电子发烧友论坛|
我想观察LTE基带和RF UL信号的互相关结果,以识别定时事件,例如帧的开始,子帧,DMRS等。我已经在Agilent MSO9064A和RF上捕获了基带
VSA 89600B和Agilent N9030A。 我将捕获文件提供给matlab并执行交叉相关,输出中没有明显的事件尖峰。 有任何想法吗? 以上来自于谷歌翻译 以下为原文 I would like to observe the cross-correlation results of LTE baseband and RF UL signals to identify timing events, such as the beginning of frames, sub-frames, DMRS, etc. I have captured the baseband on an Agilent MSO9064A and the RF using VSA 89600B and an Agilent N9030A. I fed the capture files to MatLab and performed the cross-correlation with no obvious event spikes in the output. Any ideas? |
1个回答
Hi - VSA中目前不提供RF和基带之间的跨通道测量。
在89600 VSA中,我们在相同硬件的通道之间提供互相关结果(因此对于多通道硬件采集)。 但是,这是我们在VSA软件中唯一的内置功能。 有两个不同的前端,可能他们可以使用数学函数,但似乎2次采集之间的时间对齐可能是一个问题。 这不是我们探索过的应用程序。 即使在MATLAB中进行分析,我认为你必须小心不同的采样率和开始时间。 问候 - 以上来自于谷歌翻译 以下为原文 Hi - Cross channel measurements between RF and baseband are not currently available in the VSA. In the 89600 VSA we provide cross-correlation results between channels of the same hardware (so for multi-channel hardware acquisitions). But, that’s the only built-in functionality we have in the VSA software. With 2 different front-ends, potentially they could use math functions, but seems like time alignment between the 2 acquisitions could be a problem. This is not an application we have explored. Even performing the analysis in MATLAB, I think you’d have to be careful of differing sample rates and start times. Regards - |
只有小组成员才能发言,加入小组>>
315 浏览 0 评论
1872 浏览 0 评论
2757 浏览 1 评论
2659 浏览 1 评论
2480 浏览 5 评论
1872浏览 0评论
438浏览 0评论
319浏览 0评论
/9
GMT+8, 2025-12-18 04:52 , Processed in 1.060605 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3094
