有没有办法在仪器屏幕上直观地看到频率步进比例(线性或对数)的设置?
我正在使用Agilent RFSigGen驱动程序并命令AgRfSigGen_ConfigureFrequencyStepStartStop。 我可以看到Start& 停止频率和(在计算步骤点之后)StepSize。 我如何看到Scaling值已经改变?我按下仪器前面的Sweep键并且可以很容易地看到所有内容,但我不知道在哪里可以找到Scaling参数。提前谢谢!ChrisViStatus _VI_FUNC AgRfSigGen_ConfigureFrequencyStepStartStop(ViSession Vi) ,ViReal64 Start,ViReal64 Stop,ViInt32 Scaling,ViReal64 StepSize); 以上来自于谷歌翻译 以下为原文 Is there a way to visually see in the instrument screen the setting for Frequency Step Scaling (either Linear or Logarithmic)? I am using the Agilent RFSigGen driver and command AgRfSigGen_ConfigureFrequencyStepStartStop. I can see the Start & Stop frequencies and (after calculating the step points) the StepSize. How do I see that the Scaling value has changed? I press the Sweep key on the front of the instrument and can readily see everything, but I am not sure where to find the Scaling parameter. Thanks in advance! Chris ViStatus _VI_FUNC AgRfSigGen_ConfigureFrequencyStepStartStop ( ViSession Vi, ViReal64 Start, ViReal64 Stop, ViInt32 Scaling, ViReal64 StepSize ); |
1个回答
Hi -E8257D的步进模式不提供步进频率读数。
但是,我们的客户可以定义或读取步进点的数量,步数可以从点数得出.Freq_step =(Stop_Freq - Start_Freq)/#个点要设置点数,E8257D按:扫描/列表 - > 扫描类型 - >步骤 - >配置斜坡/步骤扫描 - >输入#PointsBelow是远程命令:SWEep:POINtsSupported所有模型[:SOURce]:SWEep:POINts [:SOURce]:SWEep:POINts?此命令可让您定义 步骤扫描中的点数。示例:SWE:POIN 2001前面的示例将步骤扫描点的数量设置为2001.我希望这有助于 - 以上来自于谷歌翻译 以下为原文 Hi - E8257D’s step mode does not provide step frequency read-out. However, our customer can define or read the number of stepping points and step frequency can be derived from the number of points. Freq_step = (Stop_Freq – Start_Freq) / # of points To set # of points, E8257D press: Sweep/List->Sweep Type->Step->configure Ramp/Step Sweep-> enter # Points Below are the remote commands :SWEep:POINts Supported All Models [:SOURce]:SWEep:POINts [:SOURce]:SWEep:POINts? This command enables you to define the number of points in a step sweep. Example :SWE:POIN 2001 The preceding example sets the number of step sweep points to 2001. I hope this helped - |
只有小组成员才能发言,加入小组>>
1133 浏览 0 评论
2321 浏览 1 评论
2114 浏览 1 评论
1985 浏览 5 评论
2859 浏览 3 评论
879浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
648浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
750浏览 0评论
1448浏览 0评论
1133浏览 0评论
GMT+8, 2024-10-20 13:55 , Processed in 1.957246 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
