电子发烧友论坛|
我有关于斯巴达3e的adc的问题。
模拟效果很好但是当我加载到电路板中时。 它没有用。 我用switch 0开始转换。 在开关0打开后,不同的adc位值出现在LED上,但经过一段时间后它们都变高了。 无论adc输入如何,这个过程都是相同的,即使它们没有输入相同的过程也会在LED上重复。 我整顿了3天,但我无法找到问题所在。 请看一下。 ADC.rar 7 KB 以上来自于谷歌翻译 以下为原文 i have problem regarding adc of spartan 3e. simulation works well but when i load it into the board. it didnt work. i have used switch 0 to start the conversion. after switch 0 is turned on different values of adc bits appear on leds but after some time they all became high. this process is same regardless of the adc input, even when their is no input same process repeats on leds. i am dubugging it for 3 days but i am unable to find out the problem. please have a look on it. ADC.rar 7 KB |
1个回答
几件事
附件没有core_c.vhd文件。 您遇到的问题是您的编码方式,因此这不是人们可以帮助您进行VHDL编码的地方。 这里的人们将帮助您解决Spartan特定问题,如综合,PAR警告或错误。 ADC.vhd中的状态机不使用时钟而是使用派生信号,因此模拟它可以,但实际上它不是一个好方法 SPI_MISO线上接收的SPI数据必须使用ADC运行的SPI时钟读取,或者您需要知道ADC SPI时钟与用于读取SPI_MISO数据的时钟之间的关系。 以上来自于谷歌翻译 以下为原文 Couple of things The attachment does not have the core_c.vhd file. The issue you have is with the way you code, so this is not a place where people can help you with VHDL coding. People here will help you with Spartan specific problem like synthesis, PAR warning or errors. The state machine in ADC.vhd is not using a clock but a derived signal so simulaion wise it is ok but practically it is not a good way The SPI data received on the SPI_MISO line has to be read with the SPI clock the ADC is operating on or you need to know the relationship between the ADC SPI clock and the clock you are using to read the SPI_MISO data. |
只有小组成员才能发言,加入小组>>
3137 浏览 7 评论
3433 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2895 浏览 9 评论
4094 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3079 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1353浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1191浏览 1评论
/9
GMT+8, 2025-12-9 08:06 , Processed in 0.857237 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3057
