无法在EMpro中绘制阻抗Z. 2.对于指向矢量J = E X H,您可以在高级可视化窗口中绘制它。 为此,您需要在FEM Simulation设置窗口的“频率计划>现场存储”面板中选中“保存字段”选项之一。 完成FEM模拟后,转到“结果”窗口,然后单击窗口顶部的“高级可视化”按钮,启动“高级可视化”窗口并绘制不同的字段数据。 有关更多详细信息,请参阅EMPro文档。 我们在知识中心获得了大量有关EMPro帮助的文档,有关详细信息,请参阅EMPro产品文档。 Kaelly 以上来自于谷歌翻译 以下为原文 Hi Simon, By going to EMPro Support Home , you can submit your project file and get more help, but I will try to answer your question here. 1. There is no way to plot the impedance Z in EMpro. 2. For pointing vector J = E X H, you can plot it in Advanced Visualization window. In order to do that, you need to check one of the options of ‘Save fields for’ in ‘Frequency Plans > Field Storage’ panel in FEM Simulation Setup Window. After the FEM simulation finishes, go to ‘Results’ window and click on the button ‘Advanced Visualization’ on top of the window to launch Advanced Visualization window and plot different fields data. Please refer to EMPro documents for more details. We've got lots of documents in the Knowledge Center for help with EMPro, refer to EMPro Product Documentation for more details. Kaelly |
嗯......可能有很多可能的原因。
也许您正在运行旧版本的EMPro? 或者,在激活“高级可视化”按钮之前,您可能需要首先突出显示模拟的FEM运行? 这可能会有所帮助,但我怀疑还有更多细节需要解决。 发送给技术支持的门票[www.agilent.com/find/eesof-support|www.agilent.com/find/eesof-support],我们很乐意看看您的文件。 以上来自于谷歌翻译 以下为原文 Hmm...there could be lots of possible reasons for this. Perhaps you are running an older version of EMPro? Or you might need to highlight a simulated FEM run first before you can activate the "Advanced Visualization" button? This might help, but I suspect there are more details to be worked out still. Send in a ticket to tech support [www.agilent.com/find/eesof-support|www.agilent.com/find/eesof-support] and we would be happy to take a look at your files. |
yhxc 发表于 2019-7-10 15:27 您需要先选择项目才能看到可视化菜单。 如果您没有包含现场数据的模拟结果,则可能无法显示。 请先检查这些。 以上来自于谷歌翻译 以下为原文 You need to select the project first to see the visualization menu enabled. It may not be shown if you don't have simulation results that include field data. Check these first, please. |
只有小组成员才能发言,加入小组>>
1270 浏览 0 评论
2371 浏览 1 评论
2187 浏览 1 评论
2061 浏览 5 评论
2943 浏览 3 评论
1081浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
744浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
901浏览 0评论
1271浏览 0评论
GMT+8, 2024-12-18 12:21 , Processed in 1.305660 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
